Home/Support/
Forums
1213 Views 13 Replies Latest reply: Nov 1, 2007 4:54 PM by PhilBailey RSS
PhilBailey User 23 posts since
May 15, 2004
Jul 13, 2007 1:08 PM
Disabling the Context Menu
I need to disable the context menu on my Flash Lite 2.1 application so that users cannot affect the application. This is the menu that pops up when the user holds the stylus down on the Pocket PC screen. It is equivalent to the right-click menu that shows up in Flash on desktop PCs.
In the past, when I used Flash Player 6.0 for the Pocket PC, I could just create a big button in the lowest background layer, that covered the entire stage and did nothing when clicked. This does not seem to work in Flash Lite. I also see that the "showmenu" fscommand and the ContextMenu class are not supported in Flash Lite.
How can I suppress or disable the context menu in a Flash Lite for Windows Mobile application?
  • May1502 User 6 posts since
    Nov 22, 2005
    1. Aug 1, 2007 4:29 AM (in response to PhilBailey)
    Re: Disabling the Context Menu
    Your answer : After set Softkeys to your handlers, your FlashLite menus will be destroyed.
  • maxdef Calculating status... 1 posts since
    Aug 24, 2007
    3. Aug 24, 2007 2:16 PM (in response to PhilBailey)
    Hello,
    I need to do the same, disable the context menu, please help.
    Kind regards,
    Stuart Scott
  • colkel Calculating status... 1 posts since
    Oct 1, 2007
    4. Oct 1, 2007 9:48 AM (in response to PhilBailey)
    HI,
    I also need to disable this feature, it looks like it can
    not be done...
  • blacknoise2 Calculating status... 1 posts since
    Aug 14, 2005
    5. Oct 1, 2007 10:34 AM (in response to PhilBailey)
    same problem here, maybe a good idea for adobe to think of another way to acces the context menu then holding the stylus down.
  • dcc_med Calculating status... 4 posts since
    Oct 3, 2007
    6. Oct 3, 2007 2:48 PM (in response to blacknoise2)
    We are also facing the same problem. I take it no one has figured out a solution for this? ...
  • dcc_med User 4 posts since
    Oct 3, 2007
    8. Oct 3, 2007 3:28 PM (in response to PhilBailey)
    Thanks, Phil. We were primarily using Flash Lite to test some user interfaces that we designed for mobile devices, but one of our screen designs kept bringing up the blasted context menu whenever a user would interact with it.
    Quick question, you mentioned that you got around this issue using Janus and outputting FP7--which allowed you to suppress the tap-and-hold command. Will the outputted .swf or .exe run full screen on a Windows Mobile 6 device? I wasn't sure from your post if you were running your app on a Pocket PC or an actual touch screen cell phone (ala HTC Touch, etc.).
    Oct 3, 2007
    10. Oct 3, 2007 4:34 PM (in response to PhilBailey)
    Phil, thanks again, I am going to give this a try.
    Oct 3, 2007
    11. Oct 12, 2007 12:23 PM (in response to PhilBailey)
    quote:
    Originally posted by: PhilBailey
    My application runs on a plain Pocket PC (not a phone of any kind). I am using Windows Mobile 5, but the people at spaghettisort tell me that Janus is also compatible with Windows Mobile 6.
    My .swf files run full-screen. Janus handles this just fine.
    You should be able to download a trial copy of Janus PPC from the website. It is a fully functional copy except for the "nag" message that pops up when you run your application.
    Okay, just wanted to give everyone an update on this in case someone runs into the same problem. I did download the trial version of Janus. Unfortunately, in Janus you can only disable the context menu on Flash 7 and not Flash Lite. Definitely helpful, but doesn't quite solve my issue.
    I am surprised that Adobe hasn't developed something for Flash Lite that will disable the Hold and Tap context menu in Windows Mobile. How many times have you tried to scroll in your flash movie only to have the context menu pop up instead?
  • DavidWitt_AA Calculating status... 2 posts since
    Nov 1, 2007
    12. Nov 1, 2007 4:36 PM (in response to PhilBailey)
    Sorry, this is too late to help perhaps--I use a low-tech hack to get around this; simply create an invisible button or movie clip on your lowest layer, and assign a button function with no actions to it.
