When importing a project from HelpStudio, everything imports, but it seems that 2nd level TOC topics are not displaying vertical scroll bars when viewed in the CHM output.
Has anyone else seen this behavior?
Suggestions? ("Other than use another format")
-Matt
Hi Matt.
Can you help us understand where the problem may be. What happens if you move one of the second level topics up to the first level in the TOC? Does the vertical scroll bar display? If so, it maybe worth checking the project's .HHC file for any rouge code. Maybe even rebuiilding the TOC file would help.
Heya Matt
Try looking at the HTML behind the offending topics. See if they make mention of a scroll=no anywhere. If so, that's likely your culprit! Remove the scroll=no and you should be set.
Cheers... Rick
