• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
1
Can't install Creative Cloud Setup - error code 46
Community Beginner ,
Apr 27, 2014 Apr 27, 2014
Running Windows 7 Ultimate 64, service pack 1
Getting this message on install:
'Installer was unable to access a critical file/directory. Please try installing again. (error code: 46)'
In case it was a privileges issue:
  • Tried as main user which already has admin privileges
  • Tried creating a new admin user and installing through that
  • Tried activating the disabled default administrator user and installing
Also tried with antivirus/firewall disabled, and tried running Adobe Creative Cloud Cleaner Tool then running the installer again.
Same error every time - any ideas on how to get this installed?
Any help is much appreciated, thanks in advance
TOPICS
Creative Cloud
Views
35.0K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Beginner , Apr 27, 2014 Apr 27, 2014
Finally figured it out, so here's the solution in case anyone else hits this problem - in my case it was Comodo internet security.
Not sure if it was the anti-virus, HIPS, auto-sandbox, or the firewall, but I basically disabled *all* of them for a couple of minutes while I ran the installer, and everything worked fine. Switched back on and the installed application is working without any problems at all. Note that Comodo has to still be running and each option actually disabled, rather than just
Votes
Translate
Translate
Community Expert ,
Votes
Translate
Translate
Report
Report
Thanks for the response, I couldn't find any help in the FAQ though - the only info I could find related to this error code was about it potentially being a privileges issue, but as I said in the first comment I've tried all the options people suggested on that.
I did try the live chat earlier but got no response so closed it after half an hour waiting. I'll give that another go if no-one else can suggest anything though, I don't mind waiting but didn't have the time for it this evening.
The last link you gave seems to be to do with server errors, and this doesn't look like it's anything to do with the connection or downloading issues - it says it's downloading, then starts to install, then stops and fires the error message.
Again, any help would be very much appreciated, I'd like to get this sorted and get this installed as soon as possible.
Votes
Translate
Translate
Report
Report
Not sure if it was the anti-virus, HIPS, auto-sandbox, or the firewall, but I basically disabled *all* of them for a couple of minutes while I ran the installer, and everything worked fine. Switched back on and the installed application is working without any problems at all. Note that Comodo has to still be running and each option actually disabled, rather than just exiting Comodo in the systray (the protection stays on if you do that, it must be still running as a service).
Hope this is of some use and saves some time/hassle for anyone else having trouble with the installer.
Votes
Translate
Translate
Report
Report
New Here ,
Dec 07, 2014 Dec 07, 2014
It's almost three days i tried everything as stated above but didn't worked out.
I am running windows 8.1. Please help me out.
Suraj
Votes
Translate
Translate
Report
Report
New Here ,
Error Code..
Unable to unzip the contents of package: utilInstallPackageAtPathToPath
12/08/14 10:06:35:882 | [FATAL] |  | ASU | PIM | PIM |  |  | 4080 | Error Failed to extract assets...
12/08/14 10:06:36:002 | [FATAL] |  | ASU | PIM | PIM |  |  | 4080 | package installation failed and the return code was 46
12/08/14 10:06:36:002 | [ERROR] |  | ASU | PIM | PIM |  |  | 4080 | Failed to install with return code: 46
Votes
Translate
Translate
Report
Report
Guest
Jul 30, 2015 Jul 30, 2015
Thanks Tony, you helped me out, I was getting so frustrated, I disabled my Kaspersky before the install and it installed perfectly.  Now I have to get the products installed.
THANK YOU SO MUCH 🙂
Votes
Translate
Translate
Report
Report
New Here ,
Jul 11, 2016 Jul 11, 2016
how do did you disable Kaspersky?
Votes
Translate
Translate
Report
Report
Jun 21, 2016 Jun 21, 2016
It didn't work for me. using Windows 10
Votes
Translate
Translate
Report
Report
New Here ,
Jun 30, 2016 Jun 30, 2016
I have same issue running Windows 10 and nothing is working.
Votes
Translate
Translate
Report
Report
New Here ,
Mar 26, 2015 Mar 26, 2015
it did not work for me help?
Votes
Translate
Translate
Report
Report
New Here ,
Jul 28, 2015 Jul 28, 2015
Hi there, I got the same problem today (error 46). I managed to get past this problem by using the Adobe CC Cleaner Tool. It helps cleaning all the remnants of previous installations of, for example, the creative cloud desktop. Worked for me . Here you go: De CC Cleaner Tool gebruiken om installatieproblemen op te lossen | CC, CS3-CS6
Votes
Translate
Translate
Report
Report
Mentor ,
Aug 06, 2015 Aug 06, 2015
The CC Cleaner fixed it for me - thanks
Votes
Translate
Translate
Report
Report
New Here ,
Aug 24, 2015 Aug 24, 2015
For anyone that is still having this issue. You can resolve it in windows by going to the download location, right click the file, then select run as administrator it will run it no problem.
Votes
Translate
Translate
Report
Report
New Here ,
Mar 29, 2016 Mar 29, 2016
Running it as an administrator worked for us, after repeatedly getting the #46 error message. Thanks for sharing the tip.
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Aug 27, 2015 Aug 27, 2015
Votes
Translate
Translate
Report
Report
New Here ,
Feb 18, 2016 Feb 18, 2016
I dont have comodo and none of the anyi-viris you are talking about im on windows 8 help what do I do
Votes
Translate
Translate
Report
Report
New Here ,
May 30, 2016 May 30, 2016
Ive tried everything like turning off my firewall uninstalling McAfee I dont know what else to do and I am really starting to get frustrated. PLEASE HELP
Votes
Translate
Translate
Report
Report
New Here ,
Jul 24, 2016 Jul 24, 2016
Nothing works for mw with Windows 10.
I have disabled Firewall and anti virus but it didn't help.
I also tried "Adobe CC Cleaner" - still having the same problem.
Cannot install or use the Adobe programs 😕
Votes
Translate
Translate
Report
Report
Jul 26, 2016 Jul 26, 2016
Try installation in Safe Mode with Networking.
Best regards,
David
Votes
Translate
Translate
Report
Report
New Here ,
Dec 05, 2016 Dec 05, 2016
LATEST
me too facing same problem
you got the solution.
Votes
Translate
Translate
Report
Report
