.swf files dont open in Internet Explorer!
May 23, 2006 2:21 PM
Well the topic summary says it all.
It seems that everytime I try to open a webpage with a .swf extension (ex. http://www.freewebs.com/donjworks/snipe.swf), it just shows a white screen with that little symbol (the one with the triangle, the circle and the square) in the top left corner. Its really annoying.
Any help in helpful (Well duh!)
    May 23, 2006 2:28 PM   in reply to Donjworks
    "Donjworks" <webforumsuser@macromedia.com> wrote in message news:e4vuda$dem$1@forums.macromedia.com...
    > It seems that everytime I try to open a webpage with a .swf extension (ex. <a
    > target=_blank class=ftalternatingbarlinklarge
    > href=" http://www.freewebs.com/donjworks/snipe.swf">http://www.freewebs.com/d onjw
    > orks/snipe.swf</a> , it just shows a white screen with that little symbol (the
    > really annoying.
    Browsers don't normally open swf files directly, they are supposed to load through an html header. Many people put swfs on their
    WebPages without the html even though they shouldn't so you need to set your file associations so that your browser is told to open
    swf files. If you run windows..
    Open Windows Explorer (not Internet Explorer)
    Tools..
    Folder Options..
    File Types..
    Scroll down to SWF
    In the lower box it says what SWFs are supposed to open with. If it doesn't say Internet Explorer or Firebox or (your browser) then
    you need to click on the 'change' button and select your browser from the list. Turn on the check mark for "always open with..."
    If it already says your browser name then the browser might have it's security settings set too high to view the swf files. (or
    JavaScript turned off)
    tralfaz
    May 23, 2006 2:29 PM   in reply to Donjworks
    Are you sure the path and name along with the file are correct? I get the same thing except in the lower left of the screen there is an error on something. You may want to check that out to make sure there is not a problem.
    May 23, 2006 3:05 PM   in reply to Donjworks
    I tried the same thing and am having problems for both IE and Firefox. Both are fully updated.
    What I get is a broken QuickTime logo instead of a Flash image. I just created another thread with my ordeal.
    May 23, 2006 3:49 PM   in reply to Donjworks
    It should work just fine .. it certainly does for me in both IE and FireFox.
    Opening a .SWF directly in the browser is a good idea to avoid html
    incompatibilities and new IE problems. etc. I don't know why you would be
    having trouble doing that, unless there is some sort of intermittent
    server-side problem or some other problem on your computer.
    Jeckyl
