suppersppy
Indesign Missing from Bridge CS6 Tools Menu
Feb 20, 2014 2:28 AM
Tags: #bridge
I'm using CS6 and indesign is missing from my tools menu. I checked startup scripts in preferences and it is checked. I tried unchecking it and restarting it then rechecking it and I also tried resetting my preferences when starting bridge. Running OSX 10.8.5 and Bridge 5.0.0.39
P.S. I feel like this should be an easy fix and an easy thing to search for but I've searched extensively and the only thing I've found is the question asked occasionally. I've not found anything for CS6 and I've not found a solution.
  • Omke Oudeman
    Nov 27, 2004
    Feb 20, 2014 4:14 AM   in reply to suppersppy
    ID has never been part of the Tools menu to my knowledge but you can place files using the menu File / Place / inDesign.
    A better way would be to create a collection in Bridge from the files you want or might want to use in your ID project. Then in ID use the Mini Bridge Panel and select the collection you created for this project. Now you can drag and drop form Mini Bridge thumbnail panel.
  • Omke Oudeman
    Nov 27, 2004
    Feb 20, 2014 2:05 PM   in reply to suppersppy
    And to be clear you do have the according CS6 ID and AE versions installed at your system and also have applied the latest updates?
  • Pierre Courtejoie
    Jan 11, 2006
    Feb 22, 2014 2:34 AM   in reply to suppersppy
    Hello, according to http://indesignsecrets.com/missing-the-indesign-contact-sheet-bridge-t o-the-rescue.php , the bridge contact sheets function in the tools menu has been removed circa CS4, and is replaced by the output module.
  • Pierre Courtejoie
    Jan 11, 2006
    Feb 22, 2014 2:36 AM   in reply to Pierre Courtejoie
    And in Bridge CC, the output module is a separate download.
