Pavan_Neeli
Adobe Flex 3, unable to check existing XML nodes
Feb 18, 2014 4:37 AM
Tags: #flex #3
I am getting an XML data from server(Pls refer xmlData value). I need to: i. Create another XML with non-duplicates Folders ii. Create another XML with final count on monthly basis.
I am unable to do this with below code and getting duplicate records.
private var xmlData:XML = new XML("<root><SUMMARY_RECORD><FOLDER>Folder1</FOLDER><COUNT>100</COUNT><MONTH>Feb</MONTH><QUARTER>Q1</QUARTER><YEAR>2014</YEAR></SUMMARY_RECORD><SUMMARY_RECORD><FOLDER>Folder1</FOLDER><COUNT>100</COUNT><MONTH>Feb</MONTH><QUARTER>Q1</QUARTER><YEAR>2014</YEAR></SUMMARY_RECORD></root>");
var folderDataXML:XML = new XML("<root></root>");
var folderDGDataXML:XML = new XML("<root></root>");
private function loaded():void{
var item:XML;
        folderDGDataXML
.appendChild(new XML("<FOLDER_NAME><Name>ALL</Name></FOLDER_NAME>"));
for each (item in xmlData.SUMMARY_RECORD){
if (folderDGDataXML.FOLDER_NAME.(Name==item.FOLDER).toString() == ""){
                folderDGDataXML
.appendChild(new XML("<FOLDER_NAME><Name>"+item.FOLDER+"</Name></FOLDER_NAME>"));
if (folderDataXML.SUMMARY_RECORD.(Name==item.MONTH).toXMLString() == ""){
                folderDataXML
.appendChild(new XML("<SUMMARY_RECORD><Name>"+item.MONTH+"</Name><COUNT>"+item.COUNT+"</COUNT></SUMMARY_RECORD>"));
}else{
var count:int = Number(folderDataXML.SUMMARY_RECORD.(Name==item.MONTH).COUNT) + Number(item.COUNT);
                folderDataXML
.SUMMARY_RECORD.(Name==item.MONTH).COUNT = count;
Final output:
folderDGDataXML
<root>
<FOLDER_NAME>
<Name>ALL</Name>
</FOLDER_NAME>
<FOLDER_NAME>
<Name>Folder1</Name>
</FOLDER_NAME>
<FOLDER_NAME>
</FOLDER_NAME>
</root>
folderDataXML
<root>
<SUMMARY_RECORD>
<Name>Feb</Name>
<COUNT>100</COUNT>
</SUMMARY_RECORD>
<SUMMARY_RECORD>
<Name>Feb</Name>
<COUNT>100</COUNT>
</SUMMARY_RECORD>
</root>
Can you please help me where I am doing wrong? After getting correct XML, I need to populate datagrid & column chart.
Thanks in advance for the help.
Regards
Pavan
    Feb 18, 2014 9:17 AM   in reply to Pavan_Neeli
    Most loops that eliminate duplicates keep a list/map of the data that has already been processed and compares the loop value against that.
    In ActionScript, it is more efficient to use a map which is usually a plain object.
    var alreadySeenFolders:Map = {};
    In the loop you compare:
        var folderName:String = item.FOLDER.toString();
        if (alreadySeenFolders[folderName] == 1)
            continue; // was already in map
        alreadySeenFolders[folderName] = 1; // store it in map
