Does anyone have the same experience in CP7 not being able to refresh SumTotal LMS on exit or update the course status? Any help would be greatly appreciated.
Thanks in advance
Hello ,
Are you Publishing as a Scorm 2004 or Scorm 1.2 ? Try switching that .
Please go to Quiz > Quiz Prefrences > Reporting > Advanced
Then check the option which says Send Data on every slide .
Thank you Himashu,
I am publishing SCORM 1.2, which is what is required at this time. I will try checking the option “Send Data on every slide” and let you know what happens.
"Don't bother about being modern. Unfortunately it is the one thing that, whatever you do, you cannot avoid."
- Salvador Dali
Did this work for you? I am having the same issue with exiting Captivate 7 courses in my LMS (Intellum). I have tried every close option imaginable, and it still does not direct me back to the correct page in the LMS.
We've experienced this many times in the past and on our current LMS Learn.com, which is now Taleo.
The problem came when we started using the SCORM 2004 player which launches courses in a frameset. THe Previous 1.2 player launched courses in a popup window. We had to parse the url to exit 1.2 courses run in a 2004 player to the course menu.
The following function (mod_close()) is called after the terminate, we parse all of the user and course info so we can return them to the menu:
function getUrlVars()
var vars = [], hash;
var hashes = window.top.location.href.slice(window.top.location.href.indexOf('?') + 1).split('&');
for(var i = 0; i < hashes.length; i++)
hash = hashes.split('=');
vars.push(hash[0]);
vars[hash[0]] = hash[1];
return vars;
function mod_close()
window.top.location="/learn6.asp?sessionid="+(getUrlVars()['sessionid'])+"&rootclass="+(getUrlVars()['rootclass'])+"&classid="+(getUrlVars()['classid'])+"&c=&courseid=0&mode=";
