Any idea why typekit would not be working on a secure page in bc? Its working fine on all other non-secure pages.
Thanks.
Thanks guys! I had entered worldsecuresystems.com in typekit instead of mydomain.worldsecuresystems.com.
It's probably becuase you haven't registered the Worldsecuresystems URL with typekit?
Try logging into typekit and adding that url.
Or better still. Use GoogleFonts 🙂
Brett Stockley
prettypollution.com.au
Hi Wheezer,
I'm sorry that you ran into trouble with this! As Brett suggested, it's possible that the secure section of your website uses a different domain name, and you just need to include this in the listing on your kit.
To add domains, go to http://typekit.com and launch your Kit Editor. Click Kit Settings in the upper right corner and add your domain to the domains field, then save your settings. When you're done, republish your kit. The fonts will start working within a few minutes of republishing.
If that doesn't solve the problem, would you share the URL of a page where you are seeing this issue? You can email us at support@typekit.com if you would rather not post it in the forum.
-- liz
