• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Why is TOC and Index connected at the hip.
New Here ,
Apr 11, 2014 Apr 11, 2014
Why do you have to have TOC and Index tabs together? Why can't you have one without the other?
Views
422
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND ,
Hi there
It's possible to have a TOC and no  Index. It's also possible to have and Index and no TOC. Just  create a project that has nothing in the TOC or the Index and compile. I tested this earlier to confirm my suspicions and here is what I found.
Cheers... Rick
Votes
Translate
Translate
Report
Report
New Here ,
Apr 14, 2014 Apr 14, 2014
Thanks Rick,  I'll give it a try.
Worked great. I thought I might want some day to use the Index so I created a new index name called "Empty Index" and set it up as the one to use on a build and no Index tab after a build. Thanks again Rick;    Mike
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Jun 17, 2014 Jun 17, 2014
LATEST
Hi
You can hide tabs even after generating the Help file. You can have all three (TOC, Index and Search) or anyone or two of them as per your requirement. you just need to understand the internally javascript is running and you can make changes from the js files also. It it possible via editing the Whbar.js file from the project folder.
Say, for example- if you want to have only Content (TOC) and Search, and no Index tab; follow the below steps.
1. Edit the Whtbar.js file
2. Go to function addButton
3. Comment the code inside Else If (see below) and save the js file again.
4. Open index.htm file again, you will not see index tab anymore.
Same you can do for other tabs to hide them.
else if(sType=="idx")
        var svTitle="Index";
        /* Comment this code
sButton="<a title=\""+svTitle+"\" id=\"btnidx\" class=\"btnidx\" href=\"javascript:void(0);\" onclick=\"showIndex();return false;\">";
        if(!sI1)
            sI1=gsIIndex;
        if(!sI2)
            sI2=gsIIndexS;
        if(!sI4)
            sI4=gsIIndexS;
        goIdx=new button(sType,sTitle,nWidth,nHeight,sI1,sI2,sI3,sI4,sI5,sI6);
        gaObjBtns[nBtn]=goIdx;
        if(nStyle&BTN_TEXT)
            sText=goIdx.sText
        if(nStyle&BTN_IMG)
            sI=getImage(goIdx,svTitle);
        sButton+=genButton(sText,sI,nStyle);
        sButton+="</a>";
        bState=true;
comment code */
Votes
Translate
Translate
Report
Report
Resources
RoboHelp Documentation
Download Adobe RoboHelp
