Hellou everybody, last week I have upgraded to Presenter 9. Please, know somebody, where can I find and replace text Adobe Presenter on splash screen, when loading exported course from Presenter 9? In previous version of Presenter 8 it was inside wpconfig file (text ,,uiname..."). But this line of uiname text file I cannot to find inside instalation Presenter 9.
Thank for any help.
best regards
Yarik
I Presenter 8 I just modified the language.xml file located at C:\Users\{UserName}\AppData\Local\Adobe\Adobe Presenter\Themes (Windows 7/8 file path). Then this text can be edited in the Theme Editor through the Modify Text Labels button. Add the following to the file:
<!-- uitext -->
<uitext name="ADOBE_PRESENTER" value="Adobe Presenter"/>
I did it after the quiz pod and message box text list, but you should be able to put it anywhere. Then when you go into the Modify Text Labels tool, it
...Copy link to clipboard
<!-- uitext -->
I did it after the quiz pod and message box text list, but you should be able to put it anywhere. Then when you go into the Modify Text Labels tool, it should show there and you can modify it as you see fit.
Perfect! It works! Thank you very much.
Yarik
I followed your way, but it doesn't work.
Here is my post, would you please be kindly to help me?
Presenter 9: "Change SWF loading text" not works
Thanks~
This method was about modifying it in Presenter's source files, you appear to be modifying the published/output files. Explanation is in your new thread.
Thanks for your feedback in another post.
