any solution for this...this is combobox compenent.
any solution?
use;
var m: Number;
var b: Number;
combo_box.addEventListener(MouseEvent.MOUSE_DOWN, startscrollF);
function startscrollF(event: MouseEvent): void {
paramF(combo_box.mouseY, combo_box.dropdown.verticalScrollPosition, combo_box.dropdown.height - 10, combo_box.dropdown.maxVerticalScrollPosition);
this.addEventListener(Event.ENTER_FRAME, scrollF);
stage.addEventListener(MouseEvent.MOUSE_UP, stopscrollF);
function scrollF(e: Event): void {
combo_box.dropdown.verticalScrollPosition = Math.rou
...Copy link to clipboard
you can reference the scrollbar using your cb's dropdown's verticalScrollBar property.
Try this: When a user puts their finger on the list to start scrolling, have a variable track where they put their finger down, and have a timer update the CB's scroll amount by how much they have moved their finger from the original area where they put it down.
An example of a code to go along with this is:
var start_finger_position:Number
combo_box.addEventListener(MouseEvent.MOUSE_OVER, fl_hover);
function fl_hover(event:MouseEvent):void
start_finger_position = mouseY
//insert timer listener and function here
//timer code:
combo_box.verticalScrollbar.scroll = combo_box.verticalScrollbar.scroll + (mouseY - start_finger_position)
(The timer updates the scroll, so have an interval of about 10-50)
sorry, i was try my best... i cant understand this coding work...need your help.. may i get the full coding?
var textFormat:TextFormat = new TextFormat();
textFormat.font = "Trebuchet MS";
textFormat.size = 50;
combobox.textField.setStyle("textFormat", textFormat);
combobox.rowCount = 8;
combobox.dropdown.rowHeight = 55;
combobox.dropdown.setRendererStyle("textFormat", textFormat);
combobox.addItem( {label: "BKB1"} );
combobox.addItem( {label: "BKB2"} );
combobox.addItem( {label: "BKB3"} );
combobox.addItem( {label: "BKB4"} );
combobox.addItem( {label: "BKB5"} );
combobox.addItem( {label: "BKB6"} );
combobox.addItem( {label: "BKB7"} );
combobox.addItem( {label: "BKB8"} );
combobox.addItem( {label: "BKB9"} );
combobox.addItem( {label: "BKB10"} );
combobox.addEventListener(Event.CHANGE, changeimage);
function changeimage(event:Event):void{
if (combobox.selectedItem.label=="BKB1")gotoAndStop(2);
if (combobox.selectedItem.label=="BKB2")gotoAndStop(3);
if (combobox.selectedItem.label=="BKB3")gotoAndStop(4);
if (combobox.selectedItem.label=="BKB4")gotoAndStop(5);
if (combobox.selectedItem.label=="BKB5")gotoAndStop(6);
if (combobox.selectedItem.label=="BKB6")gotoAndStop(7);
if (combobox.selectedItem.label=="BKB7")gotoAndStop(8);
if (combobox.selectedItem.label=="BKB8")gotoAndStop(9);
if (combobox.selectedItem.label=="BKB9")gotoAndStop(10);
if (combobox.selectedItem.label=="BKB10")gotoAndStop(11);
this my combobox coding...
thanks
again, the combobox has no verticalScrollBar property. use:
combobox.dropdown.verticalScrollBar as in
combobox.addEventListener(Event.OPEN,f);
function f(e:Event):void{
stage.invalidate();
this.addEventListener(Event.RENDER,ff);
function ff(e:Event):void{
combobox.dropdown.verticalScrollBar.visible = false;
this success hide vertical scroll bar.But i need use hand to scroll down without using vertical scroll bar.
Can help ? thanks a lot for help.
then use a mousedown listener to start a loop (like enterframe) that terminates on mouseup and repeatedly updates the combobox'es dropdown's verticalScrollPosition.
Need more help... can give example coding?
i was try use this coding but i cant coding it...
//timer code:
var m:Number;
var b:Number;
function startscrollF(event:MouseEvent):void {
paramF(combo_box.mouseY,combo_box.scrollPosition,combo_box.height-10,combo_box.maxScrollPosition);
this.addEventListener(Event.ENTER_FRAME,scrollF);
this.addEventListener(MouseEvent.MOUSE_UP,stopscrollF);
function scrollF(e:Event):void{
combo_box.scrollPosition=Math.round(Math.min(combo_box.mouseY*m+b,combo_box.maxScrollPosition));
function stopscrollF(e:Event):void{
this.removeEventListener(Event.ENTER_FRAME,scrollF);
function paramF(x1:Number,y1:Number,x2:Number,y2:Number):void{
m=(y1-y2)/(x1-x2);
b=m*x1-y1;
Scene 2, Layer 'As', Frame 1, Line 53 | 1119: Access of possibly undefined property scrollPosition through a reference with static type fl.controls:ComboBox. |
Scene 2, Layer 'As', Frame 1, Line 53 | 1119: Access of possibly undefined property maxScrollPosition through a reference with static type fl.controls:ComboBox. |
Scene 2, Layer 'As', Frame 1, Line 48 | 1119: Access of possibly undefined property maxScrollPosition through a reference with static type fl.controls:ComboBox. |
Scene 2, Layer 'As', Frame 1, Line 48 | 1119: Access of possibly undefined property scrollPosition through a reference with static type fl.controls:ComboBox. |
this is the error i get...
i apply this into combobox
var m:Number;
var b:Number;
combobox.addEventListener(MouseEvent.MOUSE_DOWN, startscrollF);
paramF(combobox.mouseY,combobox.scrollPosition,combobox.height-10,combobox.maxScrollPosition);
combobox.scrollPosition=Math.round(Math.min(combobox.mouseY*m+b,combobox.maxScrollPosition));
m=(y1-y2)/(x1-x2);
b=m*x1-y1;
try
var m:Number;
var b:Number;
paramF(combo_box.mouseY,combo_box.dropdown.verticalScrollPosition,combo_box.height-10,combo_box.dropdown.maxVerticalScrollPosition);
combo_box.dropdown.scrollPosition=Math.round(Math.min(combo_box.mouseY*m+b,comb o_box.dropdown.maxVerticalScrollPosition));
m=(y1-y2)/(x1-x2);
b=m*x1-y1;
p.s. you may need to use a render event (shown in message 4).
The result i get from this coding. The scroll Bar start from bottom and scrollpane cannot scrolling.
I was test on mobile phone.
coding i use:
var m:Number;
var b:Number;
paramF(combobox.mouseY,combobox.dropdown.verticalScrollPosition,combobox.height-10,combobox.dropdown.maxVerticalScrollPosition);
combobox.dropdown.verticalScrollPosition=Math.round(Math.min(combobox.mouseY *m+b,combobox.dropdown.maxVerticalScrollPosition));
m=(y1-y2)/(x1-x2);
b=m*x1-y1;
use;
var m: Number;
var b: Number;
combo_box.dropdown.verticalScrollPosition = Math.round(Math.min(combo_box.dropdown.mouseY * m + b, combo_box.dropdown.maxVerticalScrollPosition));
function stopscrollF(e: Event): void {
this.removeEventListener(Event.ENTER_FRAME, scrollF);
function paramF(x1: Number, y1: Number, x2: Number, y2: Number): void {
m = (y1 - y2) / (x1 - x2);
b = m * x1 - y1;
emm.... this coding no error but still unable scroll the combobox...i try few times ald..
the combobox still function as normal combobox..
create a new fla, add a combobox to the stage and assign its instance name combo_box.
use the properties panel to add items to the combobox.
copy the code in message 12 and paste it into the actions panel.
test.
i test with AS3 and Air for Android
follow the step.
-combobox instance name= combo_box
-properties panel(data provider)= add name
-copy message12 as AS.
-test
result: Still same as before.cannot scolling
test it in flash pro.
i need develop android App.
i using Adobe Flash Professional CS6(AIR for Android) for development..
i know.
test in flash pro.
if that fails you've done something wrong.
if that works, that's as much help as i give via the forums. testing on mobile devices is too time-consuming (for me) to do free of charge.
done test...cant scroll with mouse click ..
still have same problem.
sorry for taking you too much time
you don't scroll with a mouse click. you mouse down and drag your mouse.
ya...i get it...before that i open the combobox and drag so cant make it...
finally solve this problem.
Thanks you very much.
sorry take u a lot of time .
thanks for always helping me..
you're welcome.
