After looking through online forums and video tutorials...
I am still faced with errors loading an external swf into my main swf (full stage width).
In my main.swf.....i have several scenes.
On one of those scenes I have an external SWF which loads to the size of my main.swf stage.
That works fine...
BUT
I now want to close the external swf on a button (in my external swf) and go back to one of my scenes in my main.SWF
I have read many forums which talk about dispatchEvent
I have tried these methods and I am still faced with errors.
I just want a button on my external.swf that closes/unloads/removes itself.......so the user can continue in the MAIN.SWF after they have played EXTERNAL.SWF.
in actionscript 2 this was a doddle,
in as3 it is an unnecessary pain in my rectum
sorry if I have missed much out
any help would be much appreciated
jayquery
Try changing the main file loader code to more like the following (blue is new😞
var defaultSWF:URLRequest = new URLRequest("gametestG.swf");
var loader:Loader = new Loader();
loader.contentLoaderInfo.addEventListener(Event.COMPLETE, loaderCompleteHandler);
loader.load(defaultSWF);
function loaderCompleteHandler(evt:Event):void {
MovieClip(evt.target.content).addEventListener("closeChild", onChildClose);
addChild(loader);
function onChildClose(event:Event):void {
loader.unloadAndStop();
r
It would be appropriate to follow the direction you say you found where the swf dispatches an event when it wants to be closed. When you load the swf you assign an event listener to it in the main file for the event that it will generate. You need to do this after the swf has completely loaded. Then just have the swf dispatch said event via the button to close it and the main file should hear it and process unloading the Loader that brought the swf in.
If you show the code that you tried that didn't producethe desired result it should help to get it to work.
I have this code on my main.SWF scene....
var Xpos:Number = 800;
var Ypos:Number= 600;
var swf:MovieClip;
addChild(loader);
childSwif.addEventListener("closeChild", onChildClose);
removeChild(childSwif);
childSwif.unloadAndStop();
that loads to my stage size which is all good
on my external swf I had ....
back_btn.addEventListener(MouseEvent.CLICK,unloadSelf);
function unloadSelf (e:MouseEvent){
dispatchEvent("closeChild");
Thanks for the reply
jayquery
addChild(loader);
removeChild(loader);
Can you help me solve this problem..?
I have a dispatchEvent to
I put a button on my external.swf that closes/unloads/removes itself.......so the user can continue in the MAIN.SWF after load the EXTERNAL.SWF.
I have tried these methods and the child file is still not close/unload.
btnNKa.addEventListener(MouseEvent.CLICK, loadNK1);
var myLoaderNK:Loader = new Loader();
function movieLoaded(event:Event):void {
myLoaderNK.x=0;
myLoaderNK.y=0;
myLoaderNK.scaleX=1;
myLoaderNK.scaleY=1;
stage.addChild(myLoaderNK);
myLoaderNK.content.addEventListener("killMe", killLoadedClip);
function killLoadedClip(event:Event):void{
event.target.removeEventListener("killMe", killLoadedClip)
stage.removeChild(myLoaderNK);
myLoaderNK.unload();
function loadNK1(MouseEvent):void {
var urlNK1:URLRequest=new URLRequest("sampel_file.swf");
myLoaderNK.load(urlNK1);
And this code on my child SWF (sampel_file.SWF) scene....
tmbl_exit.addEventListener(MouseEvent.CLICK, fl_close);
function fl_close(event:MouseEvent):void
dispatchEvent(new Event("killMe", true));
You do not appear to have anything that calls the movieLoaded function. See the very first line of blue code in my example above.
its workin.. thank u very much..
You're welcome
