• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
RoboHelp Server 8
Contributor ,
Feb 04, 2009 Feb 04, 2009
Hello,
I am starting this thread to give an introduction to RoboHelp Server 8. Any comments and questions are most welcome.
RoboHelp Server 8 is completely rewritten in Java and is much more stable and robust than previous versions.
Installation is much more simplified now.
One major difference from earlier versions is now RoboHelp Server 8 does not need IIS Server. Instead it uses tomcat server.
You can download RoboHelp Server 8 trial version from http://www.adobe.com/downloads/
Prerequisite for installing RoboHelp Server 8
• Java Runtime Environment (JRE) 1.5 or higher
• Tomcat 6.0.14 (or 6.0.16)
Steps to install RoboHelp Server 8
1) Install JRE and Tomcat.
2) Verify tomcat is up and running by visiting url : http://localhost:8080
3) Launch setup.exe of RoboHelp Server 8
4) RoboHelp Server 8 should get installed. Launch Config Manager from the desktop.
5) Select the database you want to use for RoboHelp server 8 installation.
6) Click save and then close Config Manager.
7) Now open RoboHelp Server web admin url in browser: http://localhost:8080/robohelp/admin
8) Web Admin login page should get opened up.
9) Use default user name “admin” and password ”admin” to log in.
10) RoboHelp Server 8 web admin should get launched.
I shall talk about new features of RoboHelp Server 8 in follow-up thread.
If you run into any issues while installing RoboHelp Server 8, please post your queries here.
Tulika.
RoboHelp Server Team.
Adobe Systems.
Views
14.8K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Contributor ,
Feb 10, 2009 Feb 10, 2009
Hello,
I would like to introduce the "Enhanced Search" feature of RoboHelp Server 8.
RoboHelp Server 8 has two modes of search.
In one mode of search, RoboHelp Server uses the search-index generated by the RoboHTML client which is published to RoboHelp Server when the project is
published.
In the other mode, RoboHelp server re-generates the search-index at server. This is the default mode of indexing used by RoboHelp Server 8.
Server Side indexing (reindex=true) vs Client Side Indexing(reindex=false)
Advantages of Server side indexing as compared to Client Side Indexing-
a) This mode has better support for unicode search like CJK languages.
b) This search also supports wildcard search.
c) Its more efficient and robust.
d) Server Administrator can schedule reindexing of server documents at specified time. Any additional documents in pdf, doc, xls, ppt or txt format can be added to project folder on server machine explicitly at anytime and when scheduled indexing happens these documents will be indexed too and show up in search results.
This gives admin the flexibility to add documents other than RoboHTML published format to RoboHelp server and make them available to their end user via this search functionality.
Limitation of Server side indexing as compared to Client Side Indexing-
a) Project synonym list, phrase list and stop list is ignored while re-generating search index at server side.
b) Topic context is not shown in searh results.
However new search enhancements introduced in RoboHTML 8 like keyword search, ranking, excluding topic from search result are supported in both the modes.
To change the mode of indexing, user can follow these steps
-go to <RHServer8 installation path>/WEB-INF,
-open robohelp_server.properties file in notepad.
-set reindex=false (by default it is set to true).
-Restart the server(restart tomcat service)
Depending on their requirement, user can choose either mode of search.
Tulika.
Votes
Translate
Translate
Report
Report
Explorer ,
Mar 31, 2010 Mar 31, 2010
I have had my index on Robohelp 8 HTML come u and am never able to see the end of my index.
I have over 3000 Topics and the index only works up the letter 'C', and then I see 'Loading index..' and nothing ever happens.
I am not sure if I have my Robohelp server 8 index set to 'true' or 'false', but could this be my problem?
Votes
Translate
Translate
Report
Report
Explorer ,
My question was directed to Tulika, and her answer up front on the Index.
Votes
Translate
Translate
Report
Report
Advisor ,
Hi, rwrich21
I am not sure I know the answer to your question, but here are a couple of threads to review which may shed some light on your issues. There are some possible solutions toward the bottom of the thread, post #5.
http://forums.adobe.com/message/2649890#2649890
Meanwhile, I think there is a bit of confusion regarding the word "index" as it relates to Tulika's comments. She was not referring to the Keyword Index which I think is what you are asking about. Rather, she was referring to the way RoboHelp Server creates a Search Index. These are two very different things though they involve the word "index." What she was saying was that the Search Engine can use client-side or server-side indexing to create search results. Enhanced Search is what she is discussing in post #1 up above.
John Daigle
Adobe Certified RoboHelp and Captivate Instructor
Evergreen, Colorado
www.showmethedemo.com
John Daigle
Newport, Oregon
Votes
Translate
Translate
Report
Report
New Here ,
Jul 22, 2010 Jul 22, 2010
Hello, I'm having the same issue you had with my keyword index not fully loading when calling webhelppro output from a central server.
Were you ever able to resolve your issue? If yes, what did the trick?
Thanks for any help or direction
Votes
Translate
Translate
Report
Report
Explorer ,
I did not have a rename of the project problem. I have had this problem for a year and a half fortunately most of my users don't use it but I like it. It worked for awhile before we got Robohelp 7 and has not worked since.
Richard Wright
Senior Systems Analyst
NORTHROP GRUMMAN CIVILIAN AGENCIES
1615 Woodward Street
Austin, TX  78772
(512) 326-6610
Richard.Wright@va.gov
Votes
Translate
Translate
Report
Report
New Here ,
LATEST
Votes
Translate
Translate
Report
Report
New Here ,
Feb 24, 2009 Feb 24, 2009
Tulika,
I'm sorry but we are not finding the installation of RoboHelp Server 8 simplified nor easier as being promoted by Adobe. In fact, it's completely the opposite. Customers using IIS will be faced with figuring out and installing JRE and Tomcat, and for some companies, this may be the first time either of these technologies have ever been used. Neither JRE or Tomcat is included with the RoboServer 8 installation and forces the user to go out and find these resources, download them and try to figure out how they need to be installed. Why in world were they not included with the RoboHelp Server 8 installation and why weren't they automatically configured for the user? Additionally, the documentation on how any of this works is vague at best and extremely confusing. We have yet been able to get all of this to work!
We are extremely disappointments in the direction RoboHelp Server 8 has taken and the time, energy and resources being spent on getting it to work has left a lot of doubt in our minds about its future.
Votes
Translate
Translate
Report
Report
Advisor ,
Feb 26, 2009 Feb 26, 2009
Whoa, Todd. My experience was just the opposite. After years of fighting that ugly IIS-only "RoboEngine", the new RoboHelp Server 8 was a dream to install. I am an author, not a developer or an IT network person. Yet, following the documentation, I downloaded Tomcat first and installed it on the default port 8080 (a single Windows .exe to install and fairly simple actually) Then I installed RoboHelp server and set up users and protected areas. It worked "as advertised."
I agree I was anxious at first because I had never installed Apache anything. I'm pretty much a Windows guy for good or ill. It took awhile for me to go to the Apache Tomcat site, but I figured out what to download pretty quickly. I don't know, but I think the reason Adobe doesn't include Tomcat in the install is because Tomcat is an open source software and constantly changing on their own timetable. Also, there might be support issues on non-Adobe software. Obviously, if it could be packaged as a single install, they would be definitely be more convenient.
Meanwhile, for a fumble-fingers, non IT guy like me, I was pleased with the outcome. So far I've installed it on three machines without a hitch. Maybe I was lucky? What I might do is create a Captivate movie on the install process so folks can see the procedure more clearly.
john
John Daigle
Newport, Oregon
Votes
Translate
Translate
Report
Report
New Here ,
Mar 10, 2009 Mar 10, 2009
Todd,
Did you ever get yours working?
Votes
Translate
Translate
Report
Report
New Here ,
Mar 25, 2009 Mar 25, 2009
John/Vern,
Tulika helped us get RoboHelp Server 8 running last Friday (3/20/09) but unfortunately, our help system still is not functioning because there appears to be some problem with the content that's preventing RoboHelp Server from running. Specifically, Tulika says:
"The problematic characters are : < (less than), > (greater than), " (quote), & (ampersand), ‘ (apostrophe) Scan your:
1) topic names
2) topic file names
3) toc book/page name
and remove any occurrence of the above mentioned characters."
Tulika and other Adobe support staff thought we could resolve the problem by upgrading the client version of RoboHelp to version 8. However, that did not solve the problem and we need to scan literally hundreds of help files for the above characters. These "problem characters" of course have always worked in the previous versions of RoboHelp (since v4) and we believe the RoboHelp client should trap for characters if they are not supported on RoboHelp Server 8.
John I'm really glad your installation has gone well because I can definitely say ours has not. Yes, I'm sure much of this has to do with us not being familiar with Tomcat and JRE but I also don't believe we should be required to figure out how to find, download and configure these applications when, in our opinion, they should be part of the install. My tech guys tell me Adobe has used Tomcat before in a product called Version Cue but it was completely transparent. Meaning, Tomcat was installed and configured as part of the CS3 installation, which is exactly what we would have love to happened here.
To give you some idea of what it has taken to get this installed here is our time-line:
- Purchased RoboHelp Server 8 on 2/4/09
- Tried to get it running internally for 2 weeks.
- Engaged Adobe Support on 2/24/09
- Meeting w/ Adobe Support Engineers 3/2/09
- Meeting w/ Adobe Support Engineers 3/3/09
- Meeting w/ Adobe Support Engineers 3/4/09
- (Little to no response from Adobe during these 2 weeks.)
- Called Support on 03/16/09 and wouldn't get off the phone until I talked to a Support Manager. Well, I had to get off the phone but Jeri did promptly call me back.
- Meeting w/ Adobe Support Engineers 3/18/09
- Meeting w/ Adobe Support Engineers 3/20/09
- UNRESOLVED, SUPPORT SYSTEM STILL DOWN (problem with "content")
Additionally, there has been dozens of e-mails going back and forth between Adobe and our company, literally begging them for help. We came to our breaking point last week and finally demanded Adobe escalate this issue to their engineers/developers. That's when we hooked up with 2 people that really made a difference: Shawn Cormier and Tulika Garg. Both of these people are top-notch and are the ones who got the server running for us on Friday (3/20/09).
As of this writing, Tulika is still trying to pin-point exactly what file in our RoboHelp project is causing the problem with the server (yep, we zipped up our entire project and sent it off to Tulika). We're hoping for two things: (1) she can find it so we don't have to spend hours/days debugging this problem and (2) what we sent her will help Adobe fix the client and server software so others don't run into the same problem.
This post is not meant to disparage Adobe or their support staff, engineers, etc. in any way and I hope it ends up being useful to someone out there (Tulika actually asked me to post this for you – which I thought was pretty big of her).
Good luck to all.
Votes
Translate
Translate
Report
Report
New Here ,
Mar 27, 2009 Mar 27, 2009
Ok, our RoboHelp system is up and running again. The problem was definitely with the naming of the files, which were not playing nice with RoboHelp Server 8.
Tulika helped us solved the problem, here's what she said and did:
*** "I upgraded your project to RHT 8 and replaced “&”, “>”, “<”, “ ’ ” with “_” just in the file names and the project worked just fine after that. I didn’t change it anywhere else i.e. the topic names and toc entries still contain ““&”, “>”, “<”, “ ’ ” and the project was successfully published to RoboHelp Server 8 and I can view it from Web Admin page as well." ***
Votes
Translate
Translate
Report
Report
New Here ,
Apr 27, 2009 Apr 27, 2009
I'm hoping that since you were successful with RS 8, you can help us figure something out. Basically, we're evaulated version 8, but still trying to publish our version 7 robohelp projects. It did take some IT folks with Tomcat experience to get everything setup, but it appears to be working. We were able to publish our version 7 WebHelp Pro project to the server (after some touch and go trying to figure out exactly what the server string had to be, etc.
What we cannot figure out is the URL that we are supposed to use to view the webhelp? That's the main thing. But we also get a message on the Troubleshooting tab that "No default project has been defined" along with the date. But we don't see the project in the list on the Projects tab.
Thanks in advance for any help. (P.S. We are trying to launch this as part of our pilot on Friday so need to figure this out ASAP!)
-Kristen
Votes
Translate
Translate
Report
Report
Contributor ,
Can you please share your tomcat logs? They are located in "<tomcat-install-dir>/logs".
Tulika.
Votes
Translate
Translate
Report
Report
New Here ,
Apr 28, 2009 Apr 28, 2009
Thank you, Tulika, for taking the time to help us! Attached are the latest log files. Please let me know if you need other specific ones (we had about 10 of them, but I can only attach 3). I appreciate your help.
-Kristen
Votes
Translate
Translate
Report
Report
New Here ,
Thank you so much for your help. Can I email these log files to you? I'm getting an error message when I try to attach them. Thanks!
-Kristen
Votes
Translate
Translate
Report
Report
New Here ,
They are attached. Thanks so much!
Votes
Translate
Translate
Report
Report
New Here ,
Can you please clarify something that our IT guy just heard from Adobe help when he called. They told him that the topic name and file name cannot contain any spaces. I understand that is true for the file name...it always has been that spaces are replaced by the underscore. I cannot believe that the same would suddenly be true for the topic name. That would make RS8 a no-go for us.
Thanks!
-Kristen
Votes
Translate
Translate
Report
Report
LEGEND ,
Hi Kristen
I'm sure this was probably directed at someone else, but I'd be totally shocked if that were true.
Keep in mind that Adobe Support is a call center. And what you get from a call center will likely vary. You have folks that are well versed in products and other folks that aren't nearly as well versed.
I stand to be corrected on this, but I've never known Topic Titles to have any effect on things other than what they display to the user.
Sincerely... Rick
Votes
Translate
Translate
Report
Report
Contributor ,
Hi Kristen, Rick,
You can safely include space or other special characters like > < & ' (apostrophe) in your topic names and it shouldn't be an issue. Your webhelp published to RoboHelp Server 8 will work absolutely fine even if your topic names include any of the above mentioned characters.
However you should definitely replace > < & ' (apostrophe) with underscore in your filenames. But its only for filenames and you can freely use these characters in your topic names.
Tulika.
RoboHelp Server Dev Team.
Adobe Systems.
Votes
Translate
Translate
Report
Report
New Here ,
Apr 29, 2009 Apr 29, 2009
Hi again,
Yes, I was pretty confident that was the case, regarding special characters and spaces. Adobe help also apparently attributed our errors to having hyperlinks to documents in Lotus Notes databases. I have done that for years with great success. I can't believe that would cause the issue unless for some reason, the length of the URL is now an issue? (LN links are 12 miles long!).
So basically, here's the low down. Apparently we can publish the test projects (e.g., clownfish schoo) to the server and launch it using the standard URL (which I think is something like <Server>/RoboHelp/Server/Prj=<project name>) There is some "redirect" action that converts the URL to what looks like gibberish, but it pulls up the project homepage.
When we publish our project, it does not show up in the RoboServer Admin tool and we cannot access it via that URL convention. It does attempt some redirect thing and then just displays a blank page (not even an error or "topic cannot be found" page).
We can't figure out what the heck is going on. Any suggestions would be greatly appreciated! (BTW, just to remind, we are publishing RH 7 projects to the RoboServer 8 trial version for testing).
-Kristen
Votes
Translate
Translate
Report
Report
New Here ,
May 14, 2009 May 14, 2009
UPDATE: We are now successfully publishing to the RS 8 server! We have been using it in our pilot release to about 300 users for about 1-1/2 weeks and have not have any stability issues whatsoever, unlike RS 7 which had to be rebooted almost daily because it went down all the time. So we are happy about this and plan to purchase the upgrade.
However (there is always a however!), we are now going back to working with a merged master/subproject methodology. We have successfully done this (following Peter Grainge's detailed instructions) to our old RS 5 server and it works perfectly. We have published the master project to RS8, which created the mergedProjects folder and related subprojects subfolders, per usual. We published the subprojects to their respective subfolders, per usual. But here's the however part...we cannot see any of the subprojects when we open the master, as we typically would.
I'm sure this is probably some simple setting we are missing or something. Does anyone know if this merge process has changed in anyway for publishing to RS8?
-Kristen
Votes
Translate
Translate
Report
Report
Community Expert ,
Kristen
To the very best of my knowledge, the method of merging on my site works on RoboHelp Server so I don't think that is part of the problem. Unfortunately I don't work with RoboHelp Server so I cannot help you on that side of things.
I believe you are using RH7 to produce your help and I believe that needs a tweak to make it work with RHS 8. I am not sure offhand if that was part of Patch 3 and I will look into that as soon as I post this.
I am also asking someone else to look at this as he has more knowledge of RHS.
Standby.
Votes
Translate
Translate
Report
Report
Community Expert ,
Yes, Patch 3 must be installed.
Votes
Translate
Translate
Report
Report
Resources
RoboHelp Documentation
Download Adobe RoboHelp
