Oct 23, 2008 10:45 AM
Hi All
I am having an issue when trying to rename a file under a
folder with a period in the name of the folder.
I have tried this test on 3 different servers with the same
result
I first did a rename action in a cfm file that was
not under a folder with a period and it works renaming a
file that lives under a folder with a period.
d:\test.cfm action rename d:\test.temp\test.txt to
d:\test.temp\test.xml (works)
So i moved my cfm file to the folder with a period and poof
it breaks. so apparently if you try to rename a file from a cfm
file that lives under a folder with a period it fails with invalid
source attribute error.
d:\test.temp\test.cfm action rename d:\test.temp\test.txt to
d:\test.temp\test.xml (fails)
The value of the attribute source, which is currently
"d:\test.temp\test.txt", is invalid.
whats worse is this code worked under version 5.
My question is, is the a documented issue or is something
that other users are seeing that no one knows about?
Is there a hot fix for this? All 3 servers are at Cumulative
HF3
Tim Garver
