Sara Houmann Mortensen
Creating anchored objects underneath a textframe?
Feb 21, 2014 4:09 AM
Tags: #anchored_object
I'd like to make a box underneath a textframe and anchor it so that it will move along with a special section of the text. When I anchor the box it is automaticly placed on top of the text wich is not my intension. Also if I place the box in the back befor anchoring. Can you help me:)?
Best,
Sara
    Feb 21, 2014 4:20 AM   in reply to Sara Houmann Mortensen
    On the anchor object options, for position select: inline or above line then play with space before and space after settings.
    Feb 21, 2014 6:54 AM   in reply to Sara Houmann Mortensen
    I think we need some clarification of what yolu mean by "underneath." If you mean it should appear further down in the text flow, that's doable. If you mean behind the text you can only accomplish that with an inline/above line frame (for inline you can just drag downwards) and careful sizing and positioning, so it may not be achievable in all cases. Custom position anchored objects are always above the text that holds the anchor in the stacking order.
    Feb 21, 2014 11:08 PM   in reply to Sara Houmann Mortensen
    In some contexts (eg., black text on white background), you can easily use anchored objects with "Incrustation" effect (in French).
Bookmarked By (1)
