• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
Locked
0
Fatal Error when packaging ipa with AIR 4.0
Explorer ,
Mar 18, 2014 Mar 18, 2014
I updated from AIR 3.8 to 4.0 and now get a fata error when attempting to package an ipa using adt.bat via ANT.
Any ideas what the issue could be ?
- Abey
     [exec] #
     [exec] # A fatal error has been detected by the Java Runtime Environment:
     [exec] #
     [exec] #  EXCEPTION_UNCAUGHT_CXX_EXCEPTION (0xe06d7363) at pc=0x7581c41f, p
id=6348, tid=11704
     [exec] #
     [exec] # JRE version: Java(TM) SE Runtime Environment (7.0_51-b13) (build 1
.7.0_51-b13)
     [exec] # Java VM: Java HotSpot(TM) Client VM (24.51-b03 mixed mode, sharing
windows-x86 )
     [exec] # Problematic frame:
     [exec] # C  [KERNELBASE.dll+0xc41f]
     [exec] #
     [exec] # Failed to write core dump. Minidumps are not enabled by default on
client versions of Windows
     [exec] #
error log content:
Current thread (0x0104d400):  JavaThread "main" [_thread_in_native, id=11704, stack(0x01070000,0x010c0000)]
siginfo: ExceptionCode=0xe06d7363, ExceptionInformation=0x19930520 0x010bf5f0 0x105774a4
Registers:
EAX=0x010bf558, EBX=0x00800000, ECX=0x00000003, EDX=0x00000000
ESP=0x010bf558, EBP=0x010bf5a8, ESI=0x1064666c, EDI=0x5da70020
EIP=0x7581c41f, EFLAGS=0x00000212
Top of Stack: (sp=0x010bf558)
0x010bf558:   e06d7363 00000001 00000000 7581c41f
0x010bf568:   00000003 19930520 010bf5f0 105774a4
0x010bf578:   0507ba30 0507ba30 5da70020 00800000
0x010bf588:   1064666c 010bf598 1044cad0 10646aa0
0x010bf598:   010bf5d8 10445542 00000008 10443a0e
0x010bf5a8:   010bf5e0 10443439 e06d7363 00000001
0x010bf5b8:   00000003 010bf5d4 e06d7363 00000001
0x010bf5c8:   00000000 00000000 00000003 19930520
Instructions: (pc=0x7581c41f)
0x7581c3ff:   02 50 ff 75 14 8d 45 c4 50 e8 55 ad 02 00 83 c4
0x7581c40f:   0c eb 03 89 45 c0 8d 45 b0 50 ff 15 5c 11 81 75
0x7581c41f:   c9 c2 10 00 cc cc cc cc cc 8b ff 55 8b ec 56 8b
0x7581c42f:   75 08 83 fe f4 72 18 83 fe f6 77 13 8d 45 08 50
Register to memory mapping:
EAX=0x010bf558 is pointing into the stack for thread: 0x0104d400
EBX=0x00800000 is an unknown value
ECX=0x00000003 is an unknown value
EDX=0x00000000 is an unknown value
ESP=0x010bf558 is pointing into the stack for thread: 0x0104d400
EBP=0x010bf5a8 is pointing into the stack for thread: 0x0104d400
ESI=0x1064666c is an unknown value
EDI=0x5da70020 is an unknown value
Stack: [0x01070000,0x010c0000],  sp=0x010bf558,  free space=317k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
C  [llvm.dll+0x443439]
C  [llvm.dll+0x4429d5]
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
j  llvm.llvmJNI.WriteModuleToFile(Ljava/lang/String;JLllvm/Module;J)V+0
j  llvm.LLVM.WriteModuleToFile(Ljava/lang/String;Lllvm/Module;J)V+7
j  com.adobe.air.ipa.GOAOTCompiler.writeBitcode(Ljava/lang/String;Lllvm/Module;)Ljava/io/File;+52
j  com.adobe.air.ipa.GOAOTCompiler.linkAndOptimizeBitcodeImpl()V+151
j  com.adobe.air.ipa.BitcodeOptimizer.main([Ljava/lang/String;)V+43
v  ~StubRoutines::call_stub
---------------  P R O C E S S  ---------------
Java Threads: ( => current thread )
  0x00541000 JavaThread "Service Thread" daemon [_thread_blocked, id=10428, stack(0x04930000,0x04980000)]
  0x0053c400 JavaThread "C1 CompilerThread0" daemon [_thread_blocked, id=9776, stack(0x00ea0000,0x00ef0000)]
  0x0053b000 JavaThread "Attach Listener" daemon [_thread_blocked, id=2804, stack(0x04870000,0x048c0000)]
  0x00538000 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=11616, stack(0x04810000,0x04860000)]
  0x004c9800 JavaThread "Finalizer" daemon [_thread_blocked, id=11160, stack(0x046b0000,0x04700000)]
  0x004c8000 JavaThread "Reference Handler" daemon [_thread_blocked, id=9156, stack(0x044f0000,0x04540000)]
=>0x0104d400 JavaThread "main" [_thread_in_native, id=11704, stack(0x01070000,0x010c0000)]
Other Threads:
  0x004c6400 VMThread [stack: 0x045e0000,0x04630000] [id=11604]
  0x00553400 WatcherThread [stack: 0x04640000,0x04690000] [id=9940]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
def new generation   total 9920K, used 6153K [0x303c0000, 0x30e80000, 0x31910000)
  eden space 8832K,  69% used [0x303c0000, 0x309c17e0, 0x30c60000)
  from space 1088K,   0% used [0x30c60000, 0x30c60c70, 0x30d70000)
  to   space 1088K,   0% used [0x30d70000, 0x30d70000, 0x30e80000)
tenured generation   total 21888K, used 698K [0x31910000, 0x32e70000, 0x343c0000)
   the space 21888K,   3% used [0x31910000, 0x319be9e8, 0x319bea00, 0x32e70000)
compacting perm gen  total 12288K, used 1384K [0x343c0000, 0x34fc0000, 0x383c0000)
   the space 12288K,  11% used [0x343c0000, 0x3451a1d0, 0x3451a200, 0x34fc0000)
    ro space 10240K,  41% used [0x383c0000, 0x387f2050, 0x387f2200, 0x38dc0000)
    rw space 12288K,  52% used [0x38dc0000, 0x39406800, 0x39406800, 0x399c0000)
Card table byte_map: [0x001c0000,0x00210000] byte_map_base: 0x0003e200
Polling page: 0x00190000
Code Cache  [0x024f0000, 0x025b0000, 0x044f0000)
total_blobs=321 nmethods=97 adapters=162 free_code_cache=32007Kb largest_free_block=32775552
Compilation events (10 events):
Event: 227.562 Thread 0x0053c400   88             llvm.Twine::getCPtr (13 bytes)
Event: 227.562 Thread 0x0053c400 nmethod 88 0x025a9488 code [0x025a9580, 0x025a9610]
Event: 227.562 Thread 0x0053c400   90  s          llvm.Twine::delete (34 bytes)
Event: 227.562 Thread 0x0053c400 nmethod 90 0x025a9688 code [0x025a9790, 0x025a99bc]
Event: 227.563 Thread 0x0053c400   92  s          llvm.JNIStringRef::delete (38 bytes)
Event: 227.563 Thread 0x0053c400 nmethod 92 0x025a9cc8 code [0x025a9de0, 0x025aa1e8]
Event: 227.564 Thread 0x0053c400   94  s          llvm.StringRef::delete (34 bytes)
Event: 227.564 Thread 0x0053c400 nmethod 94 0x025aa588 code [0x025aa690, 0x025aa8bc]
Event: 227.567 Thread 0x0053c400   95 %           com.adobe.air.ipa.GOAOTCompiler::prepareBitcodeForSplitting @ 15 (300 bytes)
Event: 227.569 Thread 0x0053c400 nmethod 95% 0x025aa948 code [0x025aad00, 0x025ac5b0]
GC Heap History (8 events):
Event: 43.536 GC heap before
{Heap before GC invocations=0 (full 0):
def new generation   total 9792K, used 2767K [0x303c0000, 0x30e60000, 0x31910000)
  eden space 8704K,  31% used [0x303c0000, 0x30673fb0, 0x30c40000)
  from space 1088K,   0% used [0x30c40000, 0x30c40000, 0x30d50000)
  to   space 1088K,   0% used [0x30d50000, 0x30d50000, 0x30e60000)
tenured generation   total 21888K, used 0K [0x31910000, 0x32e70000, 0x343c0000)
   the space 21888K,   0% used [0x31910000, 0x31910000, 0x31910200, 0x32e70000)
compacting perm gen  total 12288K, used 1361K [0x343c0000, 0x34fc0000, 0x383c0000)
   the space 12288K,  11% used [0x343c0000, 0x345146e0, 0x34514800, 0x34fc0000)
Event: 43.541 GC heap after
Heap after GC invocations=1 (full 1):
def new generation   total 9920K, used 0K [0x303c0000, 0x30e80000, 0x31910000)
  eden space 8832K,   0% used [0x303c0000, 0x303c0000, 0x30c60000)
  from space 1088K,   0% used [0x30c60000, 0x30c60000, 0x30d70000)
tenured generation   total 21888K, used 689K [0x31910000, 0x32e70000, 0x343c0000)
   the space 21888K,   3% used [0x31910000, 0x319bc7e8, 0x319bc800, 0x32e70000)
Event: 227.545 GC heap before
{Heap before GC invocations=1 (full 1):
def new generation   total 9920K, used 4416K [0x303c0000, 0x30e80000, 0x31910000)
  eden space 8832K,  50% used [0x303c0000, 0x308100a8, 0x30c60000)
compacting perm gen  total 12288K, used 1371K [0x343c0000, 0x34fc0000, 0x383c0000)
   the space 12288K,  11% used [0x343c0000, 0x34516cc0, 0x34516e00, 0x34fc0000)
Event: 227.550 GC heap after
Heap after GC invocations=2 (full 2):
Event: 227.588 GC heap before
{Heap before GC invocations=2 (full 2):
def new generation   total 9920K, used 8832K [0x303c0000, 0x30e80000, 0x31910000)
  eden space 8832K, 100% used [0x303c0000, 0x30c60000, 0x30c60000)
Event: 227.589 GC heap after
Heap after GC invocations=3 (full 2):
def new generation   total 9920K, used 14K [0x303c0000, 0x30e80000, 0x31910000)
  from space 1088K,   1% used [0x30d70000, 0x30d73948, 0x30e80000)
  to   space 1088K,   0% used [0x30c60000, 0x30c60000, 0x30d70000)
Event: 227.604 GC heap before
{Heap before GC invocations=3 (full 2):
def new generation   total 9920K, used 8846K [0x303c0000, 0x30e80000, 0x31910000)
Event: 227.605 GC heap after
Heap after GC invocations=4 (full 2):
def new generation   total 9920K, used 3K [0x303c0000, 0x30e80000, 0x31910000)
Deoptimization events (0 events):
No events
Internal exceptions (10 events):
Event: 5.294 Thread 0x0104d400 Threw 0x306303a0 at C:\re\jdk7u51\527\hotspot\src\share\vm\prims\jvm.cpp:1244
Event: 5.295 Thread 0x0104d400 Threw 0x3064c148 at C:\re\jdk7u51\527\hotspot\src\share\vm\prims\jvm.cpp:1244
Event: 43.541 Thread 0x0104d400 Threw 0x303c0320 at C:\re\jdk7u51\527\hotspot\src\share\vm\prims\jvm.cpp:1244
Event: 43.575 Thread 0x0104d400 Threw 0x303c3488 at C:\re\jdk7u51\527\hotspot\src\share\vm\prims\jvm.cpp:1244
Event: 43.575 Thread 0x0104d400 Threw 0x303c54d8 at C:\re\jdk7u51\527\hotspot\src\share\vm\prims\jvm.cpp:1244
Event: 155.264 Thread 0x0104d400 Threw 0x30802848 at C:\re\jdk7u51\527\hotspot\src\share\vm\prims\jvm.cpp:1244
Event: 227.550 Thread 0x0104d400 Threw 0x303c05f8 at C:\re\jdk7u51\527\hotspot\src\share\vm\prims\jvm.cpp:1244
Event: 227.551 Thread 0x0104d400 Threw 0x303c2758 at C:\re\jdk7u51\527\hotspot\src\share\vm\prims\jvm.cpp:1244
Event: 227.552 Thread 0x0104d400 Threw 0x303c5c50 at C:\re\jdk7u51\527\hotspot\src\share\vm\prims\jvm.cpp:1244
Event: 227.556 Thread 0x0104d400 Threw 0x304074f8 at C:\re\jdk7u51\527\hotspot\src\share\vm\prims\jvm.cpp:1244
Events (10 events):
Event: 227.589 Executing VM operation: RevokeBias
Event: 227.589 Executing VM operation: RevokeBias done
Event: 227.589 Executing VM operation: BulkRevokeBias
Event: 227.589 Executing VM operation: BulkRevokeBias done
Event: 227.604 Executing VM operation: GenCollectForAllocation
Event: 227.605 Executing VM operation: GenCollectForAllocation done
Dynamic libraries:
0x010c0000 - 0x010ef000           C:\Windows\SysWOW64\java.exe
0x77220000 - 0x773a0000           C:\Windows\SysWOW64\ntdll.dll
0x75250000 - 0x75360000           C:\Windows\syswow64\kernel32.dll
0x75810000 - 0x75857000           C:\Windows\syswow64\KERNELBASE.dll
0x750d0000 - 0x75170000           C:\Windows\syswow64\ADVAPI32.dll
0x75610000 - 0x756bc000           C:\Windows\syswow64\msvcrt.dll
0x756c0000 - 0x756d9000           C:\Windows\SysWOW64\sechost.dll
0x768c0000 - 0x769b0000           C:\Windows\syswow64\RPCRT4.dll
0x74c80000 - 0x74ce0000           C:\Windows\syswow64\SspiCli.dll
0x74c70000 - 0x74c7c000           C:\Windows\syswow64\CRYPTBASE.dll
0x76a50000 - 0x76b50000           C:\Windows\syswow64\USER32.dll
0x769c0000 - 0x76a50000           C:\Windows\syswow64\GDI32.dll
0x769b0000 - 0x769ba000           C:\Windows\syswow64\LPK.dll
0x76c10000 - 0x76cad000           C:\Windows\syswow64\USP10.dll
0x72870000 - 0x72a0e000           C:\Windows\WinSxS\x86_microsoft.windows.common-controls_6595b64144ccf1df_6.0.7601.17514_none_41e6975e2bd6f2b2\COMCTL32.dll
0x76dc0000 - 0x76e17000           C:\Windows\syswow64\SHLWAPI.dll
0x76740000 - 0x767a0000           C:\Windows\system32\IMM32.DLL
0x76cc0000 - 0x76d8c000           C:\Windows\syswow64\MSCTF.dll
0x56090000 - 0x5614f000           C:\Program Files (x86)\Java\jre7\bin\msvcr100.dll
0x6d8e0000 - 0x6dc60000           C:\Program Files (x86)\Java\jre7\bin\client\jvm.dll
0x72f00000 - 0x72f07000           C:\Windows\SysWOW64\WSOCK32.dll
0x75a80000 - 0x75ab5000           C:\Windows\syswow64\WS2_32.dll
0x771f0000 - 0x771f6000           C:\Windows\syswow64\NSI.dll
0x74460000 - 0x74492000           C:\Windows\SysWOW64\WINMM.dll
0x75a70000 - 0x75a75000           C:\Windows\syswow64\PSAPI.DLL
0x6d750000 - 0x6d75c000           C:\Program Files (x86)\Java\jre7\bin\verify.dll
0x5da50000 - 0x5da70000           C:\Program Files (x86)\Java\jre7\bin\java.dll
0x5b3f0000 - 0x5b403000           C:\Program Files (x86)\Java\jre7\bin\zip.dll
0x10000000 - 0x10682000           C:\Users\abey\Documents\Code\ConcordContentLoadingOpt\utils\build\tools\flex\4.6.0_Air4.0\lib\aot\lib\llvm.dll
0x65710000 - 0x657fb000           C:\Windows\SysWOW64\dbghelp.dll
VM Arguments:
jvm_args: -Djava.util.Arrays.useLegacyMergeSort=true -Xms32m -Xmx64m
java_command: com.adobe.air.ipa.BitcodeOptimizer C:\Users\abey\Documents\Code\ConcordContentLoadingOpt\utils\build\flex\..\..\..\consumer\www\devices\AOTBuildOutput5889547474422064649.tmp\BitcodeOptimizer_opts.ser
Launcher Type: SUN_STANDARD
Environment Variables:
JAVA_HOME=../tools/java/win32/jdk1.6.0_16
PATH=C:\Program Files (x86)\AMD APP\bin\x86_64;C:\Program Files (x86)\AMD APP\bin\x86;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\ATI Technologies\ATI.ACE\Core-Static;C:\Program Files (x86)\MySQL\MySQL Utilities 1.3.4\;C:\Program Files\TortoiseSVN\bin;C:\Program Files\Java\jre7\bin
USERNAME=abey
OS=Windows_NT
PROCESSOR_IDENTIFIER=Intel64 Family 6 Model 42 Stepping 7, GenuineIntel
TOPICS
Performance issues
Views
671
Translate
Translate
Report
Report
Community guidelines
community guidelines
Adobe Employee ,
Mar 19, 2014 Mar 19, 2014
LATEST
Could you please open a new bug report on this over at bugbase.adobe.com? When adding the bug, please include the sample code or an application so we can quickly test this out internally. Once the bug has been added would you mind posting back with the URL so that others affected can add their votes and comments.
Thanks for reporting,
Nimit
Votes
Translate
Translate
Report
Report
