I'm using CS3
I'm working on a sharepoint file that involves a video of a
presentation with embedded cue points that trigger specific
keyframes which in turn display text relative to what the person in
the video is saying. I've gotten this all to work just fine when
its just one scene, but the presentation is broken up into 5
chapters and what I was trying to do is have each chapter have its
own scene. I set this up, but discovered that while the
seekToNextNavCuePoint works fine for the first scene, it doesn't
work with the next scene. Instead it jumps to the new cue point,
plays about a half second of the video and then the movie's UI
(it's one of the out-of-the-box one's that come with Flash Pro)
progress bar goes all stripey and then it stops.
I attached the Actionscript I have setup for the 1st scene. I
have Flash Player setup for debugging, but this doesn't seem to
trigger any error messages. I've tried for each additional scene to
rename everything so that there aren't any duplicated instances
between the scenes but that didn't work. I even took that 2nd scene
and when I deleted all the scenes around cue skipping worked just
fine, so it seems like it's something specific to do with having
multiple scenes.
I'm hoping it's just a coding issues and not a a larger
problem with something.
For now I've just made each scene it's own Flash movie, but I
was kind of hoping to have it all as one movie file. Thoughts?
All help is appreciated.
