DerrickDel
Dynamically populating dropdown lists in a pdf form from a datasource
Feb 10, 2009 11:35 PM
Is there a way to populate a dropdown list in a pdf form from a datasource, specifically from an Access database table or query, using LiveCycle Designer. I am easily able to do this using cfselect in Coldfusion, however, cannot seem to figure it out for pdf forms. I am aware of the Show Dynamic Properties option enabled in LiveCycle Designer, and then binding to a datasource. However, this seems limited as I am only able to select single columns from Access (currently using an Access database) tables, and a unable to select from queries like I do using cfselect in Coldfusion forms. Is this something that must be done with Java scripting? If so, is there any other way? I know nothing about scripting. Thanks
    Feb 11, 2009 1:53 AM   in reply to DerrickDel
    Feb 16, 2009 11:01 PM   in reply to DerrickDel
    Hi DerrickDel,
    Can you please post your code here?...
    Feb 17, 2009 3:28 AM   in reply to DerrickDel
    Hi DerrickDel,
    Do you want to create an interactive pdf form from where the user can select a value from the drop down presented?
    (Or)
    You just need to populate a pdf from database tables?.
    Please clarify..
    Mar 20, 2009 10:39 AM   in reply to DerrickDel
    you can try doing a cfdocument format="pdf" and try making that a interactive form... just a thought
    Aug 5, 2010 1:08 AM   in reply to DerrickDel
    You can find a sample PDF here which related dropdown list are populated from Access table.
    Enjoy,
    Murat
    www.muratkuru.com.tr
