How to get fast exporting times?
Feb 15, 2014 11:01 AM
Tags: #pro #premiere #exporting #faster #fast #times
So i have recently brought a new computer (very powerful) for the things i want to do, as i am also posting this you can tell i make alot of videos as well.
Here are my computer specs:
intel core i7 quad core 3.70ghz
16gb beast ram 2400mhz
4gb amd radeon r9 290 graphics card
asus SSD writes @ 830mb/rs
At the moment i am exporting a video which is 1hour and 20 minutes long and have manged to get the export time down to 30-40minutes
I have always been trying to figuring out how to get faster exporting times for a long time now, is it dependant on the sequance settings as well?
    Feb 15, 2014 11:11 AM   in reply to Jason Jamie
    Feb 15, 2014 11:38 AM   in reply to Jason Jamie
    There are really only three things you can do to decrease export times without changing the final export itself.
    1. Get a faster CPU.
    2. Enable GPU acceleration.
    3. Don't check the Maximum Render Quality box for export.
    Feb 15, 2014 11:57 AM   in reply to Jason Jamie
    File>Project Settings>General...for a direct Export.  There is a visible 'switch' in AME if you Queue the export, at the bottom right of the Queue panel.
    Feb 15, 2014 12:12 PM   in reply to Jason Jamie
    Then you're left with options 1 and 3 for the moment.
    Adding an nVidia card with 1GB of onboard memory should allow 2 as well.
    Feb 15, 2014 12:19 PM   in reply to Jason Jamie
    Actually I see OpenCL is now available for Windows.  What card model do you have?  (You only listed the chip.)
    Feb 15, 2014 12:27 PM   in reply to Jason Jamie
    r9 290
    That's the chip used in the card.  What's the card model?  Radeon HD XXXX?  FirePro VXXXX?  Something else?
    Feb 15, 2014 2:18 PM   in reply to Jason Jamie
    >Where could I find that? I'm a bit unsure sorry
    Windows Control Panel -- Hardware and Sound -- Device Manager -- Display Adapters
    Feb 15, 2014 2:52 PM   in reply to Jason Jamie
    Try the box the card came in.
    Feb 15, 2014 2:53 PM   in reply to Jason Jamie
    Is it th M200? Sound fimilar?
    It doesn't.
    What version of Premiere Pro?
    If not PProCC your options for hardware acceleration are somewhat limited
    History of MINIMUM requirements from CS3 to Cloud
    http://helpx.adobe.com/x-productkb/policy-pricing/system-requirements- premiere-pro.html
    Feb 15, 2014 5:19 PM   in reply to Jason Jamie
    Ahhhh, there it is.  I tend to assume CC.  John's point is valid in that OpenCL for Windows was not available until CC, so yes, you're stuck with nVidia if you want option 2.
    Feb 15, 2014 6:11 PM   in reply to Jason Jamie
    not really...I'm exporting 13 min. of editing, gopro and P2 AVCIntra 100 footage...A lot of video matching, resizing and noise remover...
    Exporting time to a quicktime 1980X1080, 29,97 fps, progressive, quality 100, H264 bitrate 10Mbps ?
    Answer : 3hrs 40 min.
    CPU intel i7-3610QM
    NVIDIA GeForce GTX 670M/3GB GDDR5
    RAM: 12GB DDR3
    and i got cuda/open cl.
    Feb 16, 2014 7:49 AM   in reply to Jason Jamie
    I think you are showing off.
    Thats not bad...especially considering we do not know f what  FX , plug ins or what you are Exporting from...to!
    [Text formatting corrected.]
    Message was edited by: Jim Simon
    Feb 15, 2014 11:52 PM   in reply to Jason Jamie
    llyodreade wrote:
    Ok so if i get CC i will get guaranteed faster export times?
    No. See Tweakers Page - What video card to use? and especially the link to Tweakers Page - Exporting Style
    Feb 16, 2014 7:48 AM   in reply to Jason Jamie
    Not guaranteed.  Hardware acceleration only speeds up certain things.  If you're not using any of those things, you won't see any benefit.
    But the possibility for faster times would exist.
