quote:
Originally posted by: Tom Pesto
Hi guys,
If you're having issues with Fireworks CS4, try to run the CS4 cleanscript.
It's a utility to uninstall ALL CS4 programs. This way you can make a clean reinstall. Maybe someone installed beta versions before of CS4? Beta versions have been known to cause problems.
Here's the link to the Cs4 cleanscript
http://www.adobe.com/support/contact/cs4clean.html
Tell us if it helps.
quote:
Originally posted by: jaymannz
I had this same issue. When I loaded Fireworks CS4, it would get past the splash screen but then come up with an error "An internal error occurred. An internal error occurred" (yes the message appeared twice in the same message box).
I resolved this issue by deleting my Fireworks CS4 "configuration" folder.
For Vista users you can find this folder under C:\Users\<username>\AppData\Roaming\Adobe\. Sorry XP users but I don't know the exact path for you but will assume that it is something like C:\Documents and Settings\<username>\Application Data\Adobe\.
I renamed the "Fireworks CS4" folder to "Fireworks CS4 OLD" (just so I could access it again if need be). When I relaunched Firefox CS4, the "configuration" folder was recreated and my problem disappeared (along with any preferences and workspaces that I had created - but hey that is better than NOT being able to access the application fullstop).
I hope this can help you all.
I did that. I even deleted the whole Adobe folder and still having no luck.
I can only try and reinstall Windows Vista :(
quote:
Originally posted by: FILExt
I've had the internal error with Fireworks CS4 also and have been exchanging notes with a senior support person for some time now. Finally hit on the solution (for me at least)...too many fonts installed.
I had 1250+ fonts. When I removed them all to a backup folder and left Vista with just its defaults; after a restart Fireworks fired up just fine. I've put up to 339 back and Fireworks still starts OK so I don't know what the threshold number is (I'd guess 1024 for obvious binary reasons but it would just be a guess).
Anyhow, check your font count and if it's over that number at least consider removing some you don't use and/or back them all up, remove them all, and just reinstall the fonts you do use. Then, restart and see if Fireworks starts for you as well.
Tom
North America
Asia Pacific
