deluz
Linking to a part (anchor) in FlashPaper
Jun 15, 2006 10:55 AM
I am trying to create a simple system that will let me open a FlashPaper .swf file to a certain section.
I need this navigation to come externally, such as passing a link in, calling a variable, etc. I have Macromedia Director and have FlashPaper working in Director. I could also pass the call via an html page.
Is there any way to do this?
Ryan Deluz
    Jun 16, 2006 1:37 PM   in reply to deluz
    The quick answer is the function goToLinkTarget, but this is very poorly implemented in version 2 of FlashPaper.
    My solution and code to help goToLinkTarget work better follows:
    I am going to use Zinc to pass the link in via command line (as I couldn't get FlashPaper in director to resize properly). I created a function that will read the original names as shown in my Word Document.
    FlashPaper starts by changing the names of the links (anchors) when a word document is converted. It does not expose an interface to get these new names, so I don't know how people were assumed to use the goToLinkTarget function.
    The following code should work to load a .swf FlashPaper and create a map of its links for easy use. I hope this helps people.
    This also includes code to dynamically resize FlashPaper so that it looks good in a resizable player.
    //LOAD FLASH PAPER
    Stage.scaleMode = "noScale";
    Stage.align = "TL";
    //create MovieClip holder for FlashPaper
    //create instance of MovieClip holder and place on stage
    var mFlashPaperMC:MovieClip = _root.createEmptyMovieClip("mFlashPaperMC", _root.getNextHighestDepth());
    var mFlashPaper;
    var mBookmarkMap:Object;
    //flash paper interface
    var mFlashPaperListener:Object = new Object();
    mFlashPaperListener.onLoaded = function(mFlashPaper:Object):Void {
    //loading is complete, so we can now adjust the current page, zoom, etc.
    //mFlashPaper.setCurrentPage(mFlashPaper.getNumberOfPages());
    //mFlashPaper.setCurrentZoom(33);
    mFlashPaper.addListener(this);
    mFlashPaper.showUIElement("Brand", false);
    mFlashPaperMC.toolbar_mc.brandClip_mc._visible = false;
    mBookmarkMap = mapBookmarks(mFlashPaperMC);
    goBookmark("Home", mFlashPaper, mBookmarkMap);
    //LISTENS FOR RESIZE AND RESIZES FLASH PAPER
    var mStageListener:Object = new Object();
    mStageListener.onResize = function() {
    mFlashPaper.setSize(Stage.width, Stage.height);
    Stage.addListener(mStageListener);
    loadFlashPaper("QuickStartHelp.swf", mFlashPaperMC, Stage.width, Stage.height, mFlashPaperListener);
    stop();
    function loadFlashPaper(path_s, dest_mc, width_i, height_i, loaded_o) {
    var intervalID = 0;
    var loadFunc = function () {
    dest_mc._visible = false;
    mFlashPaper = dest_mc.getIFlashPaper();
    if (!mFlashPaper) {
    return;
    if (mFlashPaper.setSize(width_i, height_i) == false) {
    return;
    dest_mc._visible = true;
    clearInterval(intervalID);
    loaded_o.onLoaded(mFlashPaper);
    intervalID = setInterval(loadFunc, 100);
    dest_mc.loadMovie(path_s);
    function mapBookmarks(flashPaperMC) {
    //associative array to store book marks
    var asArray:Object = new Object();
    trace(flashPaperMC);
    trace(flashPaperMC.fpBookmarks_array);
    trace(flashPaperMC.fpBookmarks_array.length);
    for (var i = 0; i<flashPaperMC.fpBookmarks_array.length; i++) {
    trace(flashPaperMC.fpBookmarks_array .publicName_str);
    asArray[flashPaperMC.fpBookmarks_array
    .publicName_str] = flashPaperMC.fpBookmarks_array .anchorName_str;
    //store this bookmark name
    for (var j = 0; j<mFlashPaperMC.fbBookmarks_array
    .length; j++) {
    asArray[flashPaperMC.fpBookmarks_array [j].publicName_str] = flashPaperMC.fpBookmarks_array[j].anchorName_str;
    trace(asArray.toString());
    return asArray;
    function goBookmark(theName, flashPaperI, bookmarkMap) {
    flashPaperI.goToLinkTarget("anchor:"+bookmarkMap[theName]);
    Jun 16, 2006 1:47 PM   in reply to deluz
    FYI the internal name / anchor structure looks like this:
    Variable _level0.mFlashPaperMC.fpBookmarks_array = [object #116, class 'Array'] [
    0:[object #117, class 'Object'] {
    subBookmarks_array:[object #118, class 'Array'] [
    0:[object #119, class 'Object'] {
    anchorName_str:"_FPB1",
    publicName_str:"2 Inhibits – 1 Reward"
    1:[object #120, class 'Object'] {
    anchorName_str:"_FPB2",
    publicName_str:"1 Inhibit – 1 Reward"
    2:[object #121, class 'Object'] {
    anchorName_str:"_FPB3",
    publicName_str:"Multiple Inhibits"
    3:[object #122, class 'Object'] {
    anchorName_str:"_FPB4",
    publicName_str:"Alpha / Theta"
    anchorName_str:"_FPB0",
    publicName_str:"Choosing a Training Type"
    1:[object #123, class 'Object'] {
    subBookmarks_array:[object #124, class 'Array'] [
    0:[object #125, class 'Object'] {
    anchorName_str:"_FPB6",
    publicName_str:"No Game"
