• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Map IDs to Destinations in PDF output - Possible?
New Here ,
Mar 07, 2014 Mar 07, 2014
I've searched for whether this can be done from Robohelp but all my queries are matching the FM Named Destinations to PDF, which I know how to use, but is not the particular goal.  It seems there should be a way to convert MapIDs in RH to Destinations in PDF but I have not found anything that indicate the Printed Doc Single Source workflow supports this. I'm probably missing something obvious. 😕
Robohelp 10
Acrobat X Pro
Doable?
Diana
Views
875
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND ,
Mar 12, 2014 Mar 12, 2014
I'm not aware of a way to do this. As far as I know, the CSH information
is lost when you create Printed Documentation.
But I hope Peter jumps in to prove me wrong.
Kind regards,
Willam
Votes
Translate
Translate
Report
Report
Community Expert ,
Map IDs are linked to topics via the map and alias files which go nowhere near any print output. I assume the term "Destinations" is referring to what would be bookmarks in Word or PDF, which are a different beast.
@petergrainge
Votes
Translate
Translate
Report
Report
LEGEND ,
As Peter states the mapids don't go near printed output, but you can link to a PDF bookmark. Maybe that would provide an alternative solution:
http://forums.adobe.com/thread/841330
Votes
Translate
Translate
Report
Report
New Here ,
Thanks to all of you guys. It really is so helpful to get guidance from the experts.   The thing I am trying to test is this -- we have contextual help for several product families handled in a single help project. I'm trying to test whether it's possible to move a chunk of a more legacy product family to a tagged PDF so that its topics do not clutter the others.  The intention was to use the map ids as PDF named destinations so that the syntax could be mapped more easily for contextual help in the legacy product.
It sounds as though there is no neat/simple way to leverage the map ids to do this though.
Thanks again for your replies.
Diana
Votes
Translate
Translate
Report
Report
Community Expert ,
Mar 17, 2014 Mar 17, 2014
Could you not use merged help and keep it online? That way you would supply the customers who need all the help with the full merge and those who don't need the legacy topics would not be given that output.
See merged help on my site if you think that might help.
Alternatively, you could create Content Categories so that users can select all topics or exclude legacy. That is described in the RoboHelp Tour, also on my site.
@petergrainge
Votes
Translate
Translate
Report
Report
New Here ,
Hi Peter
I tinkered this AM with Content Categories. I'd not explored them before -- they do seem interesting for a variety of purposes, but my first test was a bit deflating.  In particular, I would have liked to see the Content Category menu option filter the results for Search as well, but it doesn't. Even if I have the subset displayed, a search hits all the underlying topics.  I suppose that makes sense as the categories tool is really just a display element.
It really seems to me that it should be not terribly difficult for Adobe to create an output option that exports webhelp based on a specific tag rather than <all untagged> <boolean> <conditional tag>.
The merged webhelp is the most elegant approach with current incarnation of RH, but the tasks to  disentangle and rework this project into child projects rather exceed our project schedules.  Something we need to consider though. Thanks for the ideas.
Votes
Translate
Translate
Report
Report
Community Expert ,
Content Categories do filter the search. If you are getting results that should not be in that category, you have not limited the content to what you intended.
The sample projects in Rh10 both have examples, take a look at Employee Care. In Rh 11, only Salesbuilder has an example.
@petergrainge
Votes
Translate
Translate
Report
Report
New Here ,
Sorry - I imagine that the issue I had is that the category level alone is not enough to do the filter - without additional conditional tagging of  all 3000+ topics. I tried to build a category for just my one product set, but obviously could not create a conditional build for that set alone since all the untagged topics are included. I really wish Adobe would support conditional builds on the specific tag.  Anyway, retagging all the topics will likely fix the category search and I do think that's simpler than splitting the topics into merged child projects. Again thanks for your reply.
Votes
Translate
Translate
Report
Report
Community Expert ,
You can set up tags so that the build only includes say TagX. http://www.grainge.org/pages/authoring/build_expressions/expressions.htm
The other way is to build a TOC that only has the topics you want and an index that only references them etc, then use the Exclude Unreferenced Topics option. Any topic not referenced in the TOC, Index, links etc will be excluded.
@petergrainge
Votes
Translate
Translate
Report
Report
New Here ,
Mar 20, 2014 Mar 20, 2014
LATEST
Peter - I have categories working but have a further question that I could not find the answer for in the forum or googling.  If we eventually move the project to HTML5, it seems we can't use categories anymore? Have you found a means to map those even in the new RH11 HTML5 responsiveness kit? I don't want to mangle my current install to test it until we think we're ready to move up to it.  Seems tho that with only one template that RH11 should support categories again?
Diana
Votes
Translate
Translate
Report
Report
Resources
RoboHelp Documentation
Download Adobe RoboHelp
