I have many problems using the latest Flash Version 13.0.0.182. My applications use an embedded version of IExplorer 11 and use OSMF to display P2P Streams. If buffering starts, an exception is thrown and my app crashes with the message "Exception 000000 in FLASH.OCX". This only happens under Windows 8.1 (64 Bit) with latest Flash Version 13.0.0.182, embedded Version. If i call the URL directly into IE, it works.
- Older Versions works fine
- On other Windows (Windows 7...) is works fine
Please file a bug at https://bugbase.adobe.com/ and include a reproducible test case as well as the crash dump log file(s). We'll then assign it for further investigation.
Thank you in advance.
Maria
Open entry in bugbase #3744747 (https://bugbase.adobe.com/index.cfm?event=bug&id=3744747)
Start EXE (Src is included), navigate to http://www.osmf.org/dev/1.5gm/embed.html?favorFlashOverHtml5Video=false will crash the application
Crash Dump is not available (because of my own EXE, not IE), no dump file in Dump-Folder.
This also happens in latest Flash Version 13.0.0.206, Bugbase entry is updated.
Need help because it doesn't work under Windows 8.1 ...
