borlak
homesite 5.5 resource window will not dock
May 21, 2007 6:00 AM
Here is a screenshot:
http://www.borlak.org/images/homesitebr.JPG
You'll notice the resource window (F9) is floating. It wont re-dock. A coworker has the option under View->Resource Windows->Dock all windows (or something to that effect). As you'll see in the screenshot, that doesn't exist for me. This is homesite 5.5 and I can't find any updates on it, or a fix for this.
If I drag the window to the sides, it doesn't try to re-dock as you would expect. I've right clicked everywhere on the resource window looking for some kind of menu option - nothing. I've also tried double clicking the titlebar of the resource window (typical way of docking a window), again to no effect.
I found the keyboard shortcut "Dock All Resource Windows" and tried several different keybinds, and it does not redock the resource window for me.
I pretty much gave up on homesite due to this and tried a couple different editors (including dreamweaver), but after a day of use I would like to go back to homesite, but this is still bugging the heck out of me. The only thing I haven't tried is re-installing, but that is a pain in my work environment since I need admin access and it can take a while to get that done; plus that option seems a little extreme.
Any help would be greatly appreciated;
Michael
    May 21, 2007 7:43 AM   in reply to borlak
    I remember I have had this problem too a while ago. As far as I know you have to fiddle with the registry - but maybe someone has a better solution. I can't see a button to attach a file here, so I show my registry-settings directly here - I hope this helps
    Windows Registry Editor Version 5.00
    [HKEY_CURRENT_USER\Software\Macromedia\HomeSite5\Docking]
    "DockPanelLeft"="211"
    "DockPanelRight"="52"
    "DockPanelTop"="80"
    "DockPanelBottom"="62"
    [HKEY_CURRENT_USER\Software\Macromedia\HomeSite5\Docking\AllaireTabDoc kForm0]
    "Visible"="1"
    "AlwaysOnTop"="1"
    "Position"="3,15,205,730"
    "Floating"="0"
    "DockHost"="DockPanel_Left"
    "DockTab"="1"
    "ActivePage"="0"
    [HKEY_CURRENT_USER\Software\Macromedia\HomeSite5\Docking\frmDockHelp]
    "Visible"="1"
    "AlwaysOnTop"="1"
    "Position"="0,0,197,694"
    "Floating"="0"
    "DockHost"="AllaireTabDockForm0"
    "PageIndex"="4"
    "DockTab"="0"
    [HKEY_CURRENT_USER\Software\Macromedia\HomeSite5\Docking\frmDockLocalF iles]
    "Visible"="1"
    "AlwaysOnTop"="1"
    "Floating"="0"
    "PageIndex"="0"
    "DockTab"="0"
    [HKEY_CURRENT_USER\Software\Macromedia\HomeSite5\Docking\frmDockProjec ts]
    "Visible"="1"
    "AlwaysOnTop"="1"
    "Floating"="0"
    "PageIndex"="1"
    "DockTab"="0"
    [HKEY_CURRENT_USER\Software\Macromedia\HomeSite5\Docking\frmDockSiteVi ew]
    "Visible"="1"
    "AlwaysOnTop"="1"
    "Position"="0,0,208,568"
    "Floating"="0"
    "PageIndex"="2"
    "DockTab"="0"
    [HKEY_CURRENT_USER\Software\Macromedia\HomeSite5\Docking\frmDockSnippe ts]
    "Visible"="1"
    "AlwaysOnTop"="1"
    "Floating"="0"
    "PageIndex"="3"
    "DockTab"="0"
    [HKEY_CURRENT_USER\Software\Macromedia\HomeSite5\Docking\frmDockTagIns pector]
    "Visible"="1"
    "AlwaysOnTop"="1"
    "Position"="0,0,227,568"
    "Floating"="0"
    "PageIndex"="5"
    "DockTab"="0"
    Jun 1, 2007 10:54 AM   in reply to borlak
    see also my faq on this for how to redock it.
    Tip: Re-Docking Resource Windows
    http://www.wilk4.com/asp4hs/tips.htm#redocking_resource_windows
    Calculating status...
    Jun 19, 2007 1:10 PM   in reply to Jeff Wilkinson
    Thank you, thank you. This little exercise (before I found your excellent post) wasted the better part of half a day. I'll definitely be keeping your site as a bookmark for future reference. Thanks again!
    Carol
    Aug 24, 2007 2:40 PM   in reply to borlak
    I'm having a similar problem with my Snippets window in Homesite 5. It used to dock in the resource window, but the snippets tab has now disappeared from the resource window and I cannot find a way to redock my snippets. The solution mentioned here will not work for me because there is no files list section in the snippets window, nor can I adjust the window to make a files list section appear.
    Any help you can provide would be greatly appreciated. This has been driving me crazy. :) Thanks!
    Oct 5, 2010 1:35 PM   in reply to borlak
    btw, I just had this problem myself.  Homesite crashed once then when I restarted everything was undocked.
    Even though I knew from my own notes how to redock most of them, the snippets tab was a bugger.
    Oddly enough, *sometiems* the snippets tab will give you that move-to menu option to let you re-dock, but not always.  Seems related to the order you redock tabs.  Perhaps you just need to not have it be last.
    Anyway, I had to add in some of those registry values (while HomeSite was closed) to redock it.
    I'll add those details to my faq as soon as I get chance.
    One note to add to that, it seems that the DockHost value for the tabs is sometimes slightly different.
    Mine is:
    "DockHost"="AllaireTabDockForm1"
    If you look at the keys under
    you'll see that one of them is something like
    AllaireTabDockForm0 or AllaireTabDockForm1
    The DockHost values for the tabs should match that, so when you recreate the
    DockHost string make sure it matches.
    On a related matter, I noticed that there is a registry value :
    HKEY_CURRENT_USER\Software\Macromedia\HomeSite5\ResourceTab]
    "DockTabLock"="0"
    I vaguely recall this being something to lock all the tabs so you can't undock them.
    I can't find that in the HomeSite user interface at all.  I'll test the registry value,
    but does anyone know how you would change it in the HS UI?
    thanks, later,
    jeff
    -- Jeff Wilkinson
    volunteer for HomeSite
    see Asp4Hs: ASP/PHP/.Net/etc Development Extensions for HomeSite
