Variable DRIVERPATH is undefined Error
May 31, 2007 6:26 PM
I have just installed coldfusion mx 6.1 developer edition on vista ultimate. The installation went fine.
However i get an error when adding a datasource in access or verifying all connections.
On adding the datasource, i get the following error.
Unable to update the NT registry.
Variable DRIVERPATH is undefined.
Is it because of vista incompability?
    May 31, 2007 7:10 PM   in reply to abhishek77
    CF probably does not have permission to access to your registry
    Locate the following reg key
    HKEY_LOCAL_MACHINE\SOFTWARE\ODBC\ODBC.INI\<your data source>\
    do you see a string called "Driver"?
    if not, create it with the value of "C:\WINDOWS\System32\odbcjt32.dll"
    if this works, credit Rob D.
    Aug 8, 2007 12:18 PM   in reply to Cole
    I did the exact same thing, but it's not working for me. I still get the following error:
    Any ideas anyone?
    Aug 8, 2007 1:42 PM   in reply to Cole
    Thank you Rob D. :)
    Jun 11, 2009 8:32 AM   in reply to abhishek77
    I had same problem with x64 vista found answer
    Open C:\Windows\SysWOW64\odbcad32.exe and create a System DSN using the Microsoft Access Driver (*.mdb).
    Then open the ColdFusion Admin and create a datasource using the ODBC Socket driver.
    Check the Trusted connection checkbox and it should work.
    Oct 3, 2010 9:33 AM   in reply to jimmoos
    @jimmoos
    Your solution is clean and works! No messing around with registry entries.
    I have x64 Windows 7. I took myself backwards and was able to reinstall my ColdFusion MX 6.1 software. It was also my first time to use the  "ODBC Socket driver" option. Upto this point I had always used the other drivers (native ones)
    Thx buddy
    Mar 20, 2011 11:02 AM   in reply to kkhisa
    Thanks so much for the info!  I have Windows 7 x64bit with
    Coldfusion 6.1.  I'm just developing for myself so didn't want to upgrade.  This solution worked perfectly.  Thanks again!
    Jun 1, 2011 5:52 AM   in reply to jimmoos
    I'm having the same problem, but when I try to create a SYSTEM DSN, I don't have a Microsoft Access option.  I only have SQL Server and SQL Native Client.  Any suggestions?  Thanks!
    Sep 1, 2011 11:42 PM   in reply to jimmoos
    That's a clean solution, but the MS Access DSN I add in System DSN does not show up in the "ODBC DSN" select box in the Datasource creation form in the CF Admin at
    Data & Services > Datasources > ODBC Socket
    so when I submit the form I get this error:
    A ODBC Datasource must be selected before submitting changes
    Nov 23, 2012 1:09 AM   in reply to aquarium.west
    I had similar issues. Fixed them by installing the 64-bit drivers from here: http://www.microsoft.com/en-us/download/details.aspx?id=13255
    Then I had to add the System DSN in the 64-bit ODBC Management Console, which causes it appear in the ODBC DSN drop-down on the CF Admin Data Source form.
    Then had to add the same System DSN to the 32-bit ODBC Management Console, to fix this error when CF attempts to connect to the database:
    Connection verification failed for data source: PABasketballSSJ
    java.sql.SQLException: [Macromedia][SequeLink JDBC Driver][ODBC Socket]internal error: The specified DSN contains an architecture mismatch between the Driver and Application
    The root cause was that: java.sql.SQLException: [Macromedia][SequeLink JDBC Driver][ODBC Socket]internal error: The specified DSN contains an architecture mismatch between the Driver and Application
