I am having a hard time getting my autosuggest to work. I have a cfinput where a person can type in a last name. I then want to return the full name and employee ID of the person and bind them to two different cfinputs. Here is my cfc:
<cfcomponent output="false">
<cffunction name="getPerson" access="remote" returntype="array">
<cfargument name="search" type="any" required="false" default="">
<!--- Define variables --->
<cfset var data = "">
<cfset var result = ArrayNew(2)>
<cfset var i=0>
<!--- Query Location Table --->
<cfquery name="data" datasource="ds" cachedwithin="#CreateTimeSpan(0,14,0,0)#">
SELECT PERSONNEL.NAME_LAST_FIRST_MID, PERSONNEL.EMPLID, MST_LD.EMPLID
FROM MST_LD LEFT JOIN PERSONNEL ON MST_LD.SYREDU_SUID = PERSONNEL.EMPLID
WHERE ((MST_LD.PRIMARY_AFFIL_STATUS)= 'Active') AND ((MST_LD.EMPLID) Is Not Null)) AND PERSONNEL.NAME_LAST like <cfqueryparam cfsqltype="cf_sql_varchar" value="#ucase(arguments.search)#%" />
order by name_last, name_first , EMPLID ASC
</cfquery>
<cfloop index="i" from="1" to="#data.RecordCount#">
<cftry>
<cfset result[1]=data.NAME_LAST_FIRST_MID>
<cfset result[2]=data.EMPLID>
<cfcatch></cfcatch>
</cftry>
</cfloop>
<!--- And return it as a List --->
<cfreturn result>
</cffunction>
</cfcomponent>
So what isn't working, specifically? What are you getting back at the client end? Also, you might want to post the <cfform> code block so we can see if anything is wrong with the bind(s).
Lastly, you should consider not using <cfform> and <cfinput>, for a number of practical reasons. Here are some ideas for suitable alternatives: https://github.com/cfjedimaster/ColdFusion-UI-the-Right-Way.
-Carl V.
Message was edited by: Carl Von Stetten
