Hi all,
I need to create an online help system that will run in an old version of Netscape, on an HP-UX machine. I tried generating Webhelp, but it will not load.
Is there a Robohelp SSL I can use that is just plain HTML (no Java)? I would prefer to have an online help that has a Contents (navigation) pane on the left and the content in the right, if possible.
I can use Technical Communication Suite 3, 4, or 5.
Thanks.
Hi there
When you double-click the WebHelp Single Source Layout recipe, click the Navigation section on the left side of the dialog. Then look at the right side and you should find an option for Pure HTML.
Cheers... Rick
THANK YOU! I'm going to try this now.
