I am using Robohelp 10, and I'm generating chm and pdf format. Is it possible to change the typeface and font size in the TOC, Index, and Glossary for pdf?
Thanks in advance.
You would need to generate a Word document rather than a PDF, make the style changes there, then generate the PDF.
Thanks, Peter. I thought there's a way to do this directly in Robohelp.
Not directly. The nearest is that when you generate the print layout, you have an option to generate to a Word template. You could create a template with the required fonts and then you would get what you want each time. However, that's not really within Rh.
