jjulie
Text in Dynamic Textfield gets cut off
Apr 5, 2007 4:44 PM
Hi
I have a dynamic text field which is just one line of text.
For some reason letters like g or p that go below the regular line of text get cut off.
I have made the field bigger, and also played around with the _height Property but it doesn't make a difference.
I have imported the font into the Library. When I embed it the font doesn't cut off but looks very different. And if I change the field to a static field it doesn't cut off either, but the font looks a little different as well.
Any ideas?
    Apr 5, 2007 4:50 PM   in reply to jjulie
    So, No matter how large you make the field it gets cut off...even with the text at the same size?
    Is the fiield set to multiline?
    Apr 5, 2007 5:20 PM   in reply to jjulie
    can you tell me what font you're using. I will try to recreate your problem.
    Apr 5, 2007 8:22 PM   in reply to jjulie
    try set the autosize for your text field to true after you set the value of it..
    e.g.
    your_txt.text = "something";
    your_txt.autosize = true;
    Apr 8, 2007 9:06 PM   in reply to jjulie
    unable to view the page, unable to download the file.
    Apr 9, 2007 8:27 PM   in reply to jjulie
    still cant,
    i cant even open the website http://www.woed.com/
    anybody here able to open it?
    Jan 5, 2012 9:57 AM   in reply to jjulie
    Hi, I am having the same problem right now using Trade Gothic font.
    Were you ever able to resolve this?
    Jack
  • kglad
    Jul 21, 2002
    Jan 5, 2012 10:57 AM   in reply to CorpusCallosum
    this thread is old.  start a new one.
    Jan 5, 2012 12:28 PM   in reply to kglad
    Why should I start a new thread if this one was never resolved and I am still having the same problem?
    ANYWAY,
    I was able to fix this by finding an answer on a different forum.
    Simply increase the text leading using the text format option, like so:
    var format:TextFormat = new TextFormat();
    format.leading = 2;
    field_txt.defaultTextFormat=format;
    Aug 28, 2013 8:28 AM   in reply to CorpusCallosum
    I also just had this problem and here's what fixed it for me.
    The field was set to multiline, but only needed to be single line. So I changed that to single line.
    There was also a -18 set for the paragraph spacing. I changed that to 0.
