Installing CF10 64-bit Dev edition on Win 7-64 and Apache 64 bit. When I get to the Add Web Server Configuration and click on the Configuration Directory button to open the directory tree, the install freezes. I have to stop the install using the task manager. Any ideas what is causing the problem. It's like the java app for the directory tree is not initializing and just freezing up everything. Java 7 update 25 is installed.
I was running CF9 with no problem on this machine. It was uninstalled before doing the CF10 install. I had no problems installing CF10 on my other machine
thanks,
Doug
Hi Doug,
Have you tried installing the ColdFusion with builtin port and then create the connector using the Web Server Configuation tool. If not, can you please give it a try.
If it works, you can disable the builtin port in ColdFusion 10\cfsuion\runtime\conf server.xml
<!-- internal webserver start
<Connector executor="tomcatThreadPool" maxThreads="50"
port="8500" protocol="org.apache.coyote.http11.Http11Protocol"
connectionTimeout="20000"
redirectPort="8445" />
internal webserver end -->
Priyank
