I've created a package with CCP Launcher. The build log looks good but when I try to install it fails. I get an icon in control panel that look like this:
PDApp.log
02/19/14 10:15:29:673 | [INFO] | | ASU | MSIInvoker | MSIInvoker | | | 2584 | Build Version - 1.4.0.37
02/19/14 10:15:29:673 | [INFO] | | ASU | MSIInvoker | MSIInvoker | | | 2584 | Logging Level verbosity Set to 4
02/19/14 10:15:30:390 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 3472 | Build Version - 1.4.0.37
02/19/14 10:15:30:390 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 3472 | Logging Level verbosity Set to 4
02/19/14 10:15:30:390 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 3472 | Executing immediate custom action for install mode.
02/19/14 10:15:30:390 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 3472 | The CustomActionData string is : mode=install;sourceDir=C:\temp\acroproxi32bit\Build\;installDir=;origDB=C:\temp\acroproxi32bit\Build\acroproxi32bit.msi
02/19/14 10:15:30:390 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 3472 | Successfully executed the immediate custom action for install mode .
02/19/14 10:15:33:089 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 1968 | Build Version - 1.4.0.37
02/19/14 10:15:33:089 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 1968 | Logging Level verbosity Set to 4
02/19/14 10:15:33:089 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 1968 | Executing the deferred custom action.
02/19/14 10:15:33:089 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 1968 | Obtained the following as CustomActionData
02/19/14 10:15:33:089 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 1968 | mode=install;sourceDir=C:\temp\acroproxi32bit\Build\;installDir=;origDB=C:\temp\acroproxi32bit\Build\acroproxi32bit.msi
02/19/14 10:15:33:089 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 1968 | Original database path is : C:\temp\acroproxi32bit\Build\acroproxi32bit.msi
02/19/14 10:15:33:120 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 1968 | OptionXML saved at location :: C:\Users\jowi\AppData\Local\Temp\{2236AB8C-F822-4E94-85A1-C7C76C1263A4}\\{ECA212C4-284B-42FD-93DA-BC16FEAAA103}
02/19/14 10:15:33:198 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 1968 | Build Version - 1.4.0.37
02/19/14 10:15:33:198 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 1968 | Logging Level verbosity Set to 4
02/19/14 10:15:33:198 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 1968 | Initializing Custom Action Data from parameters
02/19/14 10:15:33:198 | [INFO] | | ASU | DeploymentManager | Utilities | | | 1968 | Folder does not exist
02/19/14 10:15:33:198 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 1968 | Provisioning Tool path is (C:\Users\jowi\AppData\Local\Temp\{2236AB8C-F822-4E94-85A1-C7C76C1263A4}\\{66697E0F-16F3-4734-916D-55867E925B56}).
02/19/14 10:15:33:198 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 1968 | Starting to run the custom action for install mode
02/19/14 10:15:33:198 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 1968 | STEP 1: Starting to parse Option XML.
02/19/14 10:15:33:198 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 1968 | Self-Update BootStrapper Relative Path doesn't exist.
02/19/14 10:15:33:198 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 1968 | No of updates found (0).
02/19/14 10:15:33:339 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 1968 | Number of Medias found = 1
02/19/14 10:15:33:339 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 1968 | Deployment Manager is running in Install Mode.
02/19/14 10:15:33:370 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 1968 | Deployment XML created at path :: C:\Users\jowi\AppData\Local\Temp\{D77454E9-5AD3-4DD3-8C1E-E3660BF50140}\\{42CE3F50-DCB9-4E99-A2FE-85BAC02B65CB}
02/19/14 10:15:33:401 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 1968 | Override XML created at path :: C:\Users\jowi\AppData\Local\Temp\{D77454E9-5AD3-4DD3-8C1E-E3660BF50140}\\{088CF7FE-E941-4964-B2D1-EFCE4F213F2A}
02/19/14 10:15:33:417 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 1968 | STEP 2: Starting to launch ASU AAM.
02/19/14 10:15:33:417 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 1968 | Bootstrapper launch location is :: C:\temp\acroproxi32bit\Build\ASU\Set-up.dat
02/19/14 10:15:33:573 | [INFO] | | ASU | Setup | Setup | | | 1696 | Logging Level verbosity Set to 4
02/19/14 10:15:33:573 | [INFO] | | ASU | Setup | Setup | | | 1696 | Start Adobe Setup
02/19/14 10:15:33:573 | [INFO] | | ASU | Setup | Setup | | | 1696 | TimeLog: Bootstrapper Start
02/19/14 10:15:33:573 | [INFO] | | ASU | Setup | Setup | | | 1696 | TimeLog: Start initial checks
02/19/14 10:15:33:573 | [INFO] | | ASU | Setup | Utilities | | | 1696 | File 'C:\Program Files\Common Files\Adobe\OOBE\PDApp\\core\AAMConfig.xml' does not exist
02/19/14 10:15:33:588 | [INFO] | | ASU | Setup | Setup | | | 1696 | OS Bitness is: 32
02/19/14 10:15:33:588 | [INFO] | | ASU | Setup | Setup | | | 1696 | Action specified - "install"
02/19/14 10:15:33:588 | [INFO] | | ASU | Setup | Setup | | | 1696 | Skipping ACCC packages as --skipACC=1 command was specified
02/19/14 10:15:33:588 | [INFO] | | ASU | Setup | | | | 1696 | Event Guid generated is: '1c064663-0dc3-4259-887e-ed7ee714efb2'
02/19/14 10:15:33:604 | [INFO] | | ASU | Setup | PIM | | | 1696 | XML is valid
02/19/14 10:15:33:604 | [WARN] | | ASU | Setup | PIM | | | 1696 | Failed to find Node
02/19/14 10:15:33:604 | [INFO] | | ASU | Setup | | | | 2912 | Event with guid '1c064663-0dc3-4259-887e-ed7ee714efb2' is being sent
02/19/14 10:15:33:620 | [INFO] | | ASU | Setup | | | | 2912 | GetIEProxyInfo - No default proxy present on the user machine
02/19/14 10:15:33:620 | [INFO] | | ASU | Setup | | | | 2912 | GetIEProxyInfo - proxy Url is
02/19/14 10:15:33:682 | [INFO] | | ASU | Setup | PIM | | | 1696 | XML is valid
02/19/14 10:15:33:698 | [INFO] | | ASU | PIM | PIM | | | 1696 | Build Version - 2.0.0.0 (BuildVersion: 2.0; BuildDate: Mon Jun 18 2012 06:00:16 )
02/19/14 10:15:33:698 | [INFO] | | ASU | PIM | PIM | | | 1696 | Logging Level verbosity Set to 4
02/19/14 10:15:33:698 | [INFO] | | ASU | PIM | Utilities | | | 1696 | File 'C:\Program Files\Common Files\Adobe\OOBE\PDApp\\pim.db-journal' does not exist
02/19/14 10:15:33:698 | [INFO] | | ASU | PIM | Utilities | | | 1696 | File 'C:\Users\jowi\AppData\Local\Temp\\asuap.txt' does not exist
02/19/14 10:15:33:698 | [INFO] | | ASU | PIM | PIM | | | 1696 | CREATE PIM Instance ...
02/19/14 10:15:33:713 | [INFO] | | ASU | PIM | Utilities | | | 1696 | File 'C:\Program Files\Common Files\Adobe\OOBE\PDApp\pim.db-journal' does not exist
02/19/14 10:15:33:713 | [INFO] | | ASU | PIM | Utilities | | | 1696 | File 'C:\Program Files\Common Files\Adobe\OOBE\PDApp\pim.db' does not exist
02/19/14 10:15:33:729 | [INFO] | | ASU | PIM | PIM | | | 1696 | trying to createOrUpdatePIMDbSchema.
02/19/14 10:15:33:807 | [INFO] | | ASU | PIM | PIM | | | 1696 | SUCCESS Created Tables.
02/19/14 10:15:33:807 | [INFO] | | ASU | PIM | PIM | | | 1696 | PIM Database is Up To Date.
02/19/14 10:15:33:807 | [INFO] | | ASU | PIM | PIM | | | 1696 | Updater Inventory location:C:\temp\acroproxi32bit\Build\ASU\resources\updaterinventory.dll
02/19/14 10:15:33:822 | [INFO] | | ASU | PIM | PIM | | | 1696 | Acquired System level ACF lock ...
02/19/14 10:15:33:822 | [INFO] | | ASU | PIM | PIM | | | 1696 | Build Version - 2.0.0.0 (BuildVersion: 2.0; BuildDate: Mon Jun 18 2012 06:00:16 )
02/19/14 10:15:33:822 | [INFO] | | ASU | PIM | PIM | | | 1696 | Logging Level verbosity Set to 4
02/19/14 10:15:33:822 | [INFO] | | ASU | PIM | Utilities | | | 1696 | File 'C:\Program Files\Adobe\Adobe Creative Cloud\pim.db-journal' does not exist
02/19/14 10:15:33:822 | [INFO] | | ASU | PIM | PIM | | | 1696 | CREATE PIM Instance ...
02/19/14 10:15:33:838 | [INFO] | | ASU | PIM | Utilities | | | 1696 | File 'C:\Program Files\Adobe\Adobe Creative Cloud\pim.db-journal' does not exist
02/19/14 10:15:33:838 | [INFO] | | ASU | PIM | Utilities | | | 1696 | File 'C:\Program Files\Adobe\Adobe Creative Cloud\pim.db' does not exist
02/19/14 10:15:33:838 | [INFO] | | ASU | PIM | PIM | | | 1696 | trying to createOrUpdatePIMDbSchema.
02/19/14 10:15:33:900 | [INFO] | | ASU | PIM | PIM | | | 1696 | SUCCESS Created Tables.
02/19/14 10:15:33:900 | [INFO] | | ASU | PIM | PIM | | | 1696 | PIM Database is Up To Date.
02/19/14 10:15:33:900 | [INFO] | | ASU | PIM | PIM | | | 1696 | Updater Inventory location:C:\temp\acroproxi32bit\Build\ASU\resources\updaterinventory.dll
02/19/14 10:15:33:900 | [INFO] | | ASU | PIM | PIM | | | 1696 | Acquired System level ACCC lock ...
02/19/14 10:15:33:900 | [INFO] | | ASU | PIM | PIM | | | 1696 | Current OS version is: Major:6, Minor:1, ServicePack:1
02/19/14 10:15:33:900 | [INFO] | | ASU | PIM | PIM | | | 1696 | Skip properties not defined for current node
02/19/14 10:15:33:916 | [INFO] | | ASU | PIM | PIM | | | 1696 | Skip properties not defined for current node
02/19/14 10:15:33:947 | [INFO] | | ASU | PIM | PIM | | | 1696 | XML is valid
02/19/14 10:15:33:947 | [WARN] | | ASU | PIM | PIM | | | 1696 | Failed to find Node
02/19/14 10:15:34:072 | [INFO] | | ASU | PIM | PIM | | | 1696 | XML is valid
02/19/14 10:15:34:072 | [WARN] | | ASU | PIM | PIM | | | 1696 | Failed to find Node
02/19/14 10:15:34:119 | [INFO] | | ASU | PIM | PIM | | | 1696 | XML is valid
02/19/14 10:15:34:119 | [WARN] | | ASU | PIM | PIM | | | 1696 | Failed to find Node
02/19/14 10:15:34:166 | [INFO] | | ASU | PIM | PIM | | | 1696 | XML is valid
02/19/14 10:15:34:166 | [WARN] | | ASU | PIM | PIM | | | 1696 | Failed to find Node
02/19/14 10:15:34:197 | [INFO] | | ASU | PIM | PIM | | | 1696 | XML is valid
02/19/14 10:15:34:197 | [WARN] | | ASU | PIM | PIM | | | 1696 | Failed to find Node
02/19/14 10:15:34:259 | [INFO] | | ASU | PIM | PIM | | | 1696 | XML is valid
02/19/14 10:15:34:259 | [WARN] | | ASU | PIM | PIM | | | 1696 | Failed to find Node
02/19/14 10:15:34:275 | [INFO] | | ASU | PIM | PIM | | | 1696 | XML is valid
02/19/14 10:15:34:275 | [WARN] | | ASU | PIM | PIM | | | 1696 | Failed to find Node
02/19/14 10:15:34:322 | [INFO] | | ASU | Setup | | | | 1040 | HTTP Request Status code 200.
02/19/14 10:15:34:322 | [INFO] | | ASU | Setup | | | | 2912 | The http request returned HTTP_Status:0 HttpCommunicator error:0
02/19/14 10:15:34:353 | [INFO] | | ASU | PIM | PIM | | | 1696 | XML is valid
02/19/14 10:15:34:353 | [INFO] | | ASU | PIM | PIM | | | 1696 | Current OS version is: Major:6, Minor:1, ServicePack:1
02/19/14 10:15:34:353 | [WARN] | | ASU | PIM | PIM | | | 1696 | Failed to find Node
02/19/14 10:15:34:400 | [WARN] | | ASU | PIM | PIM | | | 1696 | Failed to find Node
02/19/14 10:15:34:415 | [INFO] | | ASU | PIM | PIM | | | 1696 | XML is valid
02/19/14 10:15:34:415 | [WARN] | | ASU | PIM | PIM | | | 1696 | Failed to find Node
02/19/14 10:15:34:431 | [INFO] | | ASU | PIM | PIM | | | 1696 | XML is valid
02/19/14 10:15:34:431 | [WARN] | | ASU | PIM | PIM | | | 1696 | Failed to find Node
02/19/14 10:15:34:431 | [INFO] | | ASU | PIM | PIM | | | 1696 | pim_haveEnoughDiskSpaceToInstallPackages reqSize ... 130318303
02/19/14 10:15:34:431 | [INFO] | | ASU | PIM | PIM | | | 1696 | The size required to install AAM on your machine would be 130318303
02/19/14 10:15:34:431 | [INFO] | | ASU | PIM | PIM | | | 1696 | Current OS version is: Major:6, Minor:1, ServicePack:1
02/19/14 10:15:34:431 | [INFO] | | ASU | PIM | PIM | | | 1696 | Skip properties not defined for current node
02/19/14 10:15:34:446 | [INFO] | | ASU | PIM | PIM | | | 1696 | XML is valid
02/19/14 10:15:34:446 | [INFO] | | ASU | PIM | PIM | | | 1696 | Current OS version is: Major:6, Minor:1, ServicePack:1
02/19/14 10:15:34:446 | [WARN] | | ASU | PIM | PIM | | | 1696 | Failed to find Node
02/19/14 10:15:34:462 | [INFO] | | ASU | PIM | PIM | | | 1696 | XML is valid
02/19/14 10:15:34:462 | [INFO] | | ASU | PIM | PIM | | | 1696 | Current OS version is: Major:6, Minor:1, ServicePack:1
02/19/14 10:15:34:462 | [WARN] | | ASU | PIM | PIM | | | 1696 | Failed to find Node
02/19/14 10:15:34:478 | [INFO] | | ASU | PIM | PIM | | | 1696 | XML is valid
02/19/14 10:15:34:478 | [INFO] | | ASU | PIM | PIM | | | 1696 | Current OS version is: Major:6, Minor:1, ServicePack:1
02/19/14 10:15:34:478 | [WARN] | | ASU | PIM | PIM | | | 1696 | Failed to find Node
02/19/14 10:15:34:493 | [INFO] | | ASU | PIM | PIM | | | 1696 | XML is valid
02/19/14 10:15:34:493 | [INFO] | | ASU | PIM | PIM | | | 1696 | Current OS version is: Major:6, Minor:1, ServicePack:1
02/19/14 10:15:34:493 | [WARN] | | ASU | PIM | PIM | | | 1696 | Failed to find Node
02/19/14 10:15:34:509 | [INFO] | | ASU | PIM | PIM | | | 1696 | XML is valid
02/19/14 10:15:34:509 | [INFO] | | ASU | PIM | PIM | | | 1696 | Current OS version is: Major:6, Minor:1, ServicePack:1
02/19/14 10:15:34:509 | [WARN] | | ASU | PIM | PIM | | | 1696 | Failed to find Node
02/19/14 10:15:34:524 | [INFO] | | ASU | PIM | PIM | | | 1696 | XML is valid
02/19/14 10:15:34:524 | [INFO] | | ASU | PIM | PIM | | | 1696 | Current OS version is: Major:6, Minor:1, ServicePack:1
02/19/14 10:15:34:524 | [WARN] | | ASU | PIM | PIM | | | 1696 | Failed to find Node
02/19/14 10:15:34:540 | [INFO] | | ASU | PIM | PIM | | | 1696 | XML is valid
02/19/14 10:15:34:540 | [INFO] | | ASU | PIM | PIM | | | 1696 | Current OS version is: Major:6, Minor:1, ServicePack:1
02/19/14 10:15:34:540 | [WARN] | | ASU | PIM | PIM | | | 1696 | Failed to find Node
02/19/14 10:15:34:556 | [INFO] | | ASU | PIM | PIM | | | 1696 | XML is valid
02/19/14 10:15:34:556 | [INFO] | | ASU | PIM | PIM | | | 1696 | Current OS version is: Major:6, Minor:1, ServicePack:1
02/19/14 10:15:34:556 | [WARN] | | ASU | PIM | PIM | | | 1696 | Failed to find Node
02/19/14 10:15:34:571 | [INFO] | | ASU | PIM | PIM | | | 1696 | XML is valid
02/19/14 10:15:34:571 | [INFO] | | ASU | PIM | PIM | | | 1696 | Current OS version is: Major:6, Minor:1, ServicePack:1
02/19/14 10:15:34:571 | [WARN] | | ASU | PIM | PIM | | | 1696 | Failed to find Node
02/19/14 10:15:34:587 | [INFO] | | ASU | PIM | PIM | | | 1696 | XML is valid
02/19/14 10:15:34:587 | [INFO] | | ASU | PIM | PIM | | | 1696 | Current OS version is: Major:6, Minor:1, ServicePack:1
02/19/14 10:15:34:587 | [WARN] | | ASU | PIM | PIM | | | 1696 | Failed to find Node
02/19/14 10:15:34:602 | [WARN] | | ASU | PIM | PIM | | | 1696 | Failed to find Node
02/19/14 10:15:34:602 | [INFO] | | ASU | PIM | PIM | | | 1696 | XML is valid
02/19/14 10:15:34:602 | [INFO] | | ASU | PIM | PIM | | | 1696 | Current OS version is: Major:6, Minor:1, ServicePack:1
02/19/14 10:15:34:618 | [WARN] | | ASU | PIM | PIM | | | 1696 | Failed to find Node
02/19/14 10:15:34:618 | [INFO] | | ASU | PIM | PIM | | | 1696 | XML is valid
02/19/14 10:15:34:618 | [INFO] | | ASU | PIM | PIM | | | 1696 | Current OS version is: Major:6, Minor:1, ServicePack:1
02/19/14 10:15:34:634 | [INFO] | | ASU | PIM | PIM | | | 1696 | XML is valid
02/19/14 10:15:34:634 | [INFO] | | ASU | PIM | PIM | | | 1696 | Current OS version is: Major:6, Minor:1, ServicePack:1
02/19/14 10:15:34:634 | [WARN] | | ASU | PIM | PIM | | | 1696 | Failed to find Node
02/19/14 10:15:34:649 | [INFO] | | ASU | PIM | PIM | | | 1696 | XML is valid
02/19/14 10:15:34:649 | [INFO] | | ASU | PIM | PIM | | | 1696 | Current OS version is: Major:6, Minor:1, ServicePack:1
02/19/14 10:15:34:649 | [WARN] | | ASU | PIM | PIM | | | 1696 | Failed to find Node
02/19/14 10:15:34:649 | [INFO] | | ASU | PIM | PIM | | | 1696 | pim_haveEnoughDiskSpaceToInstallPackages reqSize ... 190388759
02/19/14 10:15:34:649 | [INFO] | | ASU | PIM | PIM | | | 1696 | The size required to install ACCC on your machine would be 190388759
02/19/14 10:15:34:649 | [INFO] | | ASU | PIM | PIM | | | 1696 | The size required to install complete ACCC on your machine would be 320707062
02/19/14 10:15:34:649 | [INFO] | | ASU | PIM | PIM | | | 1696 | PIMSqlite closeDB status 0
02/19/14 10:15:34:649 | [INFO] | | ASU | PIM | PIM | | | 1696 | FREE PIM Instance ...
02/19/14 10:15:34:649 | [INFO] | | ASU | Setup | Utilities | | | 1696 | Semaphore is not locked
02/19/14 10:15:34:649 | [INFO] | | ASU | PIM | PIM | | | 1696 | Build Version - 2.0.0.0 (BuildVersion: 2.0; BuildDate: Mon Jun 18 2012 06:00:16 )
02/19/14 10:15:34:649 | [INFO] | | ASU | PIM | PIM | | | 1696 | Logging Level verbosity Set to 4
02/19/14 10:15:34:649 | [INFO] | | ASU | PIM | Utilities | | | 1696 | File 'C:\Program Files\Common Files\Adobe\OOBE\PDApp\\pim.db-journal' does not exist
02/19/14 10:15:34:649 | [INFO] | | ASU | PIM | Utilities | | | 1696 | File 'C:\Users\jowi\AppData\Local\Temp\\asuap.txt' does not exist
02/19/14 10:15:34:649 | [INFO] | | ASU | PIM | PIM | | | 1696 | CREATE PIM Instance ...
02/19/14 10:15:34:649 | [INFO] | | ASU | PIM | Utilities | | | 1696 | File 'C:\Program Files\Common Files\Adobe\OOBE\PDApp\pim.db-journal' does not exist
02/19/14 10:15:34:649 | [INFO] | | ASU | PIM | Utilities | | | 1696 | File 'C:\Program Files\Common Files\Adobe\OOBE\PDApp\pim.db' does not exist
02/19/14 10:15:34:649 | [INFO] | | ASU | PIM | PIM | | | 1696 | trying to createOrUpdatePIMDbSchema.
02/19/14 10:15:34:852 | [INFO] | | ASU | PIM | PIM | | | 1696 | SUCCESS Created Tables.
02/19/14 10:15:34:852 | [INFO] | | ASU | PIM | PIM | | | 1696 | PIM Database is Up To Date.
02/19/14 10:15:34:852 | [INFO] | | ASU | PIM | PIM | | | 1696 | Updater Inventory location:C:\temp\acroproxi32bit\Build\ASU\resources\updaterinventory.dll
02/19/14 10:15:34:868 | [INFO] | | ASU | PIM | PIM | | | 1696 | Acquired System level ACF lock ...
02/19/14 10:15:34:868 | [INFO] | | ASU | Setup | Setup | | | 1696 | TimeLog: End initial checks
02/19/14 10:15:34:868 | [INFO] | | ASU | Setup | Setup | | | 1696 | TimeLog: Begin Installing
02/19/14 10:15:34:868 | [INFO] | | ASU | Setup | PIM | | | 1696 | XML is valid
02/19/14 10:15:34:868 | [INFO] | | ASU | PIM | PIM | | | 1696 | Current OS version is: Major:6, Minor:1, ServicePack:1
02/19/14 10:15:34:868 | [INFO] | | ASU | PIM | PIM | | | 1696 | Skip properties not defined for current node
02/19/14 10:15:34:868 | [INFO] | | ASU | PIM | PIM | | | 1696 | XML is valid
02/19/14 10:15:34:883 | [WARN] | | ASU | PIM | PIM | | | 1696 | Failed to find Node
02/19/14 10:15:34:977 | [INFO] | | ASU | PIM | PIM | | | 1696 | XML is valid
02/19/14 10:15:34:977 | [WARN] | | ASU | PIM | PIM | | | 1696 | Failed to find Node
02/19/14 10:15:35:008 | [INFO] | | ASU | PIM | PIM | | | 1696 | XML is valid
02/19/14 10:15:35:008 | [WARN] | | ASU | PIM | PIM | | | 1696 | Failed to find Node
02/19/14 10:15:35:039 | [INFO] | | ASU | PIM | PIM | | | 1696 | XML is valid
02/19/14 10:15:35:039 | [WARN] | | ASU | PIM | PIM | | | 1696 | Failed to find Node
02/19/14 10:15:35:055 | [INFO] | | ASU | PIM | PIM | | | 1696 | XML is valid
02/19/14 10:15:35:070 | [WARN] | | ASU | PIM | PIM | | | 1696 | Failed to find Node
02/19/14 10:15:35:102 | [INFO] | | ASU | PIM | PIM | | | 1696 | XML is valid
02/19/14 10:15:35:102 | [WARN] | | ASU | PIM | PIM | | | 1696 | Failed to find Node
02/19/14 10:15:35:117 | [INFO] | | ASU | PIM | PIM | | | 1696 | XML is valid
02/19/14 10:15:35:117 | [WARN] | | ASU | PIM | PIM | | | 1696 | Failed to find Node
02/19/14 10:15:35:180 | [INFO] | | ASU | PIM | PIM | | | 1696 | XML is valid
02/19/14 10:15:35:180 | [INFO] | | ASU | PIM | PIM | | | 1696 | Current OS version is: Major:6, Minor:1, ServicePack:1
02/19/14 10:15:35:180 | [WARN] | | ASU | PIM | PIM | | | 1696 | Failed to find Node
02/19/14 10:15:35:226 | [WARN] | | ASU | PIM | PIM | | | 1696 | Failed to find Node
02/19/14 10:15:35:242 | [INFO] | | ASU | PIM | PIM | | | 1696 | XML is valid
02/19/14 10:15:35:242 | [WARN] | | ASU | PIM | PIM | | | 1696 | Failed to find Node
02/19/14 10:15:35:242 | [INFO] | | ASU | PIM | PIM | | | 1696 | pim_haveEnoughDiskSpaceToInstallPackages reqSize ... 130318303
02/19/14 10:15:35:242 | [INFO] | | ASU | PIM | PIM | | | 1696 | Executing Adobe Genuine Validation for all the AAM packages
02/19/14 10:15:35:242 | [INFO] | | ASU | PIM | PIM | | | 1696 | Validating package file: 'C:\temp\acroproxi32bit\Build\ASU\AAMPackages\core\PDApp.pimx'
02/19/14 10:15:35:289 | [INFO] | | ASU | PIM | PIM | | | 1696 | Validating package file: 'C:\temp\acroproxi32bit\Build\ASU\AAMPackages\core\PDApp.pima'
02/19/14 10:15:35:414 | [INFO] | | ASU | PIM | PIM | | | 1696 | Validating package file: 'C:\temp\acroproxi32bit\Build\ASU\AAMPackages\D6\D6.pimx'
02/19/14 10:15:35:429 | [INFO] | | ASU | PIM | PIM | | | 1696 | XML is valid
02/19/14 10:15:35:429 | [WARN] | | ASU | PIM | PIM | | | 1696 | Failed to find Node
02/19/14 10:15:35:445 | [INFO] | | ASU | PIM | PIM | | | 1696 | Validating package file: 'C:\temp\acroproxi32bit\Build\ASU\AAMPackages\D6\D6.pima'
02/19/14 10:15:35:492 | [INFO] | | ASU | PIM | PIM | | | 1696 | Validating package file: 'C:\temp\acroproxi32bit\Build\ASU\AAMPackages\DECore\DECore.pimx'
02/19/14 10:15:35:507 | [INFO] | | ASU | PIM | PIM | | | 1696 | XML is valid
02/19/14 10:15:35:507 | [WARN] | | ASU | PIM | PIM | | | 1696 | Failed to find Node
02/19/14 10:15:35:507 | [INFO] | | ASU | PIM | PIM | | | 1696 | Validating package file: 'C:\temp\acroproxi32bit\Build\ASU\AAMPackages\DECore\DECore.pima'
02/19/14 10:15:35:694 | [INFO] | | ASU | PIM | PIM | | | 1696 | Validating package file: 'C:\temp\acroproxi32bit\Build\ASU\AAMPackages\DWA\DWA.pimx'
02/19/14 10:15:35:694 | [INFO] | | ASU | PIM | PIM | | | 1696 | XML is valid
02/19/14 10:15:35:694 | [WARN] | | ASU | PIM | PIM | | | 1696 | Failed to find Node
02/19/14 10:15:35:710 | [INFO] | | ASU | PIM | PIM | | | 1696 | Validating package file: 'C:\temp\acroproxi32bit\Build\ASU\AAMPackages\DWA\DWA.pima'
02/19/14 10:15:35:772 | [INFO] | | ASU | PIM | PIM | | | 1696 | Validating package file: 'C:\temp\acroproxi32bit\Build\ASU\AAMPackages\P6\P6.pimx'
02/19/14 10:15:35:772 | [INFO] | | ASU | PIM | PIM | | | 1696 | XML is valid
02/19/14 10:15:35:788 | [WARN] | | ASU | PIM | PIM | | | 1696 | Failed to find Node
02/19/14 10:15:35:788 | [INFO] | | ASU | PIM | PIM | | | 1696 | Validating package file: 'C:\temp\acroproxi32bit\Build\ASU\AAMPackages\P6\P6.pima'
02/19/14 10:15:35:913 | [INFO] | | ASU | PIM | PIM | | | 1696 | Validating package file: 'C:\temp\acroproxi32bit\Build\ASU\AAMPackages\LWA\LWA.pimx'
02/19/14 10:15:35:913 | [INFO] | | ASU | PIM | PIM | | | 1696 | XML is valid
02/19/14 10:15:35:913 | [WARN] | | ASU | PIM | PIM | | | 1696 | Failed to find Node
02/19/14 10:15:35:928 | [INFO] | | ASU | PIM | PIM | | | 1696 | Validating package file: 'C:\temp\acroproxi32bit\Build\ASU\AAMPackages\LWA\LWA.pima'
02/19/14 10:15:36:022 | [INFO] | | ASU | PIM | PIM | | | 1696 | Validating package file: 'C:\temp\acroproxi32bit\Build\ASU\AAMPackages\UWA\UWA.pimx'
02/19/14 10:15:36:038 | [INFO] | | ASU | PIM | PIM | | | 1696 | XML is valid
02/19/14 10:15:36:038 | [WARN] | | ASU | PIM | PIM | | | 1696 | Failed to find Node
02/19/14 10:15:36:038 | [INFO] | | ASU | PIM | PIM | | | 1696 | Validating package file: 'C:\temp\acroproxi32bit\Build\ASU\AAMPackages\UWA\UWA.pima'
02/19/14 10:15:36:350 | [INFO] | | ASU | PIM | PIM | | | 1696 | Validating package file: 'C:\temp\acroproxi32bit\Build\ASU\AAMPackages\CCM\CCM.pimx'
02/19/14 10:15:36:365 | [INFO] | | ASU | PIM | PIM | | | 1696 | XML is valid
02/19/14 10:15:36:365 | [INFO] | | ASU | PIM | PIM | | | 1696 | Current OS version is: Major:6, Minor:1, ServicePack:1
02/19/14 10:15:36:365 | [WARN] | | ASU | PIM | PIM | | | 1696 | Failed to find Node
02/19/14 10:15:36:381 | [INFO] | | ASU | PIM | PIM | | | 1696 | Validating package file: 'C:\temp\acroproxi32bit\Build\ASU\AAMPackages\CCM\CCM.pima'
02/19/14 10:15:36:381 | [INFO] | | ASU | PIM | PIM | | | 1696 | Validating package file: 'C:\temp\acroproxi32bit\Build\ASU\AAMPackages\P7\P7.pimx'
02/19/14 10:15:36:381 | [INFO] | | ASU | PIM | PIM | | | 1696 | XML is valid
02/19/14 10:15:36:381 | [WARN] | | ASU | PIM | PIM | | | 1696 | Failed to find Node
02/19/14 10:15:36:396 | [INFO] | | ASU | PIM | PIM | | | 1696 | Validating package file: 'C:\temp\acroproxi32bit\Build\ASU\AAMPackages\P7\P7.pima'
02/19/14 10:15:36:537 | [INFO] | | ASU | PIM | PIM | | | 1696 | Validating package file: 'C:\temp\acroproxi32bit\Build\ASU\AAMPackages\IPC\IPC.pimx'
02/19/14 10:15:36:537 | [INFO] | | ASU | PIM | PIM | | | 1696 | XML is valid
02/19/14 10:15:36:537 | [WARN] | | ASU | PIM | PIM | | | 1696 | Failed to find Node
02/19/14 10:15:36:552 | [INFO] | | ASU | PIM | PIM | | | 1696 | Validating package file: 'C:\temp\acroproxi32bit\Build\ASU\AAMPackages\IPC\IPC.pima'
02/19/14 10:15:36:568 | [INFO] | | ASU | PIM | PIM | | | 1696 | Adobe Genuine Validation PASSED for all the AAM packages
02/19/14 10:15:36:568 | [INFO] | | ASU | PIM | PIM | | | 1696 | START installPackage at file C:\temp\acroproxi32bit\Build\ASU\AAMPackages\core\PDApp.pimx
02/19/14 10:15:36:568 | [INFO] | | ASU | PIM | PIM | | | 1696 | XML is valid
02/19/14 10:15:36:568 | [WARN] | | ASU | PIM | PIM | | | 1696 | Failed to find Node
02/19/14 10:15:37:114 | [INFO] | | ASU | PIM | PIM | | | 1696 | SUCCESS insertPackageUpdateList.
02/19/14 10:15:37:114 | [WARN] | | ASU | PIM | PIM | | | 1696 | Failed to find Node
02/19/14 10:15:37:114 | [INFO] | | ASU | PIM | PIM | | | 1696 | SUCCESS insertAppletRegInfoList.
02/19/14 10:15:37:114 | [INFO] | | ASU | PIM | PIM | | | 1696 | SUCCESS insertAppletRelInfoList.
02/19/14 10:15:37:130 | [INFO] | | ASU | PIM | PIM | | | 1696 | XML is valid
02/19/14 10:15:37:130 | [WARN] | | ASU | PIM | PIM | | | 1696 | Failed to find Node
02/19/14 10:15:37:130 | [INFO] | | ASU | PIM | Utilities | | | 1696 | File 'C:\Program Files\Common Files\Adobe\OOBE\PDApp\\core' does not exist
02/19/14 10:15:37:785 | [INFO] | | ASU | PIM | Utilities | | | 1696 | File 'C:\Program Files\Common Files\Adobe\OOBE\PDApp\\core\PDApp.pimx' does not exist
02/19/14 10:15:38:128 | [INFO] | | ASU | PIM | PIM | | | 1696 | XML is valid
02/19/14 10:15:38:128 | [WARN] | | ASU | PIM | PIM | | | 1696 | Failed to find Node
02/19/14 10:15:38:144 | [INFO] | | ASU | PIM | PIM | | | 1696 | XML is valid
02/19/14 10:15:38:144 | [WARN] | | ASU | PIM | PIM | | | 1696 | Failed to find Node
02/19/14 10:15:38:144 | [INFO] | | ASU | PIM | PIM | | | 1696 | SUCCESS installPackage at file 'C:\temp\acroproxi32bit\Build\ASU\AAMPackages\core\PDApp.pimx'
02/19/14 10:15:38:268 | [INFO] | | ASU | PIM | PIM | | | 1696 | START installPackage at file C:\temp\acroproxi32bit\Build\ASU\AAMPackages\D6\D6.pimx
02/19/14 10:15:38:284 | [INFO] | | ASU | PIM | PIM | | | 1696 | XML is valid
02/19/14 10:15:38:284 | [WARN] | | ASU | PIM | PIM | | | 1696 | Failed to find Node
02/19/14 10:15:38:518 | [INFO] | | ASU | PIM | PIM | | | 1696 | SUCCESS insertPackageUpdateList.
02/19/14 10:15:38:518 | [WARN] | | ASU | PIM | PIM | | | 1696 | Failed to find Node
02/19/14 10:15:38:518 | [INFO] | | ASU | PIM | PIM | | | 1696 | SUCCESS insertAppletRegInfoList.
02/19/14 10:15:38:518 | [INFO] | | ASU | PIM | PIM | | | 1696 | SUCCESS insertAppletRelInfoList.
02/19/14 10:15:38:518 | [INFO] | | ASU | PIM | PIM | | | 1696 | XML is valid
02/19/14 10:15:38:518 | [INFO] | | ASU | PIM | Utilities | | | 1696 | File 'C:\Program Files\Common Files\Adobe\OOBE\PDApp\\D6' does not exist
02/19/14 10:15:38:752 | [INFO] | | ASU | PIM | Utilities | | | 1696 | File 'C:\Program Files\Common Files\Adobe\OOBE\PDApp\\D6\D6.pimx' does not exist
02/19/14 10:15:39:345 | [INFO] | | ASU | PIM | PIM | | | 1696 | XML is valid
02/19/14 10:15:39:345 | [WARN] | | ASU | PIM | PIM | | | 1696 | Failed to find Node
02/19/14 10:15:39:360 | [INFO] | | ASU | PIM | PIM | | | 1696 | XML is valid
02/19/14 10:15:39:360 | [WARN] | | ASU | PIM | PIM | | | 1696 | Failed to find Node
02/19/14 10:15:39:360 | [INFO] | | ASU | PIM | PIM | | | 1696 | SUCCESS installPackage at file 'C:\temp\acroproxi32bit\Build\ASU\AAMPackages\D6\D6.pimx'
02/19/14 10:15:39:501 | [INFO] | | ASU | PIM | PIM | | | 1696 | START installPackage at file C:\temp\acroproxi32bit\Build\ASU\AAMPackages\DECore\DECore.pimx
02/19/14 10:15:39:516 | [INFO] | | ASU | PIM | PIM | | | 1696 | XML is valid
02/19/14 10:15:39:516 | [WARN] | | ASU | PIM | PIM | | | 1696 | Failed to find Node
02/19/14 10:15:39:719 | [INFO] | | ASU | PIM | PIM | | | 1696 | SUCCESS insertPackageUpdateList.
02/19/14 10:15:39:719 | [WARN] | | ASU | PIM | PIM | | | 1696 | Failed to find Node
02/19/14 10:15:39:735 | [WARN] | | ASU | PIM | PIM | | | 1696 | Failed to find Node
02/19/14 10:15:39:735 | [INFO] | | ASU | PIM | PIM | | | 1696 | SUCCESS insertAppletRegInfoList.
02/19/14 10:15:39:735 | [INFO] | | ASU | PIM | PIM | | | 1696 | SUCCESS insertAppletRelInfoList.
02/19/14 10:15:39:735 | [INFO] | | ASU | PIM | PIM | | | 1696 | XML is valid
02/19/14 10:15:39:735 | [INFO] | | ASU | PIM | Utilities | | | 1696 | File 'C:\Program Files\Common Files\Adobe\OOBE\PDApp\\DECore' does not exist
02/19/14 10:15:40:281 | [INFO] | | ASU | PIM | Utilities | | | 1696 | File 'C:\Program Files\Common Files\Adobe\OOBE\PDApp\\DECore\DECore.pimx' does not exist
02/19/14 10:15:40:811 | [INFO] | | ASU | PIM | PIM | | | 1696 | XML is valid
02/19/14 10:15:40:811 | [WARN] | | ASU | PIM | PIM | | | 1696 | Failed to find Node
02/19/14 10:15:40:811 | [INFO] | | ASU | PIM | PIM | | | 1696 | SUCCESS installPackage at file 'C:\temp\acroproxi32bit\Build\ASU\AAMPackages\DECore\DECore.pimx'
02/19/14 10:15:41:373 | [INFO] | | ASU | PIM | PIM | | | 1696 | START installPackage at file C:\temp\acroproxi32bit\Build\ASU\AAMPackages\DWA\DWA.pimx
02/19/14 10:15:41:373 | [INFO] | | ASU | PIM | PIM | | | 1696 | XML is valid
02/19/14 10:15:41:373 | [WARN] | | ASU | PIM | PIM | | | 1696 | Failed to find Node
02/19/14 10:15:41:560 | [INFO] | | ASU | PIM | PIM | | | 1696 | SUCCESS insertPackageUpdateList.
02/19/14 10:15:41:560 | [WARN] | | ASU | PIM | PIM | | | 1696 | Failed to find Node
02/19/14 10:15:41:560 | [INFO] | | ASU | PIM | PIM | | | 1696 | SUCCESS insertAppletRegInfoList.
02/19/14 10:15:41:560 | [INFO] | | ASU | PIM | PIM | | | 1696 | SUCCESS insertAppletRelInfoList.
02/19/14 10:15:41:560 | [INFO] | | ASU | PIM | PIM | | | 1696 | XML is valid
02/19/14 10:15:41:560 | [INFO] | | ASU | PIM | Utilities | | | 1696 | File 'C:\Program Files\Common Files\Adobe\OOBE\PDApp\\DWA' does not exist
02/19/14 10:15:41:747 | [INFO] | | ASU | PIM | Utilities | | | 1696 | File 'C:\Program Files\Common Files\Adobe\OOBE\PDApp\\DWA\DWA.pimx' does not exist
02/19/14 10:15:42:153 | [INFO] | | ASU | PIM | PIM | | | 1696 | XML is valid
02/19/14 10:15:42:153 | [WARN] | | ASU | PIM | PIM | | | 1696 | Failed to find Node
02/19/14 10:15:42:168 | [INFO] | | ASU | PIM | PIM | | | 1696 | SUCCESS installPackage at file 'C:\temp\acroproxi32bit\Build\ASU\AAMPackages\DWA\DWA.pimx'
02/19/14 10:15:42:324 | [INFO] | | ASU | PIM | PIM | | | 1696 | START installPackage at file C:\temp\acroproxi32bit\Build\ASU\AAMPackages\P6\P6.pimx
02/19/14 10:15:42:324 | [INFO] | | ASU | PIM | PIM | | | 1696 | XML is valid
02/19/14 10:15:42:324 | [WARN] | | ASU | PIM | PIM | | | 1696 | Failed to find Node
02/19/14 10:15:42:574 | [INFO] | | ASU | PIM | PIM | | | 1696 | SUCCESS insertPackageUpdateList.
02/19/14 10:15:42:574 | [WARN] | | ASU | PIM | PIM | | | 1696 | Failed to find Node
02/19/14 10:15:42:574 | [INFO] | | ASU | PIM | PIM | | | 1696 | SUCCESS insertAppletRegInfoList.
02/19/14 10:15:42:590 | [WARN] | | ASU | PIM | PIM | | | 1696 | Failed to find Node
02/19/14 10:15:42:590 | [INFO] | | ASU | PIM | PIM | | | 1696 | SUCCESS insertAppletRelInfoList.
02/19/14 10:15:42:590 | [INFO] | | ASU | PIM | PIM | | | 1696 | XML is valid
02/19/14 10:15:42:590 | [INFO] | | ASU | PIM | Utilities | | | 1696 | File 'C:\Program Files\Common Files\Adobe\OOBE\PDApp\\P6' does not exist
02/19/14 10:15:43:697 | [INFO] | | ASU | PIM | Utilities | | | 1696 | File 'C:\Program Files\Common Files\Adobe\OOBE\PDApp\\P6\P6.pimx' does not exist
02/19/14 10:15:44:399 | [INFO] | | ASU | PIM | PIM | | | 1696 | XML is valid
02/19/14 10:15:44:399 | [WARN] | | ASU | PIM | PIM | | | 1696 | Failed to find Node
02/19/14 10:15:44:415 | [INFO] | | ASU | PIM | PIM | | | 1696 | XML is valid
02/19/14 10:15:44:415 | [WARN] | | ASU | PIM | PIM | | | 1696 | Failed to find Node
02/19/14 10:15:44:415 | [INFO] | | ASU | PIM | PIM | | | 1696 | SUCCESS installPackage at file 'C:\temp\acroproxi32bit\Build\ASU\AAMPackages\P6\P6.pimx'
02/19/14 10:15:44:508 | [INFO] | | ASU | PIM | PIM | | | 1696 | START installPackage at file C:\temp\acroproxi32bit\Build\ASU\AAMPackages\LWA\LWA.pimx
02/19/14 10:15:44:508 | [INFO] | | ASU | PIM | PIM | | | 1696 | XML is valid
02/19/14 10:15:44:508 | [WARN] | | ASU | PIM | PIM | | | 1696 | Failed to find Node
02/19/14 10:15:44:696 | [INFO] | | ASU | PIM | PIM | | | 1696 | SUCCESS insertPackageUpdateList.
02/19/14 10:15:44:696 | [WARN] | | ASU | PIM | PIM | | | 1696 | Failed to find Node
02/19/14 10:15:44:696 | [INFO] | | ASU | PIM | PIM | | | 1696 | SUCCESS insertAppletRegInfoList.
02/19/14 10:15:44:696 | [INFO] | | ASU | PIM | PIM | | | 1696 | SUCCESS insertAppletRelInfoList.
02/19/14 10:15:44:696 | [INFO] | | ASU | PIM | PIM | | | 1696 | XML is valid
02/19/14 10:15:44:696 | [INFO] | | ASU | PIM | Utilities | | | 1696 | File 'C:\Program Files\Common Files\Adobe\OOBE\PDApp\\LWA' does not exist
02/19/14 10:15:45:569 | [INFO] | | ASU | PIM | Utilities | | | 1696 | File 'C:\Program Files\Common Files\Adobe\OOBE\PDApp\\LWA\LWA.pimx' does not exist
02/19/14 10:15:46:193 | [INFO] | | ASU | PIM | PIM | | | 1696 | XML is valid
02/19/14 10:15:46:193 | [WARN] | | ASU | PIM | PIM | | | 1696 | Failed to find Node
02/19/14 10:15:46:193 | [INFO] | | ASU | PIM | PIM | | | 1696 | SUCCESS installPackage at file 'C:\temp\acroproxi32bit\Build\ASU\AAMPackages\LWA\LWA.pimx'
02/19/14 10:15:46:302 | [INFO] | | ASU | PIM | PIM | | | 1696 | START installPackage at file C:\temp\acroproxi32bit\Build\ASU\AAMPackages\UWA\UWA.pimx
02/19/14 10:15:46:318 | [INFO] | | ASU | PIM | PIM | | | 1696 | XML is valid
02/19/14 10:15:46:318 | [WARN] | | ASU | PIM | PIM | | | 1696 | Failed to find Node
02/19/14 10:15:46:614 | [INFO] | | ASU | PIM | PIM | | | 1696 | SUCCESS insertPackageUpdateList.
02/19/14 10:15:46:614 | [WARN] | | ASU | PIM | PIM | | | 1696 | Failed to find Node
02/19/14 10:15:46:614 | [INFO] | | ASU | PIM | PIM | | | 1696 | SUCCESS insertAppletRegInfoList.
02/19/14 10:15:46:614 | [INFO] | | ASU | PIM | PIM | | | 1696 | SUCCESS insertAppletRelInfoList.
02/19/14 10:15:46:614 | [INFO] | | ASU | PIM | PIM | | | 1696 | XML is valid
02/19/14 10:15:46:614 | [INFO] | | ASU | PIM | Utilities | | | 1696 | File 'C:\Program Files\Common Files\Adobe\OOBE\PDApp\\UWA' does not exist
02/19/14 10:15:47:660 | [INFO] | | ASU | PIM | Utilities | | | 1696 | File 'C:\Program Files\Common Files\Adobe\OOBE\PDApp\\UWA\UWA.pimx' does not exist
02/19/14 10:15:48:486 | [INFO] | | ASU | PIM | PIM | | | 1696 | XML is valid
02/19/14 10:15:48:486 | [WARN] | | ASU | PIM | PIM | | | 1696 | Failed to find Node
02/19/14 10:15:48:486 | [INFO] | | ASU | PIM | PIM | | | 1696 | SUCCESS installPackage at file 'C:\temp\acroproxi32bit\Build\ASU\AAMPackages\UWA\UWA.pimx'
02/19/14 10:15:48:580 | [INFO] | | ASU | PIM | PIM | | | 1696 | START installPackage at file C:\temp\acroproxi32bit\Build\ASU\AAMPackages\CCM\CCM.pimx
02/19/14 10:15:48:596 | [INFO] | | ASU | PIM | PIM | | | 1696 | XML is valid
02/19/14 10:15:48:596 | [INFO] | | ASU | PIM | PIM | | | 1696 | Current OS version is: Major:6, Minor:1, ServicePack:1
02/19/14 10:15:48:596 | [WARN] | | ASU | PIM | PIM | | | 1696 | Failed to find Node
02/19/14 10:15:49:235 | [INFO] | | ASU | PIM | PIM | | | 1696 | SUCCESS insertPackageUpdateList.
02/19/14 10:15:49:235 | [INFO] | | ASU | PIM | PIM | | | 1696 | Current OS version is: Major:6, Minor:1, ServicePack:1
02/19/14 10:15:49:235 | [WARN] | | ASU | PIM | PIM | | | 1696 | Failed to find Node
02/19/14 10:15:49:235 | [INFO] | | ASU | PIM | PIM | | | 1696 | SUCCESS insertAppletRegInfoList.
02/19/14 10:15:49:235 | [INFO] | | ASU | PIM | PIM | | | 1696 | SUCCESS insertAppletRelInfoList.
02/19/14 10:15:49:235 | [INFO] | | ASU | PIM | PIM | | | 1696 | XML is valid
02/19/14 10:15:49:251 | [INFO] | | ASU | PIM | Utilities | | | 1696 | File 'C:\Program Files\Common Files\Adobe\OOBE\PDApp\\CCM' does not exist
02/19/14 10:15:49:251 | [INFO] | | ASU | PIM | PIM | | | 1696 | Current OS version is: Major:6, Minor:1, ServicePack:1
02/19/14 10:15:49:251 | [WARN] | | ASU | PIM | PIM | | | 1696 | Failed to find Node
02/19/14 10:15:49:251 | [INFO] | | ASU | PIM | Utilities | | | 1696 | File 'C:\Program Files\Common Files\Adobe\OOBE\PDApp\\CCM\CCM.pimx' does not exist
02/19/14 10:15:50:093 | [INFO] | | ASU | PIM | PIM | | | 1696 | XML is valid
02/19/14 10:15:50:093 | [INFO] | | ASU | PIM | PIM | | | 1696 | Current OS version is: Major:6, Minor:1, ServicePack:1
02/19/14 10:15:50:093 | [WARN] | | ASU | PIM | PIM | | | 1696 | Failed to find Node
02/19/14 10:15:50:093 | [INFO] | | ASU | PIM | PIM | | | 1696 | SUCCESS installPackage at file 'C:\temp\acroproxi32bit\Build\ASU\AAMPackages\CCM\CCM.pimx'
02/19/14 10:15:50:218 | [INFO] | | ASU | PIM | PIM | | | 1696 | START installPackage at file C:\temp\acroproxi32bit\Build\ASU\AAMPackages\P7\P7.pimx
02/19/14 10:15:50:218 | [INFO] | | ASU | PIM | PIM | | | 1696 | XML is valid
02/19/14 10:15:50:218 | [WARN] | | ASU | PIM | PIM | | | 1696 | Failed to find Node
02/19/14 10:15:50:374 | [INFO] | | ASU | PIM | PIM | | | 1696 | SUCCESS insertPackageUpdateList.
02/19/14 10:15:50:374 | [WARN] | | ASU | PIM | PIM | | | 1696 | Failed to find Node
02/19/14 10:15:50:374 | [INFO] | | ASU | PIM | PIM | | | 1696 | SUCCESS insertAppletRegInfoList.
02/19/14 10:15:50:374 | [INFO] | | ASU | PIM | PIM | | | 1696 | SUCCESS insertAppletRelInfoList.
02/19/14 10:15:50:374 | [INFO] | | ASU | PIM | PIM | | | 1696 | XML is valid
02/19/14 10:15:50:374 | [INFO] | | ASU | PIM | Utilities | | | 1696 | File 'C:\Program Files\Common Files\Adobe\OOBE\PDApp\\P7' does not exist
02/19/14 10:15:52:386 | [INFO] | | ASU | PIM | Utilities | | | 1696 | File 'C:\Program Files\Common Files\Adobe\OOBE\PDApp\\P7\P7.pimx' does not exist
02/19/14 10:15:54:071 | [INFO] | | ASU | PIM | PIM | | | 1696 | XML is valid
02/19/14 10:15:54:071 | [WARN] | | ASU | PIM | PIM | | | 1696 | Failed to find Node
02/19/14 10:15:54:071 | [INFO] | | ASU | PIM | PIM | | | 1696 | SUCCESS installPackage at file 'C:\temp\acroproxi32bit\Build\ASU\AAMPackages\P7\P7.pimx'
02/19/14 10:15:54:196 | [INFO] | | ASU | PIM | PIM | | | 1696 | START installPackage at file C:\temp\acroproxi32bit\Build\ASU\AAMPackages\IPC\IPC.pimx
02/19/14 10:15:54:196 | [INFO] | | ASU | PIM | PIM | | | 1696 | XML is valid
02/19/14 10:15:54:196 | [WARN] | | ASU | PIM | PIM | | | 1696 | Failed to find Node
02/19/14 10:15:54:305 | [INFO] | | ASU | PIM | PIM | | | 1696 | SUCCESS insertPackageUpdateList.
02/19/14 10:15:54:305 | [WARN] | | ASU | PIM | PIM | | | 1696 | Failed to find Node
02/19/14 10:15:54:305 | [INFO] | | ASU | PIM | PIM | | | 1696 | SUCCESS insertAppletRegInfoList.
02/19/14 10:15:54:305 | [INFO] | | ASU | PIM | PIM | | | 1696 | SUCCESS insertAppletRelInfoList.
02/19/14 10:15:54:305 | [INFO] | | ASU | PIM | PIM | | | 1696 | XML is valid
02/19/14 10:15:54:305 | [INFO] | | ASU | PIM | Utilities | | | 1696 | File 'C:\Program Files\Common Files\Adobe\OOBE\PDApp\\IPC' does not exist
02/19/14 10:15:54:336 | [INFO] | | ASU | PIM | Utilities | | | 1696 | File 'C:\Program Files\Common Files\Adobe\OOBE\PDApp\\IPC\IPC.pimx' does not exist
02/19/14 10:15:54:586 | [INFO] | | ASU | PIM | PIM | | | 1696 | XML is valid
02/19/14 10:15:54:586 | [WARN] | | ASU | PIM | PIM | | | 1696 | Failed to find Node
02/19/14 10:15:54:586 | [INFO] | | ASU | PIM | Utilities | | | 1696 | Path to Process :C:\Program Files\Common Files\Adobe\OOBE\PDApp\\IPC\customhook\AdobeIPCBrokerCustomHook.exe Process Directory :C:\Program Files\Common Files\Adobe\OOBE\PDApp\\IPC\customhook arguments being passed :"C:\Program Files\Common Files\Adobe\OOBE\PDApp\\IPC\customhook\AdobeIPCBrokerCustomHook.exe" -uninstall
02/19/14 10:15:54:586 | [INFO] | | ASU | PIM | Utilities | | | 1696 | Success in CreateProcess
02/19/14 10:15:54:633 | [INFO] | | ASU | PIM | Utilities | | | 1696 | Sucessfully launched and executed process...
02/19/14 10:15:54:633 | [INFO] | | ASU | PIM | PIM | | | 1696 | Successfully executed install modifier at path: 'C:\Program Files\Common Files\Adobe\OOBE\PDApp\\IPC\customhook\AdobeIPCBrokerCustomHook.exe'. Return code: 0
02/19/14 10:15:54:633 | [INFO] | | ASU | PIM | PIM | | | 1696 | SUCCESS installPackage at file 'C:\temp\acroproxi32bit\Build\ASU\AAMPackages\IPC\IPC.pimx'
02/19/14 10:15:54:945 | [INFO] | | ASU | PIM | Utilities | | | 1696 | File 'C:\Program Files\Common Files\Adobe\OOBE\PDApp\PDAppFlex.swf' does not exist
02/19/14 10:15:55:163 | [INFO] | | ASU | PIM | Utilities | | | 1696 | File 'C:\Program Files\Common Files\Adobe\OOBE\PDApp\PDAppFlex-app.xml' does not exist
02/19/14 10:15:55:569 | [INFO] | | ASU | PIM | PIM | | | 1696 | Processing ... _pimCreateOrUpdateAAMInventory
02/19/14 10:15:55:709 | [INFO] | | ASU | PIM | PIM | | | 1696 | Return ... SUCCESS _pimCreateOrUpdateAAMInventory
02/19/14 10:15:55:709 | [INFO] | | ASU | Setup | Setup | | | 1696 | TimeLog: End Installing. Now launching PDApp
02/19/14 10:15:56:224 | [INFO] | | ASU | Setup | Setup | | | 1696 | Deployment File Path not specified in command line arguments. Skipping payload deployment part
02/19/14 10:15:56:224 | [INFO] | | ASU | Setup | Setup | | | 1696 | xml path: 'C:\Users\jowi\AppData\Local\Adobe\OOBE\{BDEFAULT-D7CA-4F31-B4C0-15DB86C98250}.xml' doesn't exists. So can't dump the pim install status xml
02/19/14 10:15:56:224 | [INFO] | | ASU | Setup | | | | 1696 | Event Guid generated is: '53060228-1925-4bf1-a78c-f5624a95f49d'
02/19/14 10:15:56:224 | [INFO] | | ASU | Setup | Setup | | | 1696 | ================= End Adobe Setup. Exit code: 0 =================
02/19/14 10:15:56:224 | [INFO] | | ASU | PIM | PIM | | | 1696 | PIMSqlite closeDB status 0
02/19/14 10:15:56:224 | [INFO] | | ASU | PIM | PIM | | | 1696 | FREE PIM Instance ...
02/19/14 10:15:56:224 | [INFO] | | ASU | Setup | | | | 1696 | Waiting for the async thread to get the task completed
02/19/14 10:15:56:240 | [INFO] | | ASU | Setup | | | | 2912 | Event with guid '53060228-1925-4bf1-a78c-f5624a95f49d' is being sent
02/19/14 10:15:56:255 | [INFO] | | ASU | Setup | | | | 2912 | GetIEProxyInfo - No default proxy present on the user machine
02/19/14 10:15:56:255 | [INFO] | | ASU | Setup | | | | 2912 | GetIEProxyInfo - proxy Url is
02/19/14 10:15:56:661 | [INFO] | | ASU | Setup | | | | 1040 | HTTP Request Status code 200.
02/19/14 10:15:56:661 | [INFO] | | ASU | Setup | | | | 2912 | The http request returned HTTP_Status:0 HttpCommunicator error:0
02/19/14 10:15:56:661 | [INFO] | | ASU | Setup | | | | 2912 | Async thread is completed. Now exiting from function.
02/19/14 10:15:56:801 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 1968 | Build Version - 1.4.0.37
02/19/14 10:15:56:801 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 1968 | Logging Level verbosity Set to 4
02/19/14 10:15:56:801 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 1968 | The return code from the Bootstrapper Process is (0).
02/19/14 10:15:56:801 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 1968 | STEP 3: Starting to launch Bootstrapper of Media (APRO11.0.0sv_SE).
02/19/14 10:15:56:801 | [INFO] | | ASU | DeploymentManager | Utilities | | | 1968 | File 'C:\temp\acroproxi32bit\Build\Setup\APRO11.0.0sv_SE\Set-up.dat' does not exist
02/19/14 10:15:56:801 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 1968 | The Bootstrapper seems to be missing(C:\temp\acroproxi32bit\Build\Setup\APRO11.0.0sv_SE\Set-up.dat). Skipping the installation process.
02/19/14 10:15:56:801 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 1968 | Correcting Dependencies in local db.
02/19/14 10:15:56:801 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 1968 | No media db present on the machine.
02/19/14 10:15:56:801 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 1968 | STEP 4: Starting to launch Adobe Installer.
02/19/14 10:15:56:801 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 1968 | Obtained Adobe Common Folder Path.
02/19/14 10:15:56:801 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 1968 | Adobe Installer launch location is :: C:\Program Files\Common Files\Adobe\OOBE\PDApp\DECore\Setup.exe
02/19/14 10:15:56:801 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 1968 | deploymentFile = (C:\Users\jowi\AppData\Local\Temp\{D77454E9-5AD3-4DD3-8C1E-E3660BF50140}\\{42CE3F50-DCB9-4E99-A2FE-85BAC02B65CB}), installSourcePath = (C:\temp\acroproxi32bit\Build\Setup\APRO11.0.0sv_SE)
02/19/14 10:16:07:004 | [INFO] | | ASU | DeploymentManager | AAMEEUtilities | | | 1968 | Process creation completed.
02/19/14 10:16:07:004 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 1968 | The return code from the Adobe Installer Process is (0).
02/19/14 10:16:07:004 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 1968 | STEP 5: Starting to launch Provisioning Tool.
02/19/14 10:16:07:004 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 1968 | Provisioning tool launch location is :: C:\Users\jowi\AppData\Local\Temp\{2236AB8C-F822-4E94-85A1-C7C76C1263A4}\\{66697E0F-16F3-4734-916D-55867E925B56}
02/19/14 10:16:07:019 | [INFO] | | ASU | DeploymentManager | AAMEEUtilities | | | 1968 | Process creation completed.
02/19/14 10:16:07:019 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 1968 | The return Code from Provisioning Tool (6).
02/19/14 10:16:07:019 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 1968 | Provisioning Tool has failed to EULA suppression the product.
02/19/14 10:16:07:019 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 1968 | Media Successfully Installed (APRO11.0.0sv_SE)
02/19/14 10:16:07:019 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 1968 | STEP 5: Starting to launch Provisioning Tool.
02/19/14 10:16:07:019 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 1968 | Provisioning tool launch location is :: C:\Users\jowi\AppData\Local\Temp\{2236AB8C-F822-4E94-85A1-C7C76C1263A4}\\{66697E0F-16F3-4734-916D-55867E925B56}
02/19/14 10:16:07:128 | [INFO] | | ASU | OPM | OPM | | | 2816 | Build Version - 7.0.0.386
02/19/14 10:16:07:128 | [INFO] | | ASU | OPM | OPM | | | 2816 | Logging Level verbosity Set to 4
02/19/14 10:16:07:128 | [INFO] | | ASU | OPM | OPM | | | 2816 | Schema version and schema compatibility version are same or greater than current
02/19/14 10:16:07:581 | [INFO] | | ASU | OPM | OPM | | | 2816 | Successfully opened opm session, db location:C:\Users\jowi\AppData\Local\Adobe\OOBE\opm.db in opm_createLibRef
02/19/14 10:16:07:581 | [INFO] | | ASU | OPM | OPM | | | 2816 | No Record found for the input fields in opm_getValueForKey
02/19/14 10:16:07:581 | [INFO] | | ASU | OPM | OPM | | | 2816 | Released OPM refrence successfully in opm_freeLibRef
02/19/14 10:16:10:186 | [INFO] | | ASU | DeploymentManager | AAMEEUtilities | | | 1968 | Process creation completed.
02/19/14 10:16:10:186 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 1968 | The return Code from Provisioning Tool (0).
02/19/14 10:16:10:186 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 1968 | Provisioning Tool has successfully Offline Provisioning the product.
02/19/14 10:16:10:186 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 1968 | STEP 6: Starting to Configure the System.
02/19/14 10:16:10:186 | [INFO] | | ASU | DeploymentManager | Utilities | | | 1968 | File 'C:\Program Files\Common Files\Adobe\OOBE\OOBE.conf' does not exist
02/19/14 10:16:10:186 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 1968 | Customized Trial config file does not exist.
02/19/14 10:16:10:217 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 1968 | Success: Suppression of Customized Trial.
02/19/14 10:16:10:217 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 1968 | Success: Suppression of APIP.
02/19/14 10:16:10:217 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 1968 | Success:Suppression of APIP for Acrobat Professional.
02/19/14 10:16:10:248 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 1968 | Success: Supression of the Adobe Updater.
02/19/14 10:16:10:248 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 1968 | Success:Suppression of Updater for Acrobat Professional.
02/19/14 10:16:10:248 | [INFO] | | ASU | DeploymentManager | Utilities | | | 1968 | File 'C:\ProgramData\Adobe\AAMUpdater\1.0\AdobeUpdater.Overrides' does not exist
02/19/14 10:16:10:248 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 1968 | The Update Redirection XML file is not present in the machine.
02/19/14 10:16:10:248 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 1968 | RemoteUpdateManager deploy Path is : %ProgramFiles%\Common Files\Adobe\OOBE_Enterprise\RemoteUpdateManager
02/19/14 10:16:10:248 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 1968 | Substituting environment variable : ProgramFiles ,with value : C:\Program Files.
02/19/14 10:16:10:248 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 1968 | RemoteUpdateManager deploy Path after processing is: C:\Program Files\Common Files\Adobe\OOBE_Enterprise\RemoteUpdateManager
02/19/14 10:16:10:248 | [INFO] | | ASU | DeploymentManager | Utilities | | | 1968 | Folder does not exist
02/19/14 10:16:10:264 | [INFO] | | ASU | DeploymentManager | Utilities | | | 1968 | Folder does not exist
02/19/14 10:16:10:280 | [INFO] | | ASU | DeploymentManager | Utilities | | | 1968 | File 'C:\Program Files\Common Files\Adobe\OOBE_Enterprise\RemoteUpdateManager\RemoteUpdateManager.exe' does not exist
02/19/14 10:16:10:373 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 1968 | Successfully deployed the RemoteUpdateManager.
02/19/14 10:16:10:373 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 1968 | STEP 7: Starting to apply the updates.
02/19/14 10:16:10:373 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 1968 | Number of updates to apply is (0).
02/19/14 10:16:10:373 | [INFO] | | ASU | DeploymentManager | DeploymentManager | | | 1968 | The install workflow is terminating.
02/19/14 10:16:10:919 | [INFO] | | ASU | MSIInvoker | AAMEEUtilities | | | 2584 | Process creation completed.
02/19/14 10:16:10:919 | [INFO] | | ASU | MSIInvoker | MSIInvoker | | | 2584 | utilLaunchApplicationDeelevated : The return Code from Create Process (0).
You should probably post this in the Creative Cloud Forum: http://forums.adobe.com/community/creative_cloud
The PDApp log above doesn't show an obvious error other than not being able to negotiate your proxy server, which depending on the licensing option that you selected might be significant. You don't say which one you setup and you don't give too much detail on how you are installing.
- How are you attempting to install?
- Command line?
- Exceptions Deployer?
- Double clicking on an EXE?
- Another deployment technology (i.e. SCCM, FileWave, etc..)
Did you try setting up a verbose MSI installtion log?
http://support.microsoft.com/kb/2545723
I find that unless it has to do specifically with Adobe licensing technology, the PDApp logs don't really say much about what might be going wrong.
