Martijn74
FW CS4: changing the unit of measurement for type
Dec 24, 2008 12:55 PM
Hello,
Does anyone know where I can change the unit of measurment for type in CS4? Per default it's set to pt but I need it to be in px. According to the online help you can change it in the preference dialog box but I can't find it there..
Also when you look at the online help for the type preferences (see here) it's not mentioned....[
    Dec 26, 2008 4:58 PM   in reply to Martijn74
    Good question, but I've never seen a way to set font size to pixels within Fireworks (though that does not mean it doesn't exist - only that I haven't seen it.) The only pixel measurement option I've seen is for leading - you can choose % or px. All of the font size options I found in CS4 are only in points.
    Where did you see in the online help that it can be changed in a preference dialog? Posting a link to that reference might help to track down the option if it exists. (Is it possible that the new type engine in CS4 does not offer a pixel size option?)
    Dec 29, 2008 12:25 AM   in reply to Martijn74
    -double post-
    Dec 29, 2008 2:02 PM   in reply to Martijn74
    Thanks - I see it now.
    I noticed in the top right corner of the page a note that says "Topic appears in: InDesign, Illustrator, Fireworks" - perhaps you can change the unit of measure for fonts in the Preferences dialog in some or all of these other tools, but not in Fireworks. It may just be a content error and not actually apply to Fireworks.
    I looked at the documentation for extending Fireworks to see if text size has a pixel size attribute, and it appears that TextAttr.size only accepts point size measures:
    http://help.adobe.com/en_US/Fireworks/10.0_Extending/WS5b3ccc516d4fbf3 51e63e3d1183c94988d-7efd.html
    It looks like it might be content error in the help documentation.
    You can submit a bug and request for correction here:
    http://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
    Mar 23, 2012 9:57 PM   in reply to Martijn74
    unfortunately this seems to be true for all versions of Fireworks. I purchased the CS5 upgrade with the promise that this terrible use of points instead of pixels in FW would be resolved. I can assure you it is not.
    this help page was also very lame as it first says FW default is Points, then says defaults to Pixels, then says you can change it, then says you can not change it. take a look.
    http://help.adobe.com/en_US/fireworks/cs/using/WS3A6A1373-EB19-45f9-84 00-B2DB3DD32391.html#community
    Someone help..because FW only points, totally unacceptable. Im having to do my text by hand in html before I can accurately spec my image mocks because I cant tell my team what the pixel size of the font face is. and no, rendering text as paths does NOT give you an accurate unit of measure.
    Mar 24, 2012 10:09 AM   in reply to katherine.mary
    Don't fret! The default unit of text in Fireworks is pixels, not points.
    The lack of units in FW can be confusing... and it can lead to sloppy thinking. And that particular Help page does more harm than good, because it appears to have been written for multiple applications, not just Fireworks. But if you read it with that in mind, you'll understand that Fireworks is the exception: it uses pixels as the unit for text size, and that unit cannot be changed in Preferences.
    I confirmed this myself a while back, while playing with text at small sizes—including bitmap fonts, and vector fonts rendered without anti-aliasing. At the time, I thought, "Oh, pixels or points... what's the difference?" But it makes a big difference if you're dealing with a bitmap font that was designed to be rendered on an 8-pixel grid. It won't render properly if sized at 9 or 10 pixels... Anyway, points are generally larger than pixels, thanks to modern screen resolutions, and the two units are not equivalent. Fireworks is a bitmap editor, so it assumes you know that you're working with pixels, not points.
