Using logged user detail from one table ,then use another table to link more details for same user ?
Feb 17, 2014 2:45 PM
Table 'user' fields:
UserID* (Primary Key)
Address
FirstName
LastName
Email
UserName
Password
UserLevel
RegDate
Table 'transaction' fields:
transactionID* (Primary Key)
MonthID
UserID (Foreign Key)
UserName
transactionDate
transactionType
transactionAmount
OpeningBalance
Balance
Desired output table (for the logged user):
transactionDate
transactionType
transactionAmount
OpeningBalance
Balance
My advance recordset details is like this :
<?php
if (!function_exists("GetSQLValueString")) {
function GetSQLValueString($theValue, $theType, $theDefinedValue = "", $theNotDefinedValue = "")
if (PHP_VERSION < 6) {
$theValue = get_magic_quotes_gpc() ? stripslashes($theValue) : $theValue;
$theValue = function_exists("mysql_real_escape_string") ? mysql_real_escape_string($theValue) : mysql_escape_string($theValue);
switch ($theType) {
case "text":
$theValue = ($theValue != "") ? "'" . $theValue . "'" : "NULL";
break;
case "long":
case "int":
$theValue = ($theValue != "") ? intval($theValue) : "NULL";
break;
case "double":
$theValue = ($theValue != "") ? doubleval($theValue) : "NULL";
break;
case "date":
break;
case "defined":
$theValue = ($theValue != "") ? $theDefinedValue : $theNotDefinedValue;
break;
return $theValue;
mysql_select_db($database_bankusers, $bankusers);
$query_Recordset1 = "SELECT transactions.UserName, transactions.transactionDate, transactions.transactionType, transactions.transactionAmount, transactions.OpeningBalance, transactions.EndBalance, users.FirstName, transactions.transactionID FROM transactions, users WHERE users.UserName = transactions.UserName ORDER BY transactions.UserName, transactions.transactionID DESC";
$Recordset1 = mysql_query($query_Recordset1, $bankusers) or die(mysql_error());
$row_Recordset1 = mysql_fetch_assoc($Recordset1);
$totalRows_Recordset1 = mysql_num_rows($Recordset1);
This enables me to pull all the records from both tables but not specific to the logged user.
This is my problem. I would like the record to be pull is for the right user.
I am not sure if the the problem is to do with Session variable MM_UserName as I have no idea how to include it in the advanced recordset box but i am not sure there is no missing session start on this page.  Your help or suggestion will be much appreciated.
    Feb 17, 2014 3:03 PM   in reply to gurroby
    Try:
    $query_Recordset1 = "SELECT transactions.UserName, transactions.transactionDate, transactions.transactionType, transactions.transactionAmount, transactions.OpeningBalance, transactions.EndBalance, users.FirstName, transactions.transactionID FROM transactions, users WHERE users.UserName = transactions.UserName AND users.UserName = $MM_UserName ORDER BY transactions.UserName, transactions.transactionID DESC";
    Feb 17, 2014 3:38 PM   in reply to gurroby
    Sorry, my bad. Try:
    $query_Recordset1 = "SELECT transactions.UserName, transactions.transactionDate, transactions.transactionType, transactions.transactionAmount, transactions.OpeningBalance, transactions.EndBalance, users.FirstName, transactions.transactionID FROM transactions, users WHERE users.UserName = transactions.UserName AND users.UserName = $_SESSION['MM_Username']) ORDER BY transactions.UserName, transactions.transactionID DESC";
    Feb 17, 2014 5:17 PM   in reply to gurroby
    No parens around the session variable name:
    $query_Recordset1 = "SELECT transactions.UserName, transactions.transactionDate, transactions.transactionType, transactions.transactionAmount, transactions.OpeningBalance, transactions.EndBalance, users.FirstName, transactions.transactionID FROM transactions, users WHERE users.UserName = transactions.UserName AND users.UserName = $_SESSION['MM_Username'] ORDER BY transactions.UserName, transactions.transactionID DESC";
