I am using captivate 5 - i am able to copy and paste for a number of times and then it wont allow me to copy any more images etc. I have to close down captivate to clear the memory in order to continue....
There must be a way around this.... Is there a clipboard i can access in captivate... I cant delete the images showing in the library as this will remove images i need... any advice please
This is likely, ultimately, a system issue. You're system is just running out of available RAM to store the clipboard.
Access to a feature to clear the clipboard would, indeed, seem ideal...but no way to do that in Captivate.
Perhaps copy/pasting a few times within Notepad will help clear things up?
Otherwise, when I've encountered this....I've had to do the same; at least close down a couple memory-hogging applications, but even having to reboot the computer.
Fortunately, ever since working with 4gb+ RAM, I've not had this issue.
