I have a Flex app that needs to access data from a SOAP web service over https with a self signed certificate. The app needs to ignore the https warnings, just as a browser would warn & allow the user to proceed. Buying a valid signed certificate is not an option for us.
It works fine over http.
How can I achieve this?
I read that URLRequest has a property: authenticate, that I can set to false. However, this property is available only for Adobe AIR applications from what I can see. This doesn't seem available for Flex apps.
I have tried this in both Flex 3 & the latest Flash Builder 4. Have the same issue in both cases.
Help appreciated.
You'd really need to ask in the Flex or Flash Builder forums as this is a front end code modification and Flash Player can't do any of that.
Will do. Thanks.
