martyn_hsdhjksdfghjg
Can't find Adobe AIR
Feb 2, 2009 8:02 AM
I'm new to Adobe Air
I've installed this ( http://airdownload.adobe.com/air/win/download/latest/AdobeAIRInstaller .exe), I tried to make my first "Hello world" app > http://filchiprogrammer.wordpress.com/2008/03/12/creating-a-sample-hel lo-world-adobe-air-application-with-html-and-javascript/
I've set the correct path for the bins (I restarted windows, because windows needs to restart for anything)
The command adl tells me :
Adobe AIR could not be found
Use "-runtime <dir>" to specify the location of the runtime
Even if i specify the path wehe adobe air is :
adl -runtime C:\Program Files\Adobe AIR\Versions\1.0
Please help me. I really want to know more about Air.
Thanks in advance
    Feb 2, 2009 9:43 AM   in reply to martyn_hsdhjksdfghjg
    If you download the whole SDK,
    adl HelloWorld-app.xml
    should work. You don't need to specify the path for Runtime.
    Feb 2, 2009 3:24 PM   in reply to martyn_hsdhjksdfghjg
    There is nothing to install for SDK. ADL should use the default Runtime that comes with the SDK. That is why you don't specify for the -runtime option.
    If you have installed AIR Runtime, you can use:
    adl -runtime "C:\Program Files\Common Files" HelloWorld-app.xml
    Feb 9, 2009 9:50 AM   in reply to martyn_hsdhjksdfghjg
    ADL doesn't use Java. Only ADT uses Java.
    For ADT, you should use version 1.4.012 and up.
