hi there,
someone to help me. What did i do wrong ? My program shakes when i want to test it. I even couldn't touch the screen. Tks.
package {
import flash.display.*;
import flash.events.*;
import flash.text.*;
public class U2A3_JeuJumelage extends MovieClip {
private static const RANGS:int = 5;
private static const COLONNES:int = 6;
private static const RANG_HAUTEUR:Number = 130;
private static const COLONNE_LARGEUR:Number = 130;
private static const RANG_DECALAGE:Number = 60;
private static const COLONNE_DECALAGE:Number = -110;
private var carteUn:Cartes;
private var carteDeux:Cartes;
private var cartesRestantes:int = RANGS*COLONNES;
public function U2A3_JeuJumelage():void
var totalCartes:int = RANGS*COLONNES/2;
var paquetCartes:Array = new Array;
var intPointage:int;
for (var i: int=0; i < totalCartes; i++)
paquetCartes.push(i);
for (var c:int = 0; c < COLONNES; c++)
for (var r:int = 0; r < RANGS; r++)
var affichageCartes:Cartes = new Cartes();
affichageCartes.stop();
affichageCartes.x = c*COLONNE_LARGEUR+COLONNE_DECALAGE;
affichageCartes.y = r*RANG_HAUTEUR+RANG_DECALAGE;
var noRang = Math.floor(Math.random() * paquetCartes.length);
affichageCartes.rectoCarte = paquetCartes[noRang];
paquetCartes.splice(noRang, 1);
affichageCartes.addEventListener(MouseEvent.CLICK, clicSouris);
addChild(affichageCartes);
public function clicSouris(event:MouseEvent)
var carteChoisie:Cartes = (event.currentTarget as Cartes);
if (carteUn == null)
carteUn = carteChoisie;
carteUn.gotoAndStop(carteChoisie.rectoCarte + 2);
else if (carteUn == carteChoisie)
carteUn.gotoAndStop(1);
carteUn = null;
else if (carteDeux == null)
carteDeux = carteChoisie;
carteDeux.gotoAndStop(carteChoisie.rectoCarte + 2);
if (carteUn.rectoCarte == carteDeux.rectoCarte)
removeChild(carteUn);
removeChild(carteDeux);
carteUn = null;
carteDeux = null;
cartesRestantes = cartesRestantes - 2;
if (cartesRestantes == 0)
MovieClip(root).gotoAndStop("finPartie");
else
carteDeux.gotoAndStop(1);
carteDeux = null;
What do you mean when you say your program shakes? Do you get any compiler error messages?
No, i can't even touch the screen, because it shakes.
Tks.
You aren't doing a very good job of explaining what you mean. Based on your last response I'd tell you to run for cover as there appears to be an earthquake, a rather persistent one.
Exactly, it's like an earthquake. so i can't touch any button to run the program.
tks.
Taking a WAG, I would suspect what he's seeing is the way it flips through the timeline when you have a compile error.
ORDIYOH, do you have Strict mode on in the AS 3 settings, and if so are you seeing any compile errors?
