May 30, 2007 4:40 PM
Flash Player - Terminal Server/Remote Desktop
Like (0)
quote:
Originally posted by: peteweird
No go on the free distribution... I am REALLY lovin' Adobe on this one.
We tried the fix ajgalbraith98 suggests via RDP (no users on the system) without luck. We then tried it from the console and suddenly a random few users could access flash. Unfortunately for Adobe I don't consider this a fix.
Next we are going to try killing a user profile and rebuilding it from scratch. That'll make a happy customer for sure...
quote:
Originally posted by: Terminal Server Tech
I have solved this issue by changing the permissons to "READ" for everyone on the two registry keys below. (Ensure it is replicated to the child objects.)
[HKEY_CLASSES_ROOT\TypeLib\{D27CDB6B-AE6D-11CF-96B8-444553540000}]
[HKEY_CLASSES_ROOT\CLSID\{D27CDB6B-AE6D-11CF-96B8-444553540000}]
Next time the users login, it works.
By default, EVERYONE is denied. Hence the error.
Hello,
I have the same issue, but your registry tip didn't work :-(
My server is a Windows 2003 Terminal Server with Internet Explorer 8 installed.
Surfing to a page with flash on it as administrator works without problems.
But surfing to it as a normal user, the browser just shows this little red cross in the upper left corner of the box in which the flashplayer should take place.
Does anybody have a tip for me?
Sascha
Well I had the same issues and spent 3 days looking on the internet for solutions and trying many of them and nothing worked by itself. But when I took 3 of the solutions and mixed them together it work like a charm. Below is what I did to get my terminal server users able to use flash.
1. Logon to the server as the local administrator or with an account with admin rights that does not map a home folder like H:. if your home folder is mapped it the installer will think windows directory is h:\windows instead of c:\windows. I used the local administrator account.
2. Download the Adobe flash uninstaller from here http://kb2.adobe.com/cps/141/tn_14157.html
3. Put it in a folder like c:\temp on the terminal server
4. Open a command prompt and go the folder you saved the uninstall_flash_player.exe in
5. At the prompt type uninstall_flash_player.exe /clean
6. Click the Details button. If it lists any files as "Delete on reboot", then reboot now. Otherwise, just carry on.
7. Download the latest Flash Player (10 in this instance) as a standalone version and save it to the hard drive/ network share. Get the standalone version 10 from here: http://fpdownload.macromedia.com/get/flashplayer/current/licensing/win /install_flash_player_10_active_x.exe
8. Use the Control Panel Add/Remove programs method to install it. This ensures that the Windows install notification API triggers correctly (as opposed to executing change user /install in a command prompt).
9. Use regedit and find the following 3 keys and do the same for all 3 keys: right click the key select permissions, select everyone and remove before clicking apply select the Advanced button and click the Replace permissions on all child objects, click Ok then Yes on the security window then Apply. Now Add everyone and click on Read then Advance button and click the Replace permissions on all child objects, click Ok then Yes on the security window then Ok. Now repeat on the next 2 keys. (By clicking Read then Advanced it selects a few other permissions so please do it this way)
a. HKEY_CLASSES_ROOT\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}
b. HKEY_CLASSES_ROOT\CLSID\{D27CDB70-AE6D-11cf-96B8-444553540000}
c. HKEY_CLASSES_ROOT\TypeLib\{D27CDB6B-AE6D-11CF-96B8-444553540000}
10. I then logged off and logged on as a standard user and went to a site needing Flash and it worked.
11. I then had some users try it without even logging out and it work for them.
This is what worked for me on all 3 of the 2003 Terminal Servers with IE7 needing Flash 10.
I hope this might help someone else as this has driven me up a wall…
Russ
The above solution did not work for my environment. I tried this on a "downed" XenApp server and no luck. Anyone have a different solution?
CORRECTION:
The solution worked with a few changes.
1. After the you uninstall flash, reboot for good measure.
2. Use Add/Remove Programs to install the flash installer mentioned above
a. once install is complete DO NOT HIT NEXT
b. EDIT the registry permissions as mentioned above with the following exceptions:
* DO NOT remove "Everyone" instead give it READ permission.
* Click Advanced, click on Replace permission on all child object
* click apply, click ok,
c. At the permissions window, click apply and ok
3. NOW hit Next and Finish
4. Reboot not required, but YMMV
Please let me know if this works for anyone.
I just had this problem crop again after having a new SBS server installed. Where prior to the new SBS migration a user was able to browse a website using Flash without a problem, after the migration the user was being prompted to install an ActiveX control, which of course they couldn't.
I recalled the problem had occurred previously after a Flash upgrade and that the solution was some sort of registry edit. A quick google led me to this thread.
I tried the solution given by Terminal Server Tech, but it didn't work:
But when applied the permission changes to the 3 keys listed by RussCrow it did work:
I didn't find it necessary to do any of the other steps listed.
Only added the "Read" permission (applied to all sub-keys) to the group "everyone" on the 3 above keys.
Annoying issue, but thanks, changing the perms on the 3 keys worked great for me. No Reboot required.
Thanks!
This is an old thread, but still an issue. I've got Server 2003 x64 ed, so the registry keys aren't the same.
HKEY_CLASSES_ROOT\Wow6432Node\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540 000}
HKEY_CLASSES_ROOT\Wow6432Node\CLSID\{D27CDB70-AE6D-11cf-96B8-444553540 000}
HKEY_CLASSES_ROOT\Wow6432Node\TypeLib\{D27CDB6B-AE6D-11CF-96B8-4445535 40000}
Does Adobe have an official stance on their support or lack thereof for terminal servers?
Same error on 2008 R2
I have found a solutions to fix the error.
Set Account Control Settings to Never notify
Set reg key on all users.
Windows Registry Editor Version 5.00
[HKEY_CURRENT_USER\Software\Microsoft\SystemCertificates\TrustedPublis her\Certificates\FDF01DD3F37C66AC4C779D92623C77814A07FE4C]
"Blob"=hex:03,00,00,00,01,00,00,00,14,00,00,00,fd,f0,1d,d3,f3,7c,66,ac ,4c,77,\
9d,92,62,3c,77,81,4a,07,fe,4c,04,00,00,00,01,00,00,00,10,00,00,00,e0, 58,f6,\
0a,9f,4b,b0,38,21,15,f3,1c,97,8e,88,c8,0f,00,00,00,01,00,00,00,14,00, 00,00,\
7e,f1,31,96,ec,47,f2,ab,70,72,d9,3a,67,9a,e2,1c,13,c7,64,eb,14,00,00, 00,01,\
00,00,00,14,00,00,00,4a,4d,24,78,5b,74,74,8d,38,31,33,4e,36,4c,04,0f, 1a,77,\
a5,cc,19,00,00,00,01,00,00,00,10,00,00,00,05,34,5a,e8,e6,ba,19,61,ac, 2e,08,\
30,06,86,8e,f0,18,00,00,00,01,00,00,00,10,00,00,00,3c,31,c0,95,e6,51, fa,66,\
4c,bf,b1,98,e9,c0,c0,08,4b,00,00,00,01,00,00,00,44,00,00,00,37,00,42, 00,38,\
00,39,00,34,00,34,00,42,00,41,00,38,00,41,00,44,00,30,00,45,00,46,00, 44,00,\
46,00,30,00,45,00,30,00,31,00,41,00,34,00,33,00,45,00,46,00,36,00,32, 00,42,\
00,45,00,43,00,44,00,30,00,5f,00,00,00,20,00,00,00,01,00,00,00,1a,05, 00,00,\
30,82,05,16,30,82,03,fe,a0,03,02,01,02,02,10,15,e5,ac,0a,48,70,63,71, 8e,39,\
da,52,30,1a,04,88,30,0d,06,09,2a,86,48,86,f7,0d,01,01,05,05,00,30,81, b4,31,\
0b,30,09,06,03,55,04,06,13,02,55,53,31,17,30,15,06,03,55,04,0a,13,0e, 56,65,\
72,69,53,69,67,6e,2c,20,49,6e,63,2e,31,1f,30,1d,06,03,55,04,0b,13,16, 56,65,\
72,69,53,69,67,6e,20,54,72,75,73,74,20,4e,65,74,77,6f,72,6b,31,3b,30, 39,06,\
03,55,04,0b,13,32,54,65,72,6d,73,20,6f,66,20,75,73,65,20,61,74,20,68, 74,74,\
70,73,3a,2f,2f,77,77,77,2e,76,65,72,69,73,69,67,6e,2e,63,6f,6d,2f,72, 70,61,\
20,28,63,29,31,30,31,2e,30,2c,06,03,55,04,03,13,25,56,65,72,69,53,69, 67,6e,\
20,43,6c,61,73,73,20,33,20,43,6f,64,65,20,53,69,67,6e,69,6e,67,20,32, 30,31,\
30,20,43,41,30,1e,17,0d,31,30,31,32,31,35,30,30,30,30,30,30,5a,17,0d, 31,32,\
31,32,31,34,32,33,35,39,35,39,5a,30,81,dd,31,0b,30,09,06,03,55,04,06, 13,02,\
55,53,31,13,30,11,06,03,55,04,08,13,0a,43,61,6c,69,66,6f,72,6e,69,61, 31,11,\
30,0f,06,03,55,04,07,13,08,53,61,6e,20,4a,6f,73,65,31,23,30,21,06,03, 55,04,\
0a,14,1a,41,64,6f,62,65,20,53,79,73,74,65,6d,73,20,49,6e,63,6f,72,70, 6f,72,\
61,74,65,64,31,1c,30,1a,06,03,55,04,0b,14,13,49,6e,66,6f,72,6d,61,74, 69,6f,\
6e,20,53,79,73,74,65,6d,73,31,3e,30,3c,06,03,55,04,0b,13,35,44,69,67, 69,74,\
61,6c,20,49,44,20,43,6c,61,73,73,20,33,20,2d,20,4d,69,63,72,6f,73,6f, 66,74,\
20,53,6f,66,74,77,61,72,65,20,56,61,6c,69,64,61,74,69,6f,6e,20,76,32, 31,23,\
30,21,06,03,55,04,03,14,1a,41,64,6f,62,65,20,53,79,73,74,65,6d,73,20, 49,6e,\
63,6f,72,70,6f,72,61,74,65,64,30,81,9f,30,0d,06,09,2a,86,48,86,f7,0d, 01,01,\
01,05,00,03,81,8d,00,30,81,89,02,81,81,00,e3,ac,5b,0e,74,3c,b8,b7,ba, 54,55,\
45,2d,a2,57,31,ef,aa,b6,f5,00,b4,ea,5e,1f,9f,8d,10,2b,f5,41,b2,f1,a4, 30,e3,\
43,e2,f8,0f,eb,10,bd,9f,cb,d6,35,1a,56,2c,c6,d5,d1,13,6b,3a,5e,a2,46, 92,8b,\
97,7a,a8,5d,8d,93,25,e5,c3,45,56,b7,c0,0f,b2,ac,0f,82,ae,54,15,ce,44, b6,2b,\
2a,5a,8d,0f,72,fb,a7,80,4c,d6,69,2a,36,f4,8e,e8,bc,24,a7,b5,9b,99,3f, b0,78,\
4a,31,63,35,fa,42,1f,d6,61,4b,97,e7,f6,4c,5d,c1,69,02,03,01,00,01,a3, 82,01,\
7b,30,82,01,77,30,09,06,03,55,1d,13,04,02,30,00,30,0e,06,03,55,1d,0f, 01,01,\
ff,04,04,03,02,07,80,30,40,06,03,55,1d,1f,04,39,30,37,30,35,a0,33,a0, 31,86,\
2f,68,74,74,70,3a,2f,2f,63,73,63,33,2d,32,30,31,30,2d,63,72,6c,2e,76, 65,72,\
69,73,69,67,6e,2e,63,6f,6d,2f,43,53,43,33,2d,32,30,31,30,2e,63,72,6c, 30,44,\
06,03,55,1d,20,04,3d,30,3b,30,39,06,0b,60,86,48,01,86,f8,45,01,07,17, 03,30,\
2a,30,28,06,08,2b,06,01,05,05,07,02,01,16,1c,68,74,74,70,73,3a,2f,2f, 77,77,\
77,2e,76,65,72,69,73,69,67,6e,2e,63,6f,6d,2f,72,70,61,30,13,06,03,55, 1d,25,\
04,0c,30,0a,06,08,2b,06,01,05,05,07,03,03,30,71,06,08,2b,06,01,05,05, 07,01,\
01,04,65,30,63,30,24,06,08,2b,06,01,05,05,07,30,01,86,18,68,74,74,70, 3a,2f,\
2f,6f,63,73,70,2e,76,65,72,69,73,69,67,6e,2e,63,6f,6d,30,3b,06,08,2b, 06,01,\
05,05,07,30,02,86,2f,68,74,74,70,3a,2f,2f,63,73,63,33,2d,32,30,31,30, 2d,61,\
69,61,2e,76,65,72,69,73,69,67,6e,2e,63,6f,6d,2f,43,53,43,33,2d,32,30, 31,30,\
2e,63,65,72,30,1f,06,03,55,1d,23,04,18,30,16,80,14,cf,99,a9,ea,7b,26, f4,4b,\
c9,8e,8f,d7,f0,05,26,ef,e3,d2,a7,9d,30,11,06,09,60,86,48,01,86,f8,42, 01,01,\
04,04,03,02,04,10,30,16,06,0a,2b,06,01,04,01,82,37,02,01,1b,04,08,30, 06,01,\
01,00,01,01,ff,30,0d,06,09,2a,86,48,86,f7,0d,01,01,05,05,00,03,82,01, 01,00,\
aa,eb,b7,99,4b,48,53,45,d8,5f,18,5a,3a,c9,e2,61,e5,33,15,65,3e,15,b8, 1c,66,\
7e,a2,c4,74,57,ab,0c,7f,3c,2d,e2,45,fb,25,db,95,6a,c9,48,10,db,ce,d9, 2a,71,\
1e,fc,db,1e,cd,e1,ec,37,96,81,cf,9b,bb,32,46,11,17,50,58,f3,3f,c6,21, 28,09,\
0b,88,a9,d4,82,fd,ac,5f,18,d1,00,ea,2c,64,09,2b,c2,1e,4e,86,d5,1f,8f, f5,94,\
13,6a,8b,54,68,34,27,64,0c,71,5a,47,a2,bc,cf,98,8f,f4,26,4c,f1,78,30, 44,d9,\
2f,f0,95,c4,40,10,34,88,c3,39,23,9c,a2,70,5b,5b,7e,15,f6,a5,8c,82,e4, c4,46,\
48,c0,03,23,ea,85,e9,66,84,41,7b,fa,a9,dc,8a,f9,fc,e8,0b,35,cd,ea,d3, d4,1c,\
1b,df,ab,ae,40,06,a9,fd,da,68,79,88,0c,b0,21,48,33,e2,58,91,e2,34,d1, 36,82,\
58,a7,80,03,cb,14,83,52,20,1f,76,8a,21,22,b8,ff,c4,63,fa,c0,88,59,b4, 15,f2,\
83,1e,b2,5f,7a,d8,d0,c0,8d,af,79,62,6b,67,5b,60,60,9a,af,0f,1b,00,28, a0,97,\
d6,fb,4a,11,de,b4
Copyright © 2011 Adobe Systems Incorporated. All rights reserved.
Use of this website signifies your agreement to the Terms of Use and Online Privacy Policy (updated 07-14-2009).
