• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
CFMX 6.1 Daylight Savings Patch
Explorer ,
Mar 06, 2007 Mar 06, 2007
The patch for the DST is not working.
The server version is:
CMFX 6.1 version: 6,1,0,83762
Installed the full SDK located at:
C:\Program Files\java\j2re1.4.2_11
Changed the VM configuration in the jvm.config file located at C:\CFusionMX\runtime\bin to:
java.home=C:/Program Files/java/j2re1.4.2_11
Tried to restart Coldfusion Services and it would not restart!
Does anyone have any suggestions or did I miss anything?
Ron
Here is my server info:
Server Details
Server Product
ColdFusion MX
Version
6,1,0,83762
Edition
Standard
Serial Number
CPD600-xxxxx-xxxxx-xxxxx
Operating System
Windows 2003
OS Version
5.2
JVM Details
Java Version
1.4.2
Java Vendor
Sun Microsystems Inc.
Java Vendor URL
http://java.sun.com/
Java Home
C:\CFusionMX\runtime\jre
File Separator
Path Separator
Line Separator
Chr(13)
User Name
SYSTEM
User Home
C:\Documents and Settings\Default User
User Dir
Java VM Specification Version
1.0
Java VM Specification Vendor
Java VM Specification Name
Java Virtual Machine Specification
Java VM Version
1.4.2-b28
Java VM Vendor
Java VM Name
Java HotSpot(TM) Server VM
Java Specification Version
1.4
Java Specification Vendor
Java Specification Name
Java Platform API Specification
Java Class Version
48.0
Java Class Path
C:\CFusionMX\runtime\servers\lib; C:\CFusionMX\runtime\..\lib\cfusion.jar; C:\CFusionMX\runtime\..\lib; C:\CFusionMX\runtime\..\lib\bcel.jar; C:\CFusionMX\runtime\..\lib\cf4was.jar; C:\CFusionMX\runtime\..\lib\cf4was_ae.jar; C:\CFusionMX\runtime\..\lib\cfmx-ssl.jar; C:\CFusionMX\runtime\..\lib\cfmx_bootstrap.jar; C:\CFusionMX\runtime\..\lib\cfusion.jar; C:\CFusionMX\runtime\..\lib\cfx.jar; C:\CFusionMX\runtime\..\lib\collections.jar; C:\CFusionMX\runtime\..\lib\crimson.jar; C:\CFusionMX\runtime\..\lib\flashgateway.jar; C:\CFusionMX\runtime\..\lib\httpclient.jar; C:\CFusionMX\runtime\..\lib\izmado.jar; C:\CFusionMX\runtime\..\lib\jakarta-oro-2.0.6.jar; C:\CFusionMX\runtime\..\lib\java2wsdl.jar; C:\CFusionMX\runtime\..\lib\jaxp-api.jar; C:\CFusionMX\runtime\..\lib\jdom.jar; C:\CFusionMX\runtime\..\lib\jintegra.jar; C:\CFusionMX\runtime\..\lib\ldap.jar; C:\CFusionMX\runtime\..\lib\ldapbp.jar; C:\CFusionMX\runtime\..\lib\log4j.jar; C:\CFusionMX\runtime\..\lib\macromedia_drivers.jar; C:\CFusionMX\runtime\..\lib\mail.jar; C:\CFusionMX\runtime\..\lib\msapps.jar; C:\CFusionMX\runtime\..\lib\NetComponents.jar; C:\CFusionMX\runtime\..\lib\pbclient42RE.jar; C:\CFusionMX\runtime\..\lib\pbembedded42RE.jar; C:\CFusionMX\runtime\..\lib\pbserver42RE.jar; C:\CFusionMX\runtime\..\lib\pbtools42RE.jar; C:\CFusionMX\runtime\..\lib\tools.jar; C:\CFusionMX\runtime\..\lib\tt-bytecode.jar; C:\CFusionMX\runtime\..\lib\webcharts.jar; C:\CFusionMX\runtime\..\lib\webchartsJava2D.jar; C:\CFusionMX\runtime\..\lib\webservices.jar; C:\CFusionMX\runtime\..\lib\wsdl2java.jar; C:\CFusionMX\runtime\..\lib\xalan.jar; C:\CFusionMX\runtime\..\runtime\lib\jrun.jar; C:\CFusionMX\runtime\..\runtime\lib; C:\CFusionMX\runtime\..\runtime\lib\instutil.jar; C:\CFusionMX\runtime\..\runtime\lib\java2wsdl.jar; C:\CFusionMX\runtime\..\runtime\lib\jrun-ant-tasks.jar; C:\CFusionMX\runtime\..\runtime\lib\jrun-xdoclet.jar; C:\CFusionMX\runtime\..\runtime\lib\jrun.jar; C:\CFusionMX\runtime\..\runtime\lib\jspc.jar; C:\CFusionMX\runtime\..\runtime\lib\migrate.jar; C:\CFusionMX\runtime\..\runtime\lib\oem-xdoclet.jar; C:\CFusionMX\runtime\..\runtime\lib\sniffer.jar; C:\CFusionMX\runtime\..\runtime\lib\webservices.jar; C:\CFusionMX\runtime\..\runtime\lib\wsconfig.jar; C:\CFusionMX\runtime\..\runtime\lib\wsdl2java.jar; C:\CFusionMX\runtime\..\runtime\lib\xmlscript.jar; c:\cfdev\spellchecker\CFX_JSpellCheck.jar; c:\ActivEdit4\activedit\inc\spellchecker\ActivSpell2.jar; C:\CFusionMX\cfx\java; C:\Program Files\Microsoft SQL Server 2005 JDBC Driver\sqljdbc_1.0\enu\sqljdbc.jar; C:\CFusionMX\runtime\lib\jrun.jar
Java Ext Dirs
C:\CFusionMX\runtime\jre\lib\ext
Views
1.1K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Explorer , Mar 07, 2007 Mar 07, 2007
OK, I figured out the problem -
You have to make sure that you have the right download from Java. If you look at my jvm.config you will notice that the file name
is j2re1.4.2_11. It should be j2sdk1.4.2_11
So here a step by step install for CFMX 6.1 with updater 1
1) Make a backup of your jvm.config file located at: C:\CFusionMX\runtime\bin
If you have any problems, just change the path back to the original java.home=C:/CFusionMX/runtime/jre
2) Download the J2SDK 1.4.2_11 at: http://java.sun.com/products/archive/j2se/1.4.2_11/index.html...
Votes
Translate
Translate
LEGEND ,
see this first (especially steve's comments):
http://www.talkingtree.com/blog/index.cfm/2006/4/7/CFAdmin-problems-when-editing-JVM-settings
Votes
Translate
Translate
Report
Report
New Here ,
I just tried this patch and fix and I am getting the same problem. My cold fusion will not restart When I look in sys information I get Java 1.4.2-b28. Can anyone help me with this ????
danix
Votes
Translate
Translate
Report
Report
Engaged ,
First, try restoring the path to your prior JDK (restore from a backup jvm.config if you have one).
(I.E. java.home=C:/CFusionMX/runtime/jre)
Confirm that ColdFusion MX restarts and you are back to square one.
Next, install the JDK in a path without spaces (I.E. C:\j2sdk1.4.2_11 instead of c:\program files\j2sdk1.4.2_11)
Now, edit the jvm.config with the new path java.home=C:/j2sdk1.4.2_11
Save the file, restart ColdFusion and it should start.
Votes
Translate
Translate
Report
Report
New Here ,
Thanks you were right on point
danix:
Votes
Translate
Translate
Report
Report
Explorer ,
Thanks LL@work for replying.
I moved the j2re1.4.2_11 to C:\j2re1.4.2_11 and configured the jvm.config to C:/2re1.4.2_11. I also tried moving the
complete install C:\java\j2re1.4.2_11 and configured the jvm.config to C:/java/2re1.4.2_11. I tried to restart coldfusion in
both instances and Coldfusion would not restart. I had to go back to the original jvm.config java.home=C:/CFusionMX/runtime/jre
Here is the jvm.config that I tried to install:
# VM configuration
# Where to find JVM, if {java.home}/jre exists then that JVM is used
# if not then it must be the path to the JRE itself
java.home=C:/j2re1.4.2_11
# If no java.home is specified a VM is located by looking in these places in this
# order:
# 1) bin directory for java.dll (windows) or lib/<ARCH>/libjava.so (unix)
# 2) ../jre
# 3) registry (windows only)
# 4) JAVA_HOME env var plus jre (ie $JAVA_HOME/jre)
# Arguments to VM
java.args=-server -DJINTEGRA_NATIVE_MODE -DJINTEGRA_PREFETCH_ENUMS -Xmx512m -Dsun.io.useCanonCaches=false -Xbootclasspath/a:
# commas will be converted to platform specific separator and the result will be passed
# as -Djava.ext.dirs= to the VM
java.ext.dirs={jre.home}/lib/ext
# where to find shared libraries
java.library.path={application.home}/../lib,{application.home}/../jintegra/bin,{application.home}/../jintegra/bin/international,{application.home}/../lib/_nti40/bin
system.path.first=false
# JVM classpath
java.class.path={application.home}/servers/lib,{application.home}/../lib/cfusion.jar,{application.home}/../lib,{application.home}/../runtime/lib/jrun.jar,{application.home}/../runtime/lib,c:\\cfdev\\spellchecker\\CFX_JSpellCheck.jar,c:\\ActivEdit4\\activedit\\inc\\spellchecker\\ActivSpell2.jar,C:/CFusionMX/cfx/java,C:\\Program Files\\Microsoft SQL Server 2005 JDBC Driver\\sqljdbc_1.0\\enu\\sqljdbc.jar,
Thanks for the help,
Ron
Votes
Translate
Translate
Report
Report
Explorer ,
LATEST
** Make sure that you DO NOT install the J2RE 1.4.2_11. This is what gave me the problem***
Install the full J2SDK 1.4.2_11 - Here is the download:
https://sdlc6a.sun.com/ECom/EComActionServlet;jsessionid=3BC516FBC3CC49D84B7C1F83E775207E
3) I would use LL@works suggestion about not installing with any directory with spaces. I installed
it at the default java installation location C:\j2sdk1.4.2_11
4) Manually reconfigure the jvm.config file to point to the new installation
5) Restart the coldfusion application service in services.
6) Then you have to check out this hotfix:
http://www.adobe.com/cfusion/knowledgebase/index.cfm?id=kb400232
You now should be in business.
Thanks LL@work for all the help!
Ron
Votes
Translate
Translate
Report
Report
Resources
Documentation
