So I am trying to set up a table to have a set of rows repeated based on a variable set up in a separate location. So I have table output being generated from a cfoutput of the query, then in the cfoutput tag, I have a cfloop statement with the <td>s for the columns that I need repeated based on my variable. The problem I am experiencing is that the loop, instead of running from 1 to x (even when I hard coded the to = "2") is running per row the number of records in the cfoutput query in a decremental fashion, if my query has 11 rows, I get 11 loops the first run, then 10, then nine and so on. Has anyone experienced this before? Here is the code, working with CF 9 on SQL Server 2012:
<cfoutput query="getNCDs">
<tr>
<td class="ins_grid_data">#getNCDs.ncdId#</td>
<cfloop from="1" to="2" index="y" >
<cfoutput>
......... and that is what is helpful about retyping things into a forum, sometimes you spot your own mistakes. I don't need another <cfoutput> tag...I am IN a <cfoutput>. Took the extra tag out and the process worked the way I wanted it to. Everybody have a good day.
Juss
Good for you! Then mark your answer as 'correct'.
