Hi there
Ive tried to make my tank in my game shoot, all the code that is there works but when i push space to shoot which is my shooting key it does not shoot I really need help with this and I would appriciate anyone that could help
listed below should be the correct code
//checking if the space bar is pressed and shooting is allowed
if(evt.keyCode == 32 && shootAllow){
//making it so the user can't shoot for a bit
shootAllow = false;
//declaring a variable to be a new Bullet
var newBullet:Bullet = new Bullet();
//changing the bullet's coordinates
newBullet.y = tank_mc.y + tank_mc.width/2 - newBullet.width/2;
newBullet.x = tank_mc.x;
//then we add the bullet to stage
addChild(newBullet);
listed below is my entire code
import flash.display.MovieClip;
//declare varibles to create mines
//how much time before allowed to shoot again
var cTime:int = 0;
//the time it has to reach in order to be allowed to shoot (in frames)
var cLimit:int = 12;
//whether or not the user is allowed to shoot
var shootAllow:Boolean = true;
var minesInGame:uint;
var mineMaker:Timer;
var cursor:MovieClip;
var index:int=0;
var tankMine_mc:MovieClip;
var antiTankmine_mc:MovieClip;
var maxHP:int = 100;
var currentHP:int = maxHP;
var percentHP:Number = currentHP / maxHP;
function initialiseMine():void
minesInGame = 15;
//create a timer fires every second
mineMaker = new Timer(6000, minesInGame);
//tell timer to listen for Timer event
mineMaker.addEventListener(TimerEvent.TIMER, createMine);
//start the timer
mineMaker.start();
function createMine(event:TimerEvent):void
//var tankMine_mc:MovieClip;
//create a new instance of tankMine
tankMine_mc = new Mine();
//set the x and y axis
tankMine_mc.y = 513;
tankMine_mc.x = 1080;
// adds mines to stage
addChild(tankMine_mc);
tankMine_mc.addEventListener(Event.ENTER_FRAME, moveHorizontal);
function moveHorizontal(evt:Event):void{
evt.target.x -= Math.random()*5;
if (evt.target.x >= stage.stageWidth)
evt.target.removeEventListener(Event.ENTER_FRAME, moveHorizontal);
removeChild(DisplayObject(evt.target));
initialiseMine();
var atmInGame:uint;
var atmMaker:Timer;
function initialiseAtm():void
atmInGame = 15;
atmMaker = new Timer(8000, minesInGame);
atmMaker.addEventListener(TimerEvent.TIMER, createAtm);
//start the timer
atmMaker.start();
function createAtm(event:TimerEvent):void
//var antiTankmine_mc
antiTankmine_mc = new Atm();
antiTankmine_mc.y = 473;
antiTankmine_mc.x = 1080;
addChild(antiTankmine_mc);
antiTankmine_mc.addEventListener(Event.ENTER_FRAME, moveHorizontal);
function moveHorizontal_2(evt:Event):void{
evt.target.x -= Math.random()*10;
initialiseAtm();
function moveForward():void{
bg_mc.x -=10;
function moveBackward():void{
bg_mc.x +=10;
var tank_mc:Tank;
// create a new Tank and put it into the variable
// tank_mc
tank_mc= new Tank;
// set the location ( x and y) of tank_mc
tank_mc.x=0;
tank_mc.y=375;
// show the tank_mc on the stage.
addChild(tank_mc);
stage.addEventListener(KeyboardEvent.KEY_DOWN, onMovementKeys);
//creates the movement
function onMovementKeys(evt:KeyboardEvent):void
//makes the tank move by 10 pixels right
if (evt.keyCode==Keyboard.D)
tank_mc.x+=5;
//makes the tank move by 10 pixels left
if (evt.keyCode==Keyboard.A)
tank_mc.x-=5
shootAllow = false;
if (tank_mc.hitTestObject(antiTankmine_mc))
//tank_mc.gotoAndPlay("hit");
currentHP -= 10;
// remove anti tank mine
removeChild(antiTankmine_mc);
if (tank_mc.hitTestObject(tankMine_mc))
currentHP -= 10;
removeChild(tankMine_mc);
//var maxHP:int = 100;
//var currentHP:int = maxHP;
//var percentHP:Number = currentHP / maxHP;
//Incrementing the cTime
//checking if cTime has reached the limit yet
if(cTime < cLimit){
cTime ++;
} else {
//if it has, then allow the user to shoot
shootAllow = true;
//and reset cTime
cTime = 0;
function updateHealthBar():void
percentHP = currentHP / maxHP;
healthBar.barColor.scaleX = percentHP;
if(currentHP <= 0)
currentHP = 0;
trace("Game Over");
updateHealthBar();
USe the trace function to analyze what happens and what fails to happen in the code you showed. trace the conditional values to see if they are set up to allow a shot when you press the key
