how do I convert email to pdf in Office Outlook 2013?
This is a poor response. The question specifically referred to Outlook 2013, and the link only refers to converting messages to PDF generically, not Outlook 2013. The suggested steps in the link do not answer the question of converting emails in Outlook 2013 to PDF. The option just isn't there - only Text, Outlook, or HTML file types.
What would be a better suggestion is to "print to PDF" and create the file that way. It'll probably be more effective and quicker than trying to "save" the file.
To convert MSG files to PDF format you can use the manual method: by using Outlook email client “Save as” option, but manually you are not able to convert MSG file attachments. If you want to convert MSG files with their attachment so try an effective third party tool like MSG to PDF converter to convert MSG files to PDF with attachment.
Nice information shared...
I would like to suggest one more solution for extracting Outlook emails to PDF file format. It also maintains files and folders hierarchy during file conversion.
Helpful to convert Outlook 2013 emails to PDF.
Regards
You can use Print option in MS Outlook 2013 to get all the emails in PDF file format. It is difficult to convert a bulk number of Outlook messages. Therefore, you can export MSG to PDF with the help of MSG Viewer Pro that allows you to view and convert all the individual emails to portable document format (PDF).
