My project is forwarding an RTMP stream to an RTMFP (multicast stream) using a server action script. In forwarding this stream, the AMSCore process keeps consuming memory. This consumption of memory requires the system to be rebooted repeated. How can this be prevented?
Are you using builtin multicast application(server side action script) to consume rtmp and broadcast rtmfp.If not, please try to use sample multicast aplication that comes as part of default installation and let us know the results.
I did not think I could use the sample multicast application with my
project's software. Instead, I compared the outbound NetConnection and
NetStream code in the sample application with the outbound NetConnection
and NetStream code in my project's multicast server actionscript. One of
differences I discovered is that my project's application connected to the
rtmfp group with the following call:
nc_connect..connect("rtmfp:");
while the sample called:
nc.connect(resetUriProtocol(streamContext.client.uri, "rtmfp"));
Therefore, in my project's actionscript, I replaced connection to the
"rtmfp:" serverless group with a connection to the application uri:
net_connect.connect("rtmfp://127.0.0.1:" + port + "/" + application.name)
This change fixed the excessive memory consumption. So, why does the
connection to serverless network endpoint consume memory on Windows Server
2008 R2 to the point that all of the virtual memory is used or it crashes
the system?
Scott F. Wilson
Principal Software Engineer
Raytheon SAS
Marlborough, MA 01752
Phone: 508-490-3123
Fax: 508-490-1366
