I want have two domain names
If a viewer from New Zealand (NZ) visits the Australian site (.com.au), I want the website to detect that they are from New Zealand and redirect them to the NZ domain.
I found this Javascript code on the Business Catalyst KB, however it seems to loop over and over again, even though there are breaks included in the script.
<script language="javascript">
var country = '{module_visitorcountrycode}'; // e.g. var country = US;
switch (country) {
case 'US':
document.location = 'http://us.yourcompany.com';
break;
default:
document.location = 'http://www.yourcompany.com';
break;
</script>
I've read that I should use cookies but I'm not sure how to implement that with the above script.
Any help would be much appreciated.
Kind Regards
Brendon
That is only a core element Brendon. You need to do a combination of a redirect, conditional statement to check on their location and cookies. There are a few threads on this on the forum already with code, If you do a search you should find one of them I think.
Thanks Liam. Maybe something more along these lines then"?
var country = '{module_visitorcountrycode}'; // e.g. var country = NZ;
var countryCookie = document.getcookie(countrycode);
if countryCookie == 'NZ';
switch (country) {
case 'NZ':
document.location = 'http://www.google.com';http://www.demosite.com.au'; // current page;
break;
default:
document.location = 'http://www.demosite.co.nz'; // page to be redirected to;
break;
</script>
