erick1953
DVD SPACE
Feb 20, 2014 2:22 PM
Hello, I have Adobe Premiere Elements 12. I finished all editing of my home movies and wound up with 148min. I would like to burn the DVD disk on my lap top. Can I use the standard 120min. Dynex DVD-R disk.? Will the Adobe program make the proper adjustments and alow the movies to fit on this disk? Nice easy answers please...I'm an electronic nitwit....Thank you..!!
    Feb 20, 2014 2:30 PM   in reply to erick1953
    As a general rule, a standard DVD holds about 70-80 minutes of footage at full quality. You've got about twice that.
    I suppose it's worth a try -- though if it doesn't work or look good, you'll know why.
    Feb 20, 2014 2:35 PM   in reply to erick1953
    erick1953
    You will do just fine.
    Publish+Share/Disc/DVD disc....
    In the burn dialog, you should see a place to put a check mark next to "Fit Content to Available Space". Please do that.
    In the Quality area of that same burn dialog, you will Space Required and Bitrate.
    With the "Fit..." setting active, the program will lower that Bitrate value to try to make the fit as much as it can. The lower it sets
    the Bitrate value, the lower will be the quality of the end product. You can get away with a little bit of lower of the Bitrate
    before you see a significant hit on the quality. The Bitrate value max = 8.00 Mbps. Watch that if and when it is lowered.
    Keep in mind with those DVD disc
    4.7 GB/120 minutes, that 4.7 GB in reality = 4.38 GB
    8.5 GB/240 minutes, that 8.5 GB in reality = 7.95 GB
    Give it a try and then let us know the results.
    Thanks.
    ATR
    Feb 20, 2014 6:41 PM   in reply to erick1953
    Welcome to the forum.
    As has been stated, to fit more Duration onto a disc, say a DVD-5, the Bit-Rate might need to be lowered. Bit-Rate determines the files size of the Encoded MPEG-2 AV file, and also the Quality. As Bit-Rate goes down, so will the file size, allowing for a greater Duration, but at the expense of Quality.
    Only your eyes can determine whether that resultant Quality is still good enough.
    If not, then I would consider using a DVD-9, to keep the Bit-Rate up, and the Quality at its highest.
    Also, I do not recognize the brand of blank media that you have. It might be great, or maybe not. If you experience any playability issues, consider using Verbatim, Taiyo-Yuden, or Falcon Pro blank media.
    Feb 20, 2014 6:54 PM   in reply to erick1953
    erick1953
    Hunt has mentioned use of a DVD-5 and DVD-9 disc for your burn to disc DVD.
    A just in case note, the DVD-5 is the 4.7 GB/120 minutes disc and DVD-9 is the 8.5 GB/240 minutes disc (aka double layer singled sided).
    ATR
    Feb 21, 2014 1:03 PM   in reply to erick1953
    Erick
    Thanks for the great news of success. We are very please to learn of your progress. Great job.
    The best is yet to come.
    ATR
