Hello Again,
I am in a bit of fix here.
I have converted my Flash project to Html Canvas in Flash CC.
But my actions in timeline got commented out and have created a js file.
Its not working as per the actions I have created.
Done a bit of research and have known that the actions would be commented out and js has to be written for the actions wehave given.
As I have no knowledge in programming Java Script, any help in this would be highly appreciated.
This is the script I have been working on...
Thanks in Advance..
import flash.events.MouseEvent;
Wall1.stop();
Wall1.RedCove.visible = false;
Wall1.PearlGrey.visible = false;
Wall1.Boulder.visible = false;
Wall1.Lava.visible = false;
RedCove_btn.visible = false;
PearlGrey_btn.visible = false;
Boulder_btn.visible = false;
Lava_btn.visible = false;
Wall_btn.addEventListener(MouseEvent.CLICK,panels);
function panels(event:MouseEvent):void
RedCove_btn.visible = true;
PearlGrey_btn.visible = true;
Boulder_btn.visible = true;
Lava_btn.visible = true;
RedCove_btn.addEventListener(MouseEvent.CLICK, redcove);
function redcove(event:MouseEvent):void
Wall1.RedCove.visible = true;
PearlGrey_btn.addEventListener(MouseEvent.CLICK, pearlgrey);
function pearlgrey(event:MouseEvent):void
Wall1.PearlGrey.visible = true;
Boulder_btn.addEventListener(MouseEvent.CLICK, boulder);
function boulder(event:MouseEvent):void
Wall1.Boulder.visible = true;
Lava_btn.addEventListener(MouseEvent.CLICK, lava);
function lava(event:MouseEvent):void
Wall1.Lava.visible = true;
Original_Image.addEventListener(MouseEvent.CLICK, hide);
function hide (event:MouseEvent):void
Doing this manually implies code has to be rewritten?
Yes, you have to edit the js file that flash generates after you publish to canvas
EaselJS is a entirely different from AS 3.0 right?
EaselJS is basically a framework which enables you to write JavaScript with classes (similar to actionscript).
A functionality you need to make all the MovieClips/Sprites in your library available to javascript
Check out this tutorial to get a basic understanding:
if the autoconversion dosen`t work for your project you will have to do it manually.
The framework you need to look into is documented here:
http://www.createjs.com/Docs/EaselJS/modules/EaselJS.html
click events are handled like this:
Wall_btn.addEventListener("click", panels);
function panels(event){
Hello moccamaximum,
Or the .js file can be edited??
But the EaselJS is a entirely different from AS 3.0 right??
Please do help me understand.
Thank you.
