Hyperlinks from another FM document of the same FM Book does not work in RoboHelp after an FM inset. But hyperlinks from the same FM document works in Robohelp after an FM inset.
All the hyperlinks work in PDF.
Note: The hyperlinks are not within the text inset but outside the text inset. As long as it is after the text inset, from that point onward, the links will not work (if they point to another FM doc).
eg:
text inset
content
hyperlink broken (from another FM doc of same FM book)
Please help. It would be a pain if this does not work at all.
Kai
I would set up a simple set of files to test this with TCS5 (download a trial on a machine that doesn’t have any TCS products on it) and if you can reproduce the behaviour, report it as a bug and send the files to the TCS Support group. They’re not going to be patching TCS4 now that 5 is out.
