Hi all,
I'm building my playbar in Flash and everythign is going smoothly.
I was looking for a way to show my glossary throughout the movie and I set up some advanced actions to test this out within captivate. I did it this way as I didn't see a variable for this specific thing.
So is there a way to call to, reach and activate these actions through flash and my playbar?
I have used advanced actions to show/hide a glossary that is displayed for the rest of the project, but only with advanced actions, not with Flash, not with a button on the playbar.
The actions work great through captivate, but the things that I am having a tough time with and why i was asking about the actions scenario, is that both the Glossary and Table of Contents don't seem to ahve their own variables or variables that actually work.
We really want this playbar to work completely through flash so that we can just customize it for every project but if it isn't meant to be, then that is ok.
No associated variables, but to show/hide it you can create a user variable (just like for other objects you want to show/hide), mostly I label it v_visib. And I give it a default value of 0, will act as a boolean.
To have a button that toggles the widget on/off, you'll need a conditional action:
IF v_visib is equal to 0
Show TOC
Assign v_visib with 1
ELSE
Hide TOC
Assign v_visib with 0
Pretty simple, I don't like to do programming with AS or JS when it can be done in an easier way.
Lilybiri
Lily,
Thanks for the reply and sorry for the late reply on my part. Just trying to get this thing working. 😃
So, I took what you said with the action and I will definitely be using that but I also found a way to do what I was trying to do, which was reach a user created variable. It's pretty simple, honestly. It was just a matter of finding the code. So, if you wanted to display a certain usermade variable as text in your movie, you would just creat something like this below:
var myRoot:MovieClip = MovieClip(root);
var mainmov:MovieClip = MovieClip(myRoot.parent.root);
textfield.text = mainmov.cpEIGetValue('m_VarHandle.Your_Text');
and that's really all you have to do to read it! obviously it's a little more involved if you want to use it as a Boolean or something else with your actionscript but at least now I know how to access my own variables. Thanks for your help!
