Since RoboHelp 11, .mdb files don't seem to be recognized with SharePoint version control. Note that we have ensured the file type is allowed in SharePoint.
Lauching RoboHelp in Admin mode does not help.
Note that this was working under RoboHelp 10.
MDB is a Microsoft DataBase file. Rh uses a variant known as the CPD file. Did you mean MDB?
Do mean .mdb files yes:
What we will test is creating a new SharePoint connection, apparently when you install a new RH version, you need to redo the SharePoint connection.
Hi, goguenr
Because RoboHelp 11 has some enhancements and a new Topic-Sharing workflow (that can be "cloud-based") there have been some modifications. So perhaps it requires a re-connection to SharePoint. Normally, the RoboHelp/Sharepoint integration is most commonly used for source control of those files related to a specific RoboHelp Project. RoboHelp will exclude any "output" files (like those in the !SSL! folder because after all they are output files and not "source" files as source control implies. However, you can modify how this works with some configuration. If you also link to files (which are managed by "Baggage" in the Project Manager); those are added to Source Control as well. (But it sounds like you were already doing that with previous versions, so sorry if I'm stating the obvious.)
I think if would be great if you could take a look at a webinar that Willam van Weelden and I did last Fall. A recording is available for viewing and is free. You can also learn more on Willam's website:
http://www.wvanweelden.eu/blog/2013/08/17/adobe-robohelp-using-sharepoint-version-control
The recording is here (you may be asked to sign in with free Adobe ID)
http://www.adobe.com/cfusion/event/index.cfm?event=set_registered&id=2099687&loc=en_us
Willam is more versed in this than I, so perhaps he will chime in with more.
John Daigle
Adobe Certified RoboHelp and Captivate Instructor
Evergreen, Colorado
Hi John,
Thank you so much for taking the time to provide all these details. We are testing out at the moment exactly what you are suggesting, re-connecting to SP.
Will let you all know if we are successful.
Thanks again,
Roland
