• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Integrating webhelp generated content with Adobe CQ5
Guest
Feb 24, 2014 Feb 24, 2014
Can we integrate Adobe Robohelp generated web help content with Adobe CQ5 (Adobe Experience Manager)?
If Yes, How?
I have to migrate existing Online Help (webhelp content generated from RH8) on to our newly implemented CMS Adobe CQ5 ? Can any one help me, with the procedure ?
Thanks Alot,
Ravi
Views
784
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND ,
I personally have never used Adobe's Experience Manager and I doubt a lot of folk here will have either. Having said that, maybe we can try and understand what it is you are trying to migrate or if you are trying to migrate at all. The two applications are very different. RoboHelp is the source used to create the content. Adobe's Experience Manager handles the content. Can you help us by providing some further context?
Votes
Translate
Translate
Report
Report
LEGEND ,
Feb 25, 2014 Feb 25, 2014
The Adobe TCS website says:
"Out-of-the-box integration with Adobe Experience Manager: Manage content effectively using new native integration between FrameMaker 12 and Adobe Experience Manager, formerly known as Adobe CQ. Check out, check in, upload, copy, move, and create files. Get digital asset management metadata support, see version history, show dependents, and more. Customize Adobe Experience Manager by changing preferences."
This sounds like you can get FM content directly into Adobe Experience Manager. This raises the question whether you are asking if the same could be done from RoboHelp. If so, the answer appears to be "No". However that is not to say it is impossible, just that the same level of out of the box integration is not there.
Votes
Translate
Translate
Report
Report
Guest
Thanks Alot for your reply.
Yes, we can get FM content directly into AEM and the same level of out of the box integration is not there in RoboHelp. Any other way to get RH content directly into AEM ?
Votes
Translate
Translate
Report
Report
LEGEND ,
LATEST
Can I say that I am not an expert in AEM. I have compiled a list of the outputs that RH can produce at:
http://www.cmcandrew.com/robocolumn/what-is-the-most-appropriate-output-format/
All I can add is that you find out what types of output are allowed by AEM. If they allow the outputs from RH in my list, you should be OK. However the level of integration offered by FrameMaker is not available with RoboHelp. That means you have two options.
  1. If you find that AEM allows RH output, manually add the RH output content to AEM.
  2. Move your RH content to FM and use the out of the box integration.
You may also want to throw your hat into the ring by requesting that RH offers the same level of integration as FM. You can do that here:
https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform&product=38
Votes
Translate
Translate
Report
Report
Resources
RoboHelp Documentation
Download Adobe RoboHelp
